Search dialog opens in java search, not file search. [message #1048274] |
Wed, 24 April 2013 04:42  |
There is one behaviour of Eclipse that is annoying. When I press Ctrl-H, it opens the search dialog, but it also switches to the "Java Search" tab. As a result it happens regularily that I search for some text, and I don't find it because it did a "java search" instead.
Most of the time, I do a text search. So I would like ctrl-H to open the search dialog in file search tabl, or in the same tab as it opened last time.
The action for "ctrl-H" is "Open search dialog". Is there a good reason to assume java search is what is wanted?
Is there a setting that can disable this behaviour? Or change the default tab to file search?
For time being, I customise the search dialog to remove the java search tab. But I also need to do a java search sometimes.
Your comments are welcome.
FUDForum. Page generated in 0.04379 seconds
