Home » Eclipse Projects » Remote Application Platform (RAP) » Loader/ProgressBar
Loader/ProgressBar [message #102155] Tue, 12 August 2008 08:09 Go to next message
Hello!
I have implemented in my application some operations that take a while.
I'm wondering in an implementation of a kind of loader, a small dialog
with a kind of progressBar that will show the progress of the operation.
Thanks!
Re: Loader/ProgressBar [message #102234 is a reply to message #102155] Wed, 13 August 2008 03:55 Go to previous messageGo to next message
Originally posted by: rsternberg.innoopract.com
Hi George,
Have a look at the JFace ProgressMonitorDialog, it displays the progress
of a long-running operation. You have to wrap your operation in an
IRunnableWithProgress and pass it to the run method of the dialog.
HTH, Ralf
Re: Loader/ProgressBar [message #104913 is a reply to message #102234] Mon, 15 September 2008 11:08 Go to previous messageGo to next message
Hi, can you give me a little example.
I want to send a mail via RAP and while sending i want to display a
ProgressMonitorDialog.
Roland
Ralf Sternberg schrieb:
> Hi George,
> HTH, Ralf
Re: Loader/ProgressBar [message #104921 is a reply to message #104913] Mon, 15 September 2008 11:53 Go to previous messageGo to next message
take a look at the Jobs API [1].
Greets
Benny
[1] http://www.eclipse.org/articles/Article-Concurrency/jobs-api .html
> Roland
>> Hi George,
>>> dialog with a kind of progressBar that will show the progress of the
>>> operation.
>> progress of a long-running operation. You have to wrap your operation
>> in an IRunnableWithProgress and pass it to the run method of the dialog.
>> HTH, Ralf
Re: Loader/ProgressBar [message #104963 is a reply to message #104921] Tue, 16 September 2008 06:01 Go to previous messageGo to next message
Thanks.
But why I'm getting an NullPointerException???
public class Application implements IEntryPoint {
public int createUI() {
final Display display = new Display();
final Shell container = new Shell(display);
final MultiPartEmail email = new MultiPartEmail();
final EmailAttachment logFile = new EmailAttachment();
logFile.setPath("C:\\test.log");
logFile.setDisposition(EmailAttachment.ATTACHMENT);
logFile.setDescription("Log-File");
final Job job = new Job("Long Running Job") {
protected IStatus run(IProgressMonitor monitor) {
try {
email.setHostName("smtp.googlemail.com");
email.setSmtpPort(587);
email.setTLS(true);
email.addTo("foo@googlemail.com");
email.setFrom("foo@googlemail.com");
email.setSubject("test-mail");
email.setMsg("If you read this, your mail-configuration works fine!");
email.setAuthentication("foo", "foo");
email.attach(logFile);
email.send();
return Status.OK_STATUS;
} catch (EmailException e) {
e.printStackTrace();
job.schedule();
job.addJobChangeListener(new IJobChangeListener() {
public void aboutToRun(IJobChangeEvent event) {
System.out.println("aboutToRun");
public void awake(IJobChangeEvent event) {
System.out.println("awake");
public void done(IJobChangeEvent event) {
System.out.println("done");
public void running(IJobChangeEvent event) {
System.out.println("running");
public void scheduled(IJobChangeEvent event) {
System.out.println("scheduled");
public void sleeping(IJobChangeEvent event) {
System.out.println("sleeping");
container.open();
while (!container.isDisposed()) {
if (!display.readAndDispatch()) {
display.sleep();
return 0;
!ENTRY org.eclipse.rap.ui.workbench 4 2 2008-09-16 11:53:16.843
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.rap.ui.workbench".
!STACK 0
at
org.eclipse.ui.internal.progress.ProgressInfoItem.init(Progr essInfoItem.java:163)
at
org.eclipse.ui.internal.progress.ProgressManager$ProgressMan agerProvider.getInstance(ProgressManager.java:73)
at
org.eclipse.ui.internal.progress.ProgressManager.getInstance (ProgressManager.java:151)
at
org.eclipse.ui.internal.progress.JobManagerAdapter$3.run(Job ManagerAdapter.java:169)
at
org.eclipse.rwt.internal.lifecycle.UICallBackServiceHandler. runNonUIThreadWithFakeContext(UICallBackServiceHandler.java: 423)
at
org.eclipse.rwt.lifecycle.UICallBack.runNonUIThreadWithFakeC ontext(UICallBack.java:44)
at
org.eclipse.ui.internal.progress.JobManagerAdapter.findProgr essManager(JobManagerAdapter.java:167)
at
org.eclipse.ui.internal.progress.JobManagerAdapter.scheduled (JobManagerAdapter.java:148)
at
org.eclipse.core.internal.jobs.JobListeners$5.notify(JobList eners.java:49)
at
org.eclipse.core.internal.jobs.JobListeners.doNotify(JobList eners.java:96)
at
org.eclipse.core.internal.jobs.JobListeners.scheduled(JobLis teners.java:162)
at org.eclipse.core.internal.jobs.JobManager.schedule(JobManage r.java:976)
at
org.eclipse.core.internal.jobs.InternalJob.schedule(Internal Job.java:376)
at org.eclipse.core.runtime.jobs.Job.schedule(Job.java:435)
at test.Application.createUI(Application.java:55)
at
org.eclipse.rwt.internal.lifecycle.EntryPointManager.createU I(EntryPointManager.java:92)
at
org.eclipse.rwt.internal.lifecycle.RWTLifeCycle.createUI(RWT LifeCycle.java:228)
at
org.eclipse.rwt.internal.lifecycle.RWTLifeCycle$UIThreadCont roller.run(RWTLifeCycle.java:116)
aboutToRun
running
done
}Benjamin Muskalla schrieb:
> Greets
> Benny
Re: Loader/ProgressBar [message #105326 is a reply to message #104963] Tue, 16 September 2008 15:53 Go to previous message
Originally posted by: rherrmann.innoopract.com
Roland,
you are launching with org.eclipse.rap.ui.workbench but do not
actually start the workbench (PlatformUI#createAndRunWorkbench).
This might cause the NPE.
From looking at the code (while (!container.isDisposed())...), it
seems that you are using RWT standalone. In this case you would need
to provide an IProgressMonitor implementation and/or use one that
comes with JFace.
This article might give you some directions:
http://www.ibm.com/developerworks/library/os-ecgui2/
HTH
Rüdiger
> Thanks.
> try {
> email.setTLS(true);
> email.send();
> job.schedule();
> container.open();
> display.sleep();
> return 0;
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> aboutToRun
> running
> done
>> Hi,
>> Greets
>> Benny
Previous Topic:production RAP applications
Next Topic:Progress Monitoring
Current Time: Tue Sep 16 22:45:00 EDT 2025
Powered by FUDForum. Page generated in 0.04622 seconds
