Home » Eclipse Projects » P2 » Error installing repository from command line using director application
Error installing repository from command line using director application [message #1034333] Fri, 05 April 2013 06:06 Go to next message
Dear all,
I'm trying to install a feature from command line:
eclipse.exe -nosplash -application org.eclipse.equinox.p2.director -repository file:"[PATH_TO_COMPOSITE]" -installIU [NAME_FEATURE]
I'm using both Eclipse 3.8 and 4.2.
The command fails with the following error. What is strange for me is that the same command has worked fine with previous version of Eclipse (3.6)
ENTRY org.eclipse.equinox.p2.core 4 0 2013-03-29 10:08:52.636
!MESSAGE Provisioning exception
!STACK 1
org.eclipse.equinox.p2.core.ProvisionException: No repository found at jar:file:../p2_repositories/ NAME_FEATURE.zip!.
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.fail(AbstractRepositoryManager.java:393)
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:675)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:96)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:92)
at org.eclipse.equinox.internal.p2.metadata.repository.CompositeMetadataRepository.addChild(CompositeMetadataRepository.java:165)
at org.eclipse.equinox.internal.p2.metadata.repository.CompositeMetadataRepository.<init>(CompositeMetadataRepository.java:105)
at org.eclipse.equinox.internal.p2.metadata.repository.CompositeMetadataRepositoryFactory.load(CompositeMetadataRepositoryFactory.java:122)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.factoryLoad(MetadataRepositoryManager.java:57)
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:758)
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:651)
Thanks in advance for any suggestion,
Stefano
[Updated on: Mon, 08 April 2013 08:38] by Moderator
Re: Error installing repository from command line using director application [message #1051088 is a reply to message #1034333] Sun, 28 April 2013 03:19 Go to previous message
On 04/05/2013 12:06 PM, Stefano Oliveri wrote:
> Dear all,
> (3.6)
> !STACK 1
> at
I don't know whether this is the case, but p2 expected an absolute path,
if I remember correctly; are you using a relative path?
cheers
Lorenzo
HOME: http://www.lorenzobettini.it
Previous Topic:Updating Eclipse E4 project fails through p2
Next Topic:p2 director headless, can't find missing dependency from other repo.
Current Time: Mon Jul 21 06:15:35 EDT 2025
Powered by FUDForum. Page generated in 0.08145 seconds
