Home » Eclipse Projects » Eclipse Platform » Notification for XML Validation Builder
Notification for XML Validation Builder [message #1048706] Wed, 24 April 2013 17:24 Go to next message
Hey,
I added the xml validation to the build process of my project. This is the additional content of my .project file.
<buildCommand>
  <name>org.eclipse.wst.validation.validationbuilder</name>
  <arguments></arguments>
</buildCommand>
Now all xml files are validated properly. After this process has been completed, I would like to be notified. Can I register a listener, that notifies me if the process is done? Thank you!
Kon
[Updated on: Wed, 24 April 2013 17:26] by Moderator
Re: Notification for XML Validation Builder [message #1048907 is a reply to message #1048706] Thu, 25 April 2013 01:06 Go to previous messageGo to next message
Kon,
Best to ask on the Web Tools forum. I doubt there are listeners for
such specific details. What are you hoping to accomplish with such a
listener?
On 24/04/2013 11:24 PM, kon fri wrote:
> Hey,
> <buildCommand>
> </buildCommand>
> Kon
Re: Notification for XML Validation Builder [message #1048969 is a reply to message #1048706] Thu, 25 April 2013 03:18 Go to previous messageGo to next message
Hey Ed,
the xml validation process creates error markers if the file are not well formed nor valid (a schema file is present). I get this entire process with just four xml lines.
Afterwards I would like to know if this process went well by checking any presents of error markers. Basically not error markers make sure that the xml files are at least well formed and valid. On the next step, I can perform some semantical xml validation, e.g. if an element that is references by name is really present. If not, then I also create error markers.
I'm not sure if this use case can be implemented with a different approach.
Thank you.
Kon
Re: Notification for XML Validation Builder [message #1049808 is a reply to message #1048969] Fri, 26 April 2013 05:47 Go to previous messageGo to next message
Kon,
It's possible to listen to the workspace as a whole and check the deltas
for error markers being added or removed for the files of interest. But
it sounds more like what you do should be a builder... I think you
could set it up so your builder would happen after the XML validator has
done it's job; not sure how, but I'm pretty sure that's possible.
On 25/04/2013 9:18 AM, kon fri wrote:
> Hey Ed,
> approach.
> Thank you.
> Kon
Re: Notification for XML Validation Builder [message #1053551 is a reply to message #1049808] Mon, 06 May 2013 09:28 Go to previous message
Hey Ed,
thanks for your suggestion. I used http://eclipse.1072660.n5.nabble.com/Wait-for-build-to-complete-and-check-if-errors-td57716.html approach to execute my task after the build has been completed. More information about the build process can be found here http://www.eclipse.org/articles/Article-Builders/builders.html. Thank you.
Kon
Previous Topic:Mapping from editorContribution to menuContribution
Next Topic:Problem Updating Eclipse Java EE, Juno SR1
Current Time: Sun Jul 20 21:35:53 EDT 2025
Powered by FUDForum. Page generated in 0.07391 seconds
