Home » Modeling » GMF (Graphical Modeling Framework) » Error installing GMF Experimental
Error installing GMF Experimental [message #1048871] Wed, 24 April 2013 23:50 Go to next message
Hi I am trying to install the experimental SDK and I am getting the below error. Anyone faced this problem before? -
Cannot complete the install because of a conflicting dependency.
Software being installed: GMF Tooling Experimental SDK 1.2.1.201301191623 (org.eclipse.gmf.sdk.experimental.feature.group 1.2.1.201301191623)
Software currently installed: Graphical Modeling Framework (GMF) Runtime 1.6.2.201302191707 (org.eclipse.gmf.feature.group 1.6.2.201302191707)
Only one of the following can be installed at once:
org.eclipse.gmf.runtime.thirdparty_root 1.6.2.201302122140
org.eclipse.gmf.runtime.thirdparty_root 1.6.2.201302191707
org.eclipse.gmf.runtime.thirdparty_root 1.6.2.201212111909
Cannot satisfy dependency:
From: Graphical Modeling Framework (GMF) Runtime 1.6.2.201302191707 (org.eclipse.gmf.feature.group 1.6.2.201302191707)
To: org.eclipse.gmf.runtime.thirdparty.feature.group [1.6.2.201302191707]
From: Third-Party Components for GMF Runtime 1.6.2.201212111909 (org.eclipse.gmf.runtime.thirdparty.feature.group 1.6.2.201212111909)
To: org.eclipse.gmf.runtime.thirdparty_root [1.6.2.201212111909]
From: Third-Party Components for GMF Runtime 1.6.2.201302191707 (org.eclipse.gmf.runtime.thirdparty.feature.group 1.6.2.201302191707)
To: org.eclipse.gmf.runtime.thirdparty_root [1.6.2.201302191707]
From: GMF Tooling Experimental SDK 1.2.1.201301191623 (org.eclipse.gmf.sdk.experimental.feature.group 1.2.1.201301191623)
To: org.eclipse.gmf.runtime.thirdparty.feature.group [1.6.2.201212111909]
[Updated on: Wed, 24 April 2013 23:50] by Moderator
Re: Error installing GMF Experimental [message #1049147 is a reply to message #1048871] Thu, 25 April 2013 08:42 Go to previous message
what do you need from GMF Experimental? As far as I know this is a known issue.
Ralph
Previous Topic:How to use GMF code to draw diagram without cliking on the palatte?
Next Topic:Problems while integrating EMF and GMF
Current Time: Wed Jul 23 07:38:27 EDT 2025
Powered by FUDForum. Page generated in 0.06406 seconds
