Home » Eclipse Projects » EclipseLink » JPA/Dynamic OneToOne attribute in inherited table(insert new row failed when the OneToOne row is in a a table with inheritance)
JPA/Dynamic OneToOne attribute in inherited table [message #1051378] Sun, 28 April 2013 13:48 Go to next message
Mad
I am using JPA/Dynamic in a project which is very powerful for the purpose of my project. However I found some limitation or issue
I am struggling with a one to one relationship in a inherited table. As long the 1:1 is not in a inherited table it works fine
I putting the full test code I used the issue happen when I insert a new row I got null pointer
at org.eclipse.persistence.mappings.ObjectReferenceMapping.getRealAttributeValueFromAttribute(ObjectReferenceMapping.java:329)
at org.eclipse.persistence.mappings.OneToOneMapping.writeFromObjectIntoRowInternal(OneToOneMapping.java:1864)
at org.eclipse.persistence.mappings.OneToOneMapping.writeFromObjectIntoRow(OneToOneMapping.java:1802)
at org.eclipse.persistence.internal.descriptors.ObjectBuilder.buildRow(ObjectBuilder.java:1394)
at org.eclipse.persistence.internal.descriptors.ObjectBuilder.buildRow(ObjectBuilder.java:1382)
at org.eclipse.persistence.internal.queries.DatabaseQueryMechanism.insertObjectForWrite(DatabaseQueryMechanism.java:450)
at org.eclipse.persistence.queries.InsertObjectQuery.executeCommit(InsertObjectQuery.java:80)
at org.eclipse.persistence.queries.InsertObjectQuery.executeCommitWithChangeSet(InsertObjectQuery.java:90)
at org.eclipse.persistence.internal.queries.DatabaseQueryMechanism.executeWriteWithChangeSet(DatabaseQueryMechanism.java:300)
at org.eclipse.persistence.queries.WriteObjectQuery.executeDatabaseQuery(WriteObjectQuery.java:58)
at org.eclipse.persistence.queries.DatabaseQuery.execute(DatabaseQuery.java:899)
at org.eclipse.persistence.queries.DatabaseQuery.executeInUnitOfWork(DatabaseQuery.java:798)
at org.eclipse.persistence.queries.ObjectLevelModifyQuery.executeInUnitOfWorkObjectLevelModifyQuery(ObjectLevelModifyQuery.java:108)
at org.eclipse.persistence.queries.ObjectLevelModifyQuery.executeInUnitOfWork(ObjectLevelModifyQuery.java:85)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.internalExecuteQuery(UnitOfWorkImpl.java:2894)
at org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1797)
at org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1779)
at org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1730)
at org.eclipse.persistence.internal.sessions.CommitManager.commitNewObjectsForClassWithChangeSet(CommitManager.java:226)
at org.eclipse.persistence.internal.sessions.CommitManager.commitAllObjectsForClassWithChangeSet(CommitManager.java:193)
at org.eclipse.persistence.internal.sessions.CommitManager.commitAllObjectsWithChangeSet(CommitManager.java:138)
at org.eclipse.persistence.internal.sessions.AbstractSession.writeAllObjectsWithChangeSet(AbstractSession.java:4200)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.commitToDatabase(UnitOfWorkImpl.java:1439)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.commitToDatabaseWithChangeSet(UnitOfWorkImpl.java:1529)
at org.eclipse.persistence.internal.sessions.RepeatableWriteUnitOfWork.commitRootUnitOfWork(RepeatableWriteUnitOfWork.java:277)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.commitAndResume(UnitOfWorkImpl.java:1167)
at org.eclipse.persistence.internal.jpa.transaction.EntityTransactionImpl.commit(EntityTransactionImpl.java:132)
... 2 more
JPADynamicHelper helper = new JPADynamicHelper(emf);
DynamicClassLoader dcl = helper.getDynamicClassLoader();
String packagePrefix = "test" + ".";
companyClass = dcl.createDynamicClass(packagePrefix + "Company");
company = new JPADynamicTypeBuilder(companyClass, null, "u_company");
company.setPrimaryKeyFields("sys_id");
company.addDirectMapping("id", String.class, "sys_id");
company.addDirectMapping("name", String.class, "name");
taskClass = dcl.createDynamicClass(packagePrefix + "Task");
task = new JPADynamicTypeBuilder(taskClass, null, "u_task");
incidentClass = dcl.createDynamicClass(packagePrefix + "Incident", taskClass);
incident = new JPADynamicTypeBuilder(incidentClass, task.getType(), "u_incident");
problemClass = dcl.createDynamicClass(packagePrefix + "Problem", taskClass);
problem = new JPADynamicTypeBuilder(problemClass, task.getType(), "u_problem");
changeClass = dcl.createDynamicClass(packagePrefix + "Change", taskClass);
change = new JPADynamicTypeBuilder(changeClass, task.getType(), "u_change");
requestClass = dcl.createDynamicClass(packagePrefix + "Request", taskClass);
request = new JPADynamicTypeBuilder(requestClass, task.getType(), "u_request");
task.setPrimaryKeyFields("sys_id");
task.addDirectMapping("id", String.class, "sys_id");
task.addDirectMapping("name", String.class, "name");
task.addDirectMapping("description", String.class, "description");
incident.setPrimaryKeyFields("sys_id");
incident.addDirectMapping("id", String.class, "sys_id");
incident.addDirectMapping("delivery", String.class, "delivery");
incident.addDirectMapping("test", int.class, "test");
problem.setPrimaryKeyFields("sys_id");
problem.addDirectMapping("id", String.class, "sys_id");
problem.addDirectMapping("budget", double.class, "BUDGET");
problem.addDirectMapping("milestone", Calendar.class, "MILESTONE");
change.setPrimaryKeyFields("sys_id");
change.addDirectMapping("id", String.class, "sys_id");
request.setPrimaryKeyFields("sys_id");
request.addDirectMapping("id", String.class, "sys_id");
employeeClass = dcl.createDynamicClass(packagePrefix + "Employee");
employee = new JPADynamicTypeBuilder(employeeClass, null, "u_employee");
employee.setPrimaryKeyFields("sys_id");
employee.addDirectMapping("id", String.class, "sys_id");
employee.addDirectMapping("firstName", String.class, "firstname");
employee.addDirectMapping("lastName", String.class, "lastname");
employee.addManyToManyMapping("tasks", task.getType(), "u_task_emp");
ClassDescriptor descriptor = task.getType().getDescriptor();
descriptor.getInheritancePolicy().setClassIndicatorFieldName("task_type");
descriptor.getInheritancePolicy().addClassIndicator(task.getType().getJavaClass(), "TASK");
descriptor.setJavaInterface(task.getType().getJavaClass());
helper.addTypes(true, true, task.getType());
descriptor.getInheritancePolicy().addClassIndicator(incident.getType().getJavaClass(), "INCIDENT");
ClassDescriptor descriptor_incident = incident.getType().getDescriptor();
descriptor_incident.getInheritancePolicy().setClassIndicatorFieldName("task_type");
descriptor_incident.getInheritancePolicy().setParentClass(task.getType().getJavaClass());
helper.addTypes(true, true, incident.getType());
descriptor.getInheritancePolicy().addClassIndicator(problem.getType().getJavaClass(), "PROBLEM");
ClassDescriptor descriptor_problem = problem.getType().getDescriptor();
descriptor_problem.getInheritancePolicy().setClassIndicatorFieldName("task_type");
descriptor_problem.getInheritancePolicy().setParentClass(task.getType().getJavaClass());
descriptor.getInheritancePolicy().addClassIndicator(change.getType().getJavaClass(), "CHANGE");
ClassDescriptor descriptor_change = change.getType().getDescriptor();
descriptor_change.getInheritancePolicy().setClassIndicatorFieldName("task_type");
descriptor_change.getInheritancePolicy().setParentClass(task.getType().getJavaClass());
descriptor.getInheritancePolicy().addClassIndicator(request.getType().getJavaClass(), "REQUEST");
ClassDescriptor descriptor_request = request.getType().getDescriptor();
descriptor_request.getInheritancePolicy().setClassIndicatorFieldName("task_type");
descriptor_request.getInheritancePolicy().setParentClass(task.getType().getJavaClass());
helper.addTypes(true, true, problem.getType());
helper.addTypes(true, true, change.getType());
helper.addTypes(true, true, request.getType());
helper.addTypes(true, true, employee.getType());
helper.addTypes(true, true, company.getType());
incident.addOneToOneMapping("company", company.getType(), "sys_id_company");
I have populated company with some rows
to populate incident
EntityManager em = emf.createEntityManager();
em.getTransaction().begin();
DynamicEntity emp = employee.getType().newDynamicEntity();
emp.set("firstName", "Bob");
emp.set("lastName", "Smith");
emp.set("id", SysID.get());
Collection<DynamicEntity> tasks = emp.<Collection<DynamicEntity>> get("tasks");
tasks.add(incident1());
em.merge(emp);
em.getTransaction().commit();
public DynamicEntity incident1() {
DynamicEntity compEntity = company.getType().newDynamicEntity();
DynamicEntity comp = em.find( compEntity.getClass(),"e25e91119c154122bd3f22f77f7be4cd");
DynamicEntity sm = incident.getType().newDynamicEntity();
sm.set("name", "incident2");
sm.set("description", "bad incident");
sm.set("delivery", "Shipping Query Tool");
sm.set("company", comp);
sm.set("test", 50);
sm.set("id", SysID.get());
return sm;
Any help appreciate
JP
Re: JPA/Dynamic OneToOne attribute in inherited table [message #1052714 is a reply to message #1051378] Tue, 30 April 2013 08:50 Go to previous message
Why are you not adding the OneToOne mapping with the descriptor's other mappings, but instead waiting until the end. It looks like the mapping is never getting initialized (as you are adding it after you have registered the descriptor). You need to add the mapping before registering the descriptor.
Previous Topic:No data persisted to database with new JPA-RS libs
Next Topic:Exception in thread "main" java.lang.ExceptionInInitializerError
Current Time: Thu Jul 24 19:27:16 EDT 2025
Powered by FUDForum. Page generated in 0.04572 seconds
