| Home » Eclipse Projects » GEF » POLL: What will you be building with GEF?
 Goto Forum:|  |  |  |  |  |  |  |  |  |  |
| Re: POLL: What will you be building with GEF? [message #2109 is a reply to message #1908] | Thu, 16 May 2002 21:17   |  |
| Eclipse User  |  |  |  |  | I don't (yet) have a work application for GEF, although somebody mentioned visual workflow modelling, which would be useful.
 However, in my spare time I write games, and I will probably use GEF for
 that. An example would be a tool to create and edit maps (that's what my
 bezier curve tool was for).
 Colin M Sharples/New Zealand/IBM, IT Architect, BIS
 sharples@nz1.ibm.com, t: 64-4-5769853, m: 64-21-402085, f: 64-4-5765616
 "Sometimes I think the surest sign intelligent life exists
 elsewhere in the Universe is that it's never tried to contact us"
| Re: What will you be building with GEF? [message #3921 is a reply to message #3903] | Thu, 23 May 2002 11:03   |  |
| Eclipse User  |  |  |  |  | Originally posted by: crivet.rational.com
 One problem is that there is no way to determine if or where Eclipse is
 installed...short of asking the user.  This is not a nice installation
 process and does not provide for a nice user experience.  With WSAD, we can
 actually determine that it is installed and where, so we can install XDE in
 that environment.  Obviously, if XDE is installed standalone, we also have
 control over where we install the IBM WebSphere Studio Workbench platform...
 By the way, if you install WSAD today, you will still have the same issue
 with Eclipse 2.0, i.e., two development environments, so this is not
 isolated to XDE.  This would also be the case for other commercial tool
 providers who prefer to use released and stable platforms for their
 products.  You will therefore have to wait for Eclipse 2.0 to be released,
 and then for the IBM WebSphere Studio Workbench and Application Developer to
 be released before you see a version of XDE for those platform.
 And yes, XDE does provide an integrated environment, just not with the
 version of the tool platform you want right now.
 /Charles
 "Mark" <none@nospam.com> wrote in message news:ach0t6$lni$1@rogue.oti.com...
 > and in this case you end up having to versions of the same
 > ide (WSAD based on eclipse 1.0 AND a new eclipse 2.0 build)
 > installed on your machine. as far as i understand this is exactly what
 > you not want. or is it not the big sales argument for xde to have
 > only one integrated environment?
 > working with XDE would be much more fun, if you could directly
 > install into eclipse.
 > -- mark
 > "Charles Rivet" <crivet@rational.com> wrote in message
 > news:acgv10$ksj$1@rogue.oti.com...
 > > "Werner Keil" <keil@surveycom.com> wrote in message
 > > news:acad3q$s8o$1@rogue.oti.com...
 > > [...Snip...]
 > > > Plus I hate the fact that XDE only works for WSAD so
 > > > a really OPEN tool (based on GEF) is one I would like
 > > > to see (and use or even take part in) a LOT.
 > > [...Snip...]
 > > Actually, XDE will also install on its own, without WSAD.  In that case,
 > it
 > > installs the IBM WebSphere Studio Workbench and rebrands that.
 > > /Charles
| Re: What will you be building with GEF? [message #3942 is a reply to message #3921] | Thu, 23 May 2002 15:15   |  |
| Eclipse User  |  |  |  |  | hi charles!
 news:acivg7$e8r$1@rogue.oti.com...
 can
 in
 platform...
 well, eclipse doesn't even have a *simple* installer and people are able to
 run it anyway. ;-)
 unzipping an archive is not that bad actually and much better than a
 installer polluting and messing
 up your registry.
 also the XDE installer could ask the user to point it to the eclipse install
 directory. after
 that the installer could even check if the plugin's directory exists or not.
 it might even do some
 more elaborate checks to make sure it is likely that XDE will run on the
 given code base.
 even if the installer finds a version of eclipse which is newer than
 expected it could
 display a warning and ask the user *really* wants to continue. would you
 consider this
 as "not a nice installation process"?
 all in all if you are smart enough to do some UML design you should be smart
 enough
 to figure out how to install a plug-in. if not you better not start thinking
 about
 software architecture at all. ;-))
 > isolated to XDE.
 what makes you think that i would want to install both, eclipse and WSAD?
 they are both IDE's for developing java code. so why both of them? the case
 of XDE is
 a little different in my opinion. when i install XDE i need a UML design
 tool as
 just another plugin in addition to the many other plugin's i have installed.
 > products.
 hmm, i guess this is not really the point here. let's take eclipse v1.0 e.g.
 i assume this is a stable platform by your definition. could i install XDE
 on top of this on?
 well, at least not today. why? it's a stable platform!
 however it's ok to define minimum requirements (a.k.a. "stable" platform).
 but XDE excludes *all* eclipse users without a good reason.
 to
 this is exactly what i don't like on the deployment concept of XDE. i need
 to wait one
 cycle too long (the release of the WSAD platform) before i can use XDE with
 the new
 eclipse 2.0 code. this is not necessary because i will probably *never ever*
 use WSAD.
 well, in this case XDE is no different to any other "integrated environment"
 where everything
 is integrated as long as you get everything from one vendor. (well, in XDE
 case 2 vendor - but
 one box)
 i guess this conecpt is from the 80's. why do you think the eclipse
 architecture is so much concernd about
 integrating 3rd party tools as first class components? with this platform
 it's possible
 to install components from many different vendors and it *still* behaves in
 the same consistent way.
 in my believe you exclude all eclipse users from using XDE.
 i don't see any technical reasons for this.
 if this is company policy, i guess its a different story - but in this case
 we don't have to
 argue here ;-))
 > /Charles
 -- mark
 > > -- mark
 > > > [...Snip...]
 > > > [...Snip...]
 case,
 > > it
 > > > /Charles
| Re: What will you be building with GEF? [message #3955 is a reply to message #3942] | Thu, 23 May 2002 16:52   |  |
 Some comments have been snipped either because I will agree to disagree on
 those points and I did not feel anything more could be contributed, or
 because company policy prevents me from further dicsussion (a point you
 hinted at).  If you feel the need to discuss them further, please do not
 hesitate to bring them back and I will see what I can do.
 "Mark Weyerhaeuser" <m.weyerhaeuser@hookipaa.com> wrote in message
 news:acjeca$nfo$1@rogue.oti.com...
 > hi charles!
 [...Snip...]
 issue
 > > isolated to XDE.
 case
 > of XDE is
 > tool as
 installed.
 Granted, the comparison with WSS AD was off.
 > > products.
 e.g.
 > on top of this on?
 You would not need to install XDE on top of Eclipse 1.0.  XDE includes _all_
 of Eclipse 1.0 either as part of the IBM WebSphere Studio Workbench (when
 installed standalone) or as part of IBM WebSphere Studio Application
 Developer.  It would be very easy to either point XDE to your previous
 Eclipse workspace, or to move your existing projects into the XDE workspace,
 especially if they are under source control.   You can also use any other
 Eclipse 1.0 plugins that you desire.
 [...Snip...]
| Re: What will you be building with GEF? [message #230103 is a reply to message #6938] | Wed, 31 January 2007 11:47  |  |
| Eclipse User  |  |  |  |  | Originally posted by: bgil-nospam.nospam.ca
 For tutorial have a look at http://eclipsewiki.editme.com/GefDescription
 "Scott Stanchfield" <scott-usenet@javadude.com> wrote in message
 news:ade717$7vl$1@rogue.oti.com...
 > "Eben Stewart" <estewart@us.ibm.com> wrote in message
 > news:ac399j$2c3$1@rogue.oti.com...
 >> > Code Generation views (VCE-like support)
 >> Please, please, please?
 >> This was always a good feature of VAJ, and would be very useful - esp if
 > it
 >> also supported SWT as well as AWT/Swing.
 >> -- Eben Stewart
 > I'm working on one with GEF right now... Going very slowly, but it looks
 > like GEF provides about 40% of the stuff I wanted to do in my visual
 > builder, so it seems to make sense to use it.
 > Going slowly (as I read the code to figure out what it's doing -- the
 > javadocs aren't helping much).
 > Perhaps, once I figure it all out, I'll write a tutorial.
 > -- Scott
 Current Time: Thu Oct 30 21:26:51 EDT 2025
 Powered by FUDForum . Page generated in 0.07653 seconds |
