References to files [message #1049714] |
Fri, 26 April 2013 03:24  |
I am looking for a solution to reference external files (like images). The solution with a String which is validated, the resource is not updated, if the image is removed.
I have some ideas:
1. I create a new ResourceServiceProvider with EMF-Model to add images to ResourceDescriptions. For each file extension I need another EClass and additional ResourceServiceProvider. This way I can make real links in my grammar (Or is there a knwon Problem with STRING references).
2. A custom Builder "changes" the model files to trigger Xtext Builder. The files to touch can be calculated by evaluating user data of IEObjectDescriptions.
Thanks for comments,
Benjamin
Re: References to files [message #1051326 is a reply to message #1049714] |
Sun, 28 April 2013 12:04  |
Hi Benjamin,
the approach #1 is the one that I'd go forward with. The emf resource
impl could be straight forward and just ignore the file contents. If you
register a service provider for that one, everything else should work
like a charm. There are no known problems with references that use
STRING as underlying representation.
Sebastian
Looking for professional support for Xtext, Xtend or Eclipse Modeling?
Am 26.04.13 09:24, schrieb Benjamin Schwertfeger:
> Hello,
> I have some ideas:
> Benjamin
FUDForum. Page generated in 0.07880 seconds
