Home » Archived » M2M (model-to-model transformation) » [ATL] How to implement symbol-table building in ATL?
[ATL] How to implement symbol-table building in ATL? [message #105138] Sun, 17 May 2009 12:43 Go to next message
Hi, everyone,
I am using ATL to convert a language La to another language Lb. The transformation La2Lb, however, depends on some contextual information, say the type of identifiers.
Do you have any idea of how to implement such kind of context-dependent transformation in ATL?
Thanks.
Michael.
Re: [ATL] How to implement symbol-table building in ATL? [message #105173 is a reply to message #105138] Mon, 18 May 2009 05:19 Go to previous messageGo to next message
Hi Michael,
as ATL is able to use more than one source-model - why don't you integrate
your contextual information by means of a second source-model?
Lucas
Michael wrote:
> Hi, everyone,
> Thanks.
> Michael.
Re: [ATL] How to implement symbol-table building in ATL? [message #105214 is a reply to message #105173] Mon, 18 May 2009 07:38 Go to previous messageGo to next message
Lucas wrote:
> Hi Michael,
> integrate your contextual information by means of a second source-model?
> Cheers,
> Lucas
> Michael wrote:
>> Hi, everyone,
>> Thanks.
>> Michael.
Hi Lucas:
Do you have any example of this?
Thanks.
Michael.
Re: [ATL] How to implement symbol-table building in ATL? [message #105254 is a reply to message #105214] Tue, 19 May 2009 02:40 Go to previous messageGo to next message
sorry, I don't have an example. Maybe you can illustrate your
problem&question a bit further, which could make it easier to find an
answer...
Lucas
Michael wrote:
> Lucas wrote:
>> Hi Michael,
>> Cheers,
>> Lucas
>> Michael wrote:
>>> Hi, everyone,
>>> Thanks.
>>> Michael.
> Hi Lucas:
> Thanks.
> Michael.
Re: [ATL] How to implement symbol-table building in ATL? [message #105282 is a reply to message #105254] Tue, 19 May 2009 06:04 Go to previous message
Hi Lucas:
My case invovles an ATL tranformation which is from language L to Java. Actually, L is also a kind of OOP language similar to Java in structure: it has classes, enclosing
fields, methods, and so on. For example, the assignment of L is in the following form:
Identifer ::= Expression.
The L assignment is expected to be translated into a Java assignment in the following form:
JavaIdentifier :: = (CastingType)JavaExpression,
where the CastingType is type of the JavaIdentifier on the left handside. This means, this translation depends on the contextual information of the identifer--its type.
According to your valueable suggestion, first, we can translate an instance of L to a model which acts as the symbol table. Then I can translate the two models ( the instance of L and the
resulting symble-table model) to the Java program.
As far as I know, this seems ok. For me, the difficulty is how to design the metamodel of the symbol table. I think that symbol-table metamodel should
contains a scope which is nestable, and the scope contains a variable. The problem is how to navigate to the appropriate scope in the second translation.
Your comments are highly appreciated.
Regards.
Michael.
expected to be translated into a java assignment.
Lucas wrote:
> answer...
> Lucas
> Michael wrote:
>> Lucas wrote:
>>> Hi Michael,
>>> Cheers,
>>> Lucas
>>> Michael wrote:
>>>> Hi, everyone,
>>>> The
>>>> Thanks.
>>>> Michael.
>> Hi Lucas:
>> Thanks.
>> Michael.
Previous Topic:[ATL]Load input model for atl transformation within java code
Next Topic:inject km3 to ecore
Current Time: Wed Sep 17 00:41:56 EDT 2025
Powered by FUDForum. Page generated in 0.04692 seconds
