Home » Newcomers » Newcomers » *SOLVED* SWT not contained in the Eclipse IDE for Java developers(The SWT tutorial (Create HelloWorld SWT application) does not go through.)
*SOLVED* SWT not contained in the Eclipse IDE for Java developers [message #1043293] Wed, 17 April 2013 10:16 Go to next message
I have installed Eclipse IDE for Java developers, Juno (4.2).
The welcome page had a tutorial on creating SWT Hello World! application.
The tutorial does not go through.
The reason is that the SWT package is not included in this distribution and it needs to be installed thru Help -->Install New Sofware where it appears in the Juno site under General purpose tools.
There are 4 SWT items there, and I installed the first three, leaving out SWT designer XWT support. (Probably the first two would have been enough.)
After that the tutorial went thru fine.
Smile
[Updated on: Mon, 22 April 2013 14:13] by Moderator
Re: "Install new software" does not work [message #1043369 is a reply to message #1043293] Wed, 17 April 2013 12:09 Go to previous messageGo to next message
Deleted
[Updated on: Mon, 22 April 2013 14:14] by Moderator
Re: "Install new software" does not work [message #1044330 is a reply to message #1043369] Thu, 18 April 2013 15:34 Go to previous messageGo to next message
Deleted
Re: *SOLVED* SWT not contained in the Eclipse IDE for Java developers [message #1048993 is a reply to message #1043293] Thu, 25 April 2013 04:03 Go to previous messageGo to next message
eclipse for java developers is is the option in the downloads right
Re: *SOLVED* SWT not contained in the Eclipse IDE for Java developers [message #1048995 is a reply to message #1048993] Thu, 25 April 2013 04:04 Go to previous message
first option
Previous Topic:Help with running JFrame
Next Topic:Using XREF with Toad Extension/postgres
Current Time: Thu Jul 24 23:19:41 EDT 2025
Powered by FUDForum. Page generated in 0.13583 seconds
