Home » Archived » Orion (Archived) » unpacking the eclipse-orion-XXX-macosx.cocoa.x86_64.zip file
unpacking the eclipse-orion-XXX-macosx.cocoa.x86_64.zip file [message #1050692] Sat, 27 April 2013 11:48 Go to next message
When I unpack the .zip file with the macos "Archive Utility"
the orion executable is damaged. When I use the commandline
unzip command then it succeeds. I think that the command
line zip extracts the resourc forge correctly. I wonder
if this is a bug or if my mac has a problem....
Michael
Re: unpacking the eclipse-orion-XXX-macosx.cocoa.x86_64.zip file [message #1050725 is a reply to message #1050692] Sat, 27 April 2013 12:55 Go to previous messageGo to next message
I found a solution:
If I set "Allow Applications Downloaded form: Anywhere"
in "System Preferences"-->"Security & Privacy"-->General,
I can start the server...
Michael
> Michael
Re: unpacking the eclipse-orion-XXX-macosx.cocoa.x86_64.zip file [message #1052984 is a reply to message #1050725] Wed, 01 May 2013 13:28 Go to previous message
Ah yes, this is a standard Mac "feature". The same thing happens with the Eclipse platform, SDK, etc. Mac tries to protect you from using apps that don't come from their app store by claiming they are damaged.
http://support.apple.com/kb/ht5290
Previous Topic:ISecurePreferences storage
Next Topic:Making executable jar file from all orion bundles
Current Time: Thu Jul 24 22:59:04 EDT 2025
Powered by FUDForum. Page generated in 0.04545 seconds
