Home » Archived » Test and Performance Tools Platform (TPTP) » [AGR] How is attribute choiceId determined?
[AGR] How is attribute choiceId determined? [message #105115] Mon, 16 July 2007 15:50 Go to next message
Hello.
I have a quick question: in a "choice-select" type command, how is the
value of the choiceId attribute determined? I am particularly interested
at the case of a tab selection.
TIA,
B.
Re: [AGR] How is attribute choiceId determined? [message #105176 is a reply to message #105115] Mon, 16 July 2007 17:23 Go to previous messageGo to next message
Hi Barbara,
The "choiceId" as you see it in the test case Macro, is determined by the
following procedure:
First, we try to resolve the widget which has been selected by attempting to
resolve the widget using registered widget resolvers.
In most cases, one of the widget resolvers will return a valid WidgetId of
which we use the actual id attribute. This may be, for example, the text of
the TabItem.
If the resolvers can not resolve the widget then we compute a default
choiceId by combining "item#" with the index of the selection in terms of
the parent TabFolder (for the tab selection case).
I hope this answers your question. Let me know if anything remains unclear.
Sincerely,
Liz Dancy
"Barbara Rosi-Schwartz" <Barbara.Rosi-Schwartz@Etish.org> wrote in message
news:f7gi66$9qd$1@build.eclipse.org...
> Hello.
> TIA,
> B.
Re: [AGR] How is attribute choiceId determined? [message #105189 is a reply to message #105176] Tue, 17 July 2007 06:03 Go to previous messageGo to next message
Hi Liz.
Thanks for your clear reply. The reason I asked is the fact that I was
having some problem that I now resolved.
However I now have two related question. I am trying to customise my
widgets IDs as much as I can by using setData() on the widgets at
construction time and then by having my widgetReg.xml using the
getData() method to define their ID. The questions are as follows:
1) A CTabFolder that is used in a MultiPageEditor looks in my object
mine as follows:
<object descriptive="CTabFolder" referenceId="15"
contextId=" editor/com.etish.useme.client.editor.usecase.ui.editor.useca se.UseCaseEditor/aaa "
id="org.eclipse.swt.widgets.Composite#3"/>
In other words, try as I may, the id is still a generic one. Which
Composite do I need to setData() on to have a customised ID?
2) The object mine has the following element:
<object descriptive="CTabFolder: Conditions" referenceId="14"
resolverId="org.eclipse.tptp.test.auto.gui.adaptive"
id=" {{com.etish.useme.client.editor.usecase.ui.editor.usecase.de scription.DescriptionPage/1}}-{{1.0}} "/>
Although my test case works at playback time, I am baffled by the fact
that I am sitting on an editor page that is called DescriptionPage and I
am clicking on a tab called Conditions. The object in the mine refers to
the Conditions page but the ID is still that of the first tab, the
DescriptionPage.
As I mentioned, my widgetReg.xml has got the following rule:
<class name = "org.eclipse.swt.custom.CTabFolder" matchThreshold = "1.0">
<method name = "getData" weight = "1.0"/>
</class>
As I said, my test works, but I would like to understand what is happening.
Thank you very much,
B.
Liz Dancy wrote:
> Hi Barbara,
> the TabItem.
> Sincerely,
> Liz Dancy
>> Hello.
>> TIA,
>> B.
Re: [AGR] How is attribute choiceId determined? [message #106294 is a reply to message #105189] Tue, 24 July 2007 11:10 Go to previous messageGo to next message
Hi Barbara,
I would recommend creating a custom widget resolver in this case. This gives
you more control and is a more modular solution.
However, if you prefer to modify the widgetReg.xml, could you send me your
test suite (with Object Mine) as well as any setup required so I can step
through and see the specifics leading to the Object Mine entry (and also the
ID from question 1)).
Sincerely,
Liz Dancy
news:f7i45i$306$1@build.eclipse.org...
> Hi Liz.
> construction time and then by having my widgetReg.xml using the getData()
> 1) A CTabFolder that is used in a MultiPageEditor looks in my object mine
> as follows:
> DescriptionPage.
> <method name = "getData" weight = "1.0"/> </class>
> happening.
> B.
> Liz Dancy wrote:
>> Hi Barbara,
>> to resolve the widget using registered widget resolvers.
>> of which we use the actual id attribute. This may be, for example, the
>> text of the TabItem.
>> unclear.
>> Sincerely,
>> Liz Dancy
>> message news:f7gi66$9qd$1@build.eclipse.org...
>>> Hello.
>>> TIA,
>>> B.
Re: [AGR] How is attribute choiceId determined? [message #106308 is a reply to message #106294] Tue, 24 July 2007 11:55 Go to previous message
Thanks for your reply, Liz.
I will have a look at the custom widget resolver path and try and follow
it if it is not too complex or time consuming.
Thanks again.
So long,
B.
Liz Dancy wrote:
> Hi Barbara,
> Sincerely,
> Liz Dancy
Previous Topic:Where is the java src attachments for TPTP 4.4?
Next Topic:Agent Controller unavailable on amd64
Current Time: Sat Jul 26 20:18:31 EDT 2025
Powered by FUDForum. Page generated in 0.04878 seconds
