Home » Modeling » TMF (Xtext) » data binding beteen xtext and swt(data binding between xtext and swt)
data binding beteen xtext and swt [message #1048338] Wed, 24 April 2013 06:23 Go to next message
I am building a plugin for eclipse that provides a graphical editor.
In this editor, I want to bind some data between an XText model and the SWT widgets. How can I do this while updating the XTextDocument automatically?
Are there existing tools that help with this, or do code generation for this?
By now, I have created with window builder plugin JFace Automatic Databinding with controller class.
it seem that whenever I change the text field which the xtext data model (JString) is bind to, the binding put null/new instance of JString into the JString instance.
so the document isn't familiar with the new JString instance and it is not updated with the new data.
Re: data binding beteen xtext and swt [message #1049682 is a reply to message #1048338] Fri, 26 April 2013 02:36 Go to previous messageGo to next message
Hi Dana,
the emf model of xtext should only be accessed in a IUnitOfWork while inside the XtextDocument.modify or XtextDocument.readOnly. For Databinding the binding should be against the URI of the EObject and read and write inside the unitOfWork. As far as I know, there is no implementation for the eclipse databinding and xtext yet. Implementation could be similar to those of EMFEditProperties with XtextDocument instead of editing domain.
Benjamin
Re: data binding beteen xtext and swt [message #1052942 is a reply to message #1048338] Wed, 01 May 2013 09:55 Go to previous message
I extended AbstractObservableValue to work with simple xtext models as string boolean and numbers. which help me to bind between swt model and my xtext models
Previous Topic:Make an executable of my DSL once its complete?
Next Topic:UI model validation
Current Time: Fri Jul 25 17:32:12 EDT 2025
Powered by FUDForum. Page generated in 0.25243 seconds
