Home » Modeling » TMF (Xtext) » Help needed in Xtext
Help needed in Xtext [message #1049351] Thu, 25 April 2013 14:44 Go to next message
Hi All,
I need to implement something like below:
// a simple structure, there can be any no, similar to C
typedef struct
int a;
int b;
}emp;
//any no of instances of the structure
emp emp1;
emp emp2;
//assigning values to the instances
emp1.a=2;
emp2.b=3;
//function definition
void func(emp emp1)
x=1;
y=emp1.a;
The grammar that i wrote is:
Model:
((struct+=Struct) | (instance+=Instance) | (function+=Function))*
//typedef struct
//int a;
//int b;
//}emp;
Struct:
'typedef struct {'
(params+=Parameter)+
'}'name=ID ';'
Parameter:
'int' name=ID;
//emp emp1;
Instance:
struct=[Struct] name=ID';'
//i need to put something like emp1.a = 3; , which can be anywhere after the emp1 declaration, similar to the concept that variable can be used only after its defined. So how do i include it in grammar. Is it possible to do without any validator, by creating some grammar rule? How do i judge where to put in the rule as weel, as this statement can be basically anywhere afterwards
//Also for creating a variable such as emp1.a, i basically need to refer
name=[Instance]'.'param=[Parameter] '=' value=INT, but it gives some error in the editor, and doesnt consider the Parameter . Is it possible to refer it this way, or any other way
Function:
('void')? name=ID '(' ((struct+=[Struct] structVarName+=ID) (',' struct+=[Struct] structVarName+=ID)*)? ')' '{'
(assignments+=Assignment)+
Assignment:
name=ID '=' value=INT';'
Can someone please suggest?
Rohit
Re: Help needed in Xtext [message #1049371 is a reply to message #1049351] Thu, 25 April 2013 15:19 Go to previous messageGo to next message
stil the same answer as before
Instance:
struct=[Parameter|FQN] name=ID';'
FQN: ID ("." ID);
Re: Help needed in Xtext [message #1049381 is a reply to message #1049371] Thu, 25 April 2013 15:35 Go to previous messageGo to next message
Here is an extended sample
Model:
((struct+=Struct) | (instance+=Instance) | (ass+=Assignment))*
Struct:
'typedef struct {'
'}'name=ID ';'
Parameter:
'int' name=ID;
//emp emp1;
Instance:
Assignment:
inst=[Instance] "."param=[Parameter]'=' value=INT';'
class MyDslScopeProvider extends org.eclipse.xtext.scoping.impl.AbstractDeclarativeScopeProvider {
	def IScope scope_Assignment_param(Assignment a, EReference ref) {
		 Scopes::scopeFor(a.inst.struct.params)
~Christian
Re: Help needed in Xtext [message #1049670 is a reply to message #1049381] Fri, 26 April 2013 02:16 Go to previous messageGo to next message
Hi Christian,
Thanks for the reply
If i use this, the grammar doesn't give any error, but once i check in the UI editor(the runtime eclipse environment), the param=[Parameter], thing doesn't work, it says couldn't resolve reference to Parameter, even though the parameter is defined
Assignment:
On the other hand, if i use
Re: Help needed in Xtext [message #1049671 is a reply to message #1049670] Fri, 26 April 2013 02:19 Go to previous messageGo to next message
Sorry it worked perfect with your example . sure you did not forget
to use my complete grammar and to adopt the scope provider.
Especially the scope provider is keen on naming.
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext at itemis dot de
Re: Help needed in Xtext [message #1049697 is a reply to message #1049671] Fri, 26 April 2013 03:03 Go to previous messageGo to next message
Thanks again,
naming of the IScope was the issue, now it works as expected, didn't realize that the name of the IScope could be the issue i used some random name earlier.
Thanks a lot Smile
Re: Help needed in Xtext [message #1049703 is a reply to message #1049697] Fri, 26 April 2013 03:09 Go to previous messageGo to next message
One more thing something like below works, however it shouldn't since struct is defined after but it is used before, i know i can write a validator, is there any other way directly from the grammar?
emp emp1;
emp1.X =4;
typedef struct {
int X;
int Y;
int Z;
} emp;
Re: Help needed in Xtext [message #1049708 is a reply to message #1049703] Fri, 26 April 2013 03:16 Go to previous message
you have to write a validator for that yourself
Previous Topic:XText 2.4.1 DomainmodelJvmModelInferrer
Next Topic:XText ValueConverter And Generated Editor Issue
Current Time: Thu Jul 24 23:08:11 EDT 2025
Powered by FUDForum. Page generated in 0.31621 seconds
