Object Mapping not propagated from reused project [message #949001] |
Thu, 18 October 2012 11:35  |
We have a team of three testers, all of whom are set up with copies of the same projects. The base project is a set of reusable test cases. It has an AUT set up and working, and object mapping has been carried out on the AUT such that the project's test cases all work.
We are importing this library project into our own workspaces, and using it as a reusable project (basically a set of library test cases) inside our own test projects.
Unfortunately, we are finding that the test cases in the library project all fail with the error "Incomplete Object Mapping for AUT "<our_AUT>".
Our "main" projects are all set to use the same AUT as the library project, and the library project is set to be reusable.
We don't want to have to re-do all of our object mappings on three machines, with all the synchronisation issue that implies.
Is there a way to propagate the object mappings from the library project up into our "main" projects?
Re: Object Mapping not propagated from reused project [message #1696437 is a reply to message #949079] |
Tue, 26 May 2015 09:38  |
Hi Jeff,
as described by Achim and Alexandra this is still the expected behavior.
Achim Loerke wrote on Thu, 18 October 2012 13:06OM is not exported from a project. We would very much like to do it but every time we thought we had a way of doing it someone came up with a case which wouldn't work. But we are open to suggestions. Just keep in mind that the solution must work in every case, including somebody redefining an AUT or OMs, reusing names, mixing in different projects which overlapping AUTs etc.
Achim
FUDForum. Page generated in 0.05579 seconds
