Home » Newcomers » Newcomers » Is there context-sensitive help for Java included?
Is there context-sensitive help for Java included? [message #104748] Mon, 26 September 2005 02:23 Go to next message
Originally posted by: rcgraulich.gmx.de
I'm using Eclipse now for a while. So I like it! But now I've to teach Java
to some students and we're missing a context senitive help.
Let's have an example': Creating the HelloWorld Applet we use the paint()
methode. How can we get the JavaDoc Help to that methode? Usually we leave
Eclipse to load the Java Online Help/Documentation in any browser, which
isn't that much comfortable.
Any Idea?
TIA
Rolf
Re: Is there context-sensitive help for Java included? [message #104902 is a reply to message #104748] Mon, 26 September 2005 13:09 Go to previous messageGo to next message
Originally posted by: manahan.NOSPAM.ca.ibm.com
Rolf Graulich wrote:
> Any Idea?
> TIA
> Rolf
I found Shift-F2 works. Not sure if you have to set any preferences but
for me it worked out of the box.
Peter
Re: Is there context-sensitive help for Java included? [message #104926 is a reply to message #104748] Mon, 26 September 2005 15:21 Go to previous messageGo to next message
Originally posted by: myersj.gmail.com
If you have the source available for the code you're interested in, the
javadoc should show up when you hover your mouse over a java element.
Alternatively you can show the Javadoc view by going to Window->Show
View->Javadoc. The Javadoc view will show the documentation for the
selected java element.
Hope this helps,
- Jeff
> Any Idea?
> TIA
> Rolf
Re: Is there context-sensitive help for Java included? [message #105036 is a reply to message #104926] Mon, 26 September 2005 16:31 Go to previous messageGo to next message
Doing this, i.e. hover over System.out it is displaying "java.lang.System"
This isn't much for someone just starting Java ;-)
Nice tipp, didn't know this. So i got the view @javadoc which is allmost
empty. All I can see clicking on i.e. "main(String[] args)" is an entry
that displays "Parameters: args"
What else can I do? Anny Idea?
BTW: The Tipp of Peter Manahan by typing [shift]+[F2] didn't help either
So I strongly going to think that there is something wrong with my
Eclipse-settings
> Hope this helps,
> - Jeff
>> Hi,
>> Java to some students and we're missing a context senitive help.
>> leave Eclipse to load the Java Online Help/Documentation in any browser,
>> which isn't that much comfortable.
>> Any Idea?
>> TIA
>> Rolf
Re: Is there context-sensitive help for Java included? [message #105116 is a reply to message #105036] Mon, 26 September 2005 21:25 Go to previous messageGo to next message
It sounds like your Eclipse installation is pointing to a JRE
installation, not a Java SDK. Go to
Window->Preferences->Java->Installed JREs. Make sure the default one is
an SDK directory containing a src.zip, not a JRE directory.
- Jeff
Re: Is there context-sensitive help for Java included? [message #105345 is a reply to message #105116] Tue, 27 September 2005 13:26 Go to previous message
>> "java.lang.System" This isn't much for someone just starting Java ;-)
> - Jeff
that last tipp was verry helpfull! Now I understand that way of Java&Eclipse
more clearly;-)
Rolf
keep swinging
Previous Topic:Linking upper and lower panels
Next Topic:Testing - please ignore
Current Time: Tue Nov 11 22:04:37 EST 2025
Powered by FUDForum. Page generated in 0.07338 seconds
