Home » Newcomers » Newcomers » unzipping eclipse ide for Java Developers
unzipping eclipse ide for Java Developers [message #1046986] Mon, 22 April 2013 12:34 Go to next message
I am trying to download and install "Eclipse IDE for Java Developers" and when I try to extract the file (both with winzip and winrar) i get the message that it Cannot create folder and that the file name is too long. When I specify where to put the file specifically it does not extract completely, instead puts the application icon in the folder, and then says that the software is not compatible with my system, and to use the appropriate one (32-bit or 64-bit). I have downloaded and tried both versions to no avail. I have all the JAva required software, but eclipse is not working. I have tried it with IDE EE and still does not work. Help please
Re: unzipping eclipse ide for Java Developers [message #1047087 is a reply to message #1046986] Mon, 22 April 2013 15:22 Go to previous messageGo to next message
You need to install eclipse higher up in your file system hierarchy. A suggestion would be to install it in c:\eclipse.
Re: unzipping eclipse ide for Java Developers [message #1050046 is a reply to message #1046986] Fri, 26 April 2013 12:07 Go to previous messageGo to next message
(1) Use 64 bit versions of both the Java and Eclipse, if your system is 64 bit.
(2) 7-Zip has always been able to unzip Eclipse for me, even when Windows could not.
Re: unzipping eclipse ide for Java Developers [message #1050048 is a reply to message #1046986] Fri, 26 April 2013 12:10 Go to previous message
(1) Use 64 bit versions of both the Java and Eclipse, if your system is 64 bit. Also be sure you get then 64 or 32 bit version of Java for your operating system.
Previous Topic:Search opens in java search, not file search.
Next Topic:How to convert OWL-S file to ecore
Current Time: Thu Jul 24 23:58:52 EDT 2025
Powered by FUDForum. Page generated in 0.09039 seconds
