Home » Modeling » EMF » [CDO] CDOIDUtil.read - Illegal type: OBJECT
[CDO] CDOIDUtil.read - Illegal type: OBJECT [message #1048365] Wed, 24 April 2013 07:07 Go to next message
I can't specify when it occurs and I can't provide a unit-test. After doing some modifactions, I finally add an item to a list (which does not contain the item, it's contained somewhere else).
After doing the commit I get the exception:
Caused by: org.eclipse.emf.cdo.common.util.TransportException: java.io.IOException: Illegal type: OBJECT
	at org.eclipse.emf.cdo.internal.net4j.protocol.CDOClientProtocol.send(CDOClientProtocol.java:526)
	at org.eclipse.emf.cdo.internal.net4j.protocol.CDOClientProtocol.commitTransaction(CDOClientProtocol.java:393)
	at org.eclipse.emf.internal.cdo.transaction.CDOSingleTransactionStrategyImpl.commit(CDOSingleTransactionStrategyImpl.java:71)
	at org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl.commit(CDOTransactionImpl.java:1178)
	... 15 more
Caused by: java.io.IOException: Illegal type: OBJECT
	at org.eclipse.emf.cdo.common.id.CDOIDUtil.read(CDOIDUtil.java:476)
	at org.eclipse.emf.cdo.spi.common.protocol.CDODataInputImpl.readCDOID(CDODataInputImpl.java:386)
	at org.eclipse.emf.cdo.spi.common.protocol.CDODataInputImpl.readCDOLockState(CDODataInputImpl.java:346)
	at org.eclipse.emf.cdo.internal.net4j.protocol.CommitTransactionRequest.confirmingNewLockStates(CommitTransactionRequest.java:363)
	at org.eclipse.emf.cdo.internal.net4j.protocol.CommitTransactionRequest.confirming(CommitTransactionRequest.java:292)
	at org.eclipse.emf.cdo.internal.net4j.protocol.CommitTransactionRequest.confirming(CommitTransactionRequest.java:1)
	at org.eclipse.emf.cdo.internal.net4j.protocol.CDOClientRequestWithMonitoring.confirming(CDOClientRequestWithMonitoring.java:117)
	at org.eclipse.net4j.signal.RequestWithMonitoring.confirming(RequestWithMonitoring.java:171)
	at org.eclipse.net4j.signal.RequestWithConfirmation.doExtendedInput(RequestWithConfirmation.java:125)
	at org.eclipse.net4j.signal.Signal.doInput(Signal.java:328)
	at org.eclipse.net4j.signal.RequestWithConfirmation.doExecute(RequestWithConfirmation.java:105)
	at org.eclipse.net4j.signal.RequestWithMonitoring.doExecute(RequestWithMonitoring.java:235)
	at org.eclipse.net4j.signal.SignalActor.execute(SignalActor.java:53)
	at org.eclipse.net4j.signal.Signal.runSync(Signal.java:253)
	at org.eclipse.net4j.signal.SignalProtocol.startSignal(SignalProtocol.java:431)
	at org.eclipse.net4j.signal.RequestWithConfirmation.doSend(RequestWithConfirmation.java:89)
	at org.eclipse.net4j.signal.RequestWithConfirmation.send(RequestWithConfirmation.java:75)
	at org.eclipse.net4j.signal.RequestWithMonitoring.send(RequestWithMonitoring.java:110)
	at org.eclipse.emf.cdo.internal.net4j.protocol.CDOClientProtocol.send(CDOClientProtocol.java:518)
	... 18 more
I am using the current trunk of CDO and everything is running in one Java instance.
If I remove the 'add' to the list, there is no exception.
Can somebody give me a clue, what's wrong or how I can debug the problem?
Per Sterner
Re: [CDO] CDOIDUtil.read - Illegal type: OBJECT [message #1048396 is a reply to message #1048365] Wed, 24 April 2013 08:05 Go to previous messageGo to next message
Hi Per,
Are you sure that you're using the same CDO version on both clients and server?
Cheers
/Eike
http://www.esc-net.de
Am 24.04.2013 13:07, schrieb Per Sterner:
> at
> ... 15 more
> at
> at
> ... 18 more
> Regards,
> Per Sterner
Re: [CDO] CDOIDUtil.read - Illegal type: OBJECT [message #1048471 is a reply to message #1048396] Wed, 24 April 2013 10:11 Go to previous messageGo to next message
Yes, I am really running in one Java-VM (the current CDO and net4j plugins from trunk are in my workspace). I have debugged a lot and it appears, that:
0. transaction.commit(); // I commit my changes
1. CDODataOutputImpl.writeCDOLockState is called and the lockedObject type is CDOID. It's instance is TransactionCommitContext$DeltaLockWrapper$ForID.
2. CDOUtil.write is called and id.getType(); return OBJECT as type and ordinal is 1
[...] Later on:
3. CommitTransactionRequest.confirmingNewLockStates is called
4. readInt() returns 1
5. in.readCDOLockState() is called
6. CDOIDUtil.read is called. ordinal is 1
6. type is OBJECT and causes the exception
[Updated on: Wed, 24 April 2013 10:13] by Moderator
Re: [CDO] CDOIDUtil.read - Illegal type: OBJECT [message #1048474 is a reply to message #1048471] Wed, 24 April 2013 10:20 Go to previous messageGo to next message
You should check your run configuration as well, it may have mixed up installed plugins and workspace plugins.
Per Sterner wrote on Wed, 24 April 2013 16:11
[...] Later on:
Re: [CDO] CDOIDUtil.read - Illegal type: OBJECT [message #1048481 is a reply to message #1048474] Wed, 24 April 2013 10:30 Go to previous messageGo to next message
Yes, I looked with 'ss'. All bundles are only runing without a specific date-qualifier.
(I will try it against the current updatesite-dropin)
ss net4j
Framework is launched.
id	State       Bundle
43	ACTIVE      org.eclipse.net4j.db.db2_4.1.0.qualifier
55	ACTIVE      org.eclipse.net4j.http.common_4.0.200.qualifier
65	ACTIVE      org.eclipse.net4j.db.mysql_4.2.0.qualifier
76	ACTIVE      org.eclipse.emf.cdo.net4j_4.1.100.qualifier
95	ACTIVE      org.eclipse.net4j.db.postgresql_4.2.0.qualifier
119	ACTIVE      org.eclipse.net4j_4.2.0.qualifier
128	ACTIVE      org.eclipse.net4j.jvm_4.1.100.qualifier
147	ACTIVE      org.eclipse.net4j.db.h2_4.2.0.qualifier
150	ACTIVE      org.eclipse.net4j.tcp_4.1.100.qualifier
209	ACTIVE      org.eclipse.net4j.http.server_4.0.200.qualifier
226	ACTIVE      org.eclipse.emf.cdo.server.net4j_4.1.0.qualifier
238	ACTIVE      org.eclipse.net4j.defs_4.0.100.qualifier
249	ACTIVE      org.eclipse.net4j.util.defs_4.1.0.qualifier
296	ACTIVE      org.eclipse.net4j.db.derby_4.1.0.qualifier
299	ACTIVE      org.eclipse.net4j.util_3.3.0.qualifier
309	ACTIVE      org.eclipse.net4j.http_4.0.200.qualifier
310	ACTIVE      org.eclipse.net4j.db_4.2.0.qualifier
osgi> ss emf.cdo
id	State       Bundle
2	ACTIVE      org.eclipse.emf.cdo.server.admin_4.1.100.qualifier
16	ACTIVE      org.eclipse.emf.cdo.security_4.2.0.qualifier
42	ACTIVE      org.eclipse.emf.cdo.defs_4.0.100.qualifier
48	ACTIVE      org.eclipse.emf.cdo.edit_4.2.0.qualifier
69	ACTIVE      org.eclipse.emf.cdo.common.db_3.0.300.qualifier
88	ACTIVE      org.eclipse.emf.cdo.server.ocl_4.1.0.qualifier
109	ACTIVE      org.eclipse.emf.cdo.transfer.repository_4.2.0.qualifier
114	ACTIVE      org.eclipse.emf.cdo.admin_4.1.100.qualifier
116	ACTIVE      org.eclipse.emf.cdo.common_4.2.0.qualifier
118	ACTIVE      org.eclipse.emf.cdo.server.db_4.2.0.qualifier
126	ACTIVE      org.eclipse.emf.cdo.workspace_4.1.100.qualifier
154	ACTIVE      org.eclipse.emf.cdo.security.edit_4.2.0.qualifier
172	ACTIVE      org.eclipse.emf.cdo.workspace.efs_4.0.100.qualifier
174	ACTIVE      org.eclipse.emf.cdo_4.2.0.qualifier
197	ACTIVE      org.eclipse.emf.cdo.transfer_4.2.0.qualifier
233	ACTIVE      org.eclipse.emf.cdo.transfer.workspace_4.2.0.qualifier
288	ACTIVE      org.eclipse.emf.cdo.location_4.0.200.qualifier
306	ACTIVE      org.eclipse.emf.cdo.server_4.2.0.qualifier
[Updated on: Wed, 24 April 2013 10:54] by Moderator
Re: [CDO] CDOIDUtil.read - Illegal type: OBJECT [message #1048543 is a reply to message #1048471] Wed, 24 April 2013 12:10 Go to previous messageGo to next message
Am 24.04.2013 16:11, schrieb Per Sterner:
> Yes, I am really running in one Java-VM. I have debugged a lot and it appears, that:
I've indeed changed something (a lot) about the IDs:
I suggest that you submit a bugzilla and after the JAX conference I'll look at it. Please attach all the infos you've
given here and that may help to reproduce the problem in a test case.
Cheers
/Eike
> [...] Later on:
Re: [CDO] CDOIDUtil.read - Illegal type: OBJECT [message #1048544 is a reply to message #1048543] Wed, 24 April 2013 12:11 Go to previous messageGo to next message
Am 24.04.2013 18:10, schrieb Eike Stepper:
400892: Intern all CDOIDs
https://bugs.eclipse.org/bugs/show_bug.cgi?id=400892
Re: [CDO] CDOIDUtil.read - Illegal type: OBJECT [message #1049096 is a reply to message #1048544] Thu, 25 April 2013 07:01 Go to previous messageGo to next message
I noticed that the Legacy Mode is now the preferred option? (http://wiki.eclipse.org/CDO_Legacy_Mode)
I managed to test against 'emf-cdo-I20130418-0209-Site'. (I had some problems because of EMF v2.7 and the 'MinimalEStoreEObjectImpl' retrofit bundle. My Model-Bundle couldn't resolve the class 'MinimalEStoreEObjectImpl')
After adjusting my old genmodel file to use 'EObject' it works with the retrofit bundle Smile
Finally, the exception occurs..
Re: [CDO] CDOIDUtil.read - Illegal type: OBJECT [message #1051718 is a reply to message #1049096] Mon, 29 April 2013 02:31 Go to previous messageGo to next message
Am 25.04.2013 13:01, schrieb Per Sterner:
Hmm, I wouldn't say so. Now there is no explicit legacy *mode* anymore, or you could say it's always on. But that
doesn't mean that all objects should now be legacy objects. It's just that they're always supported and that there's no
way to exclude them by configuration of the CDOView.
If you have the chance to regenerate your model for CDO I strongly recommend to do it!
Similar problems have been reported already and we think that bugs in PDE cause them. At runtime all seems okay with our
retrofit fragment. Does it make a difference for you whether you deploy the retrofit fragment in binary form to the
target platform or in source form to your workspace?
> After adjusting my old genmodel file to use 'EObject' it works with the retrofit bundle :)
Well, in that case the retrofit fragment is not needed at all because your objects are legacy objects (with all their
disadvantages).
Cheers
/Eike
Re: [CDO] CDOIDUtil.read - Illegal type: OBJECT [message #1051954 is a reply to message #1051718] Mon, 29 April 2013 08:22 Go to previous messageGo to next message
Okay, I adjusted my genmodel.
I just tried it and it doesn't work for me in any configuration.
I created some testbundles (not related to anything) and there the same problem occurs. I looked into the section "Plug-In Dependencies" and the fragment doesn't appear there. But if I choose "system.bundle" as host-bundle it appears in the "Plug-In Dependencies" section and it works. But this doesn't really help Confused
disadvantages).
My workaround for now is to manually add the MinimalEStoreEObjectImpl class to the org.eclipse.emf.cdo, so it's directly visible. Otherwise my model bundle isn't compiled.
Re: [CDO] CDOIDUtil.read - Illegal type: OBJECT [message #1051957 is a reply to message #1048543] Mon, 29 April 2013 08:27 Go to previous messageGo to next message
Bugzilla entry: https://bugs.eclipse.org/bugs/show_bug.cgi?id=406531
Re: [CDO] CDOIDUtil.read - Illegal type: OBJECT [message #1052531 is a reply to message #1051954] Tue, 30 April 2013 03:52 Go to previous messageGo to next message
Am 29.04.2013 14:22, schrieb Per Sterner:
> appears in the "Plug-In Dependencies" section and it works. But this doesn't really help :?
> disadvantages).
I've now explained the problem and possible fixes in https://bugs.eclipse.org/bugs/show_bug.cgi?id=400388#c10
Cheers
/Eike
Re: [CDO] CDOIDUtil.read - Illegal type: OBJECT [message #1052594 is a reply to message #1052531] Tue, 30 April 2013 05:23 Go to previous messageGo to next message
Thanks for eclipse-pde-fragment bug/feature/info Sad (I try to use EMF 2.9)
Re: [CDO] CDOIDUtil.read - Illegal type: OBJECT [message #1052604 is a reply to message #1052594] Tue, 30 April 2013 05:38 Go to previous messageGo to next message
Am 30.04.2013 11:23, schrieb Per Sterner:
> Thanks for eclipse-pde-fragment bug/feature/info :( (I try to use EMF 2.9)
Excellent! Your feedback about that is much appreciated here or on the bugzilla.
BTW. Ed is planning to blog about this topic and ask for feedback (probably) on Thursday.
Cheers
/Eike
Re: [CDO] CDOIDUtil.read - Illegal type: OBJECT [message #1052605 is a reply to message #1052604] Tue, 30 April 2013 05:39 Go to previous message
Am 30.04.2013 11:38, schrieb Eike Stepper:
If you plan to report here I suggest to open a new thread with a catchier title ;-)
Cheers
/Eike
Previous Topic:e4mf
Next Topic:Create EMF project using mdl file
Current Time: Thu Jul 24 18:51:14 EDT 2025
Powered by FUDForum. Page generated in 0.07343 seconds
