can't open design view [message #990969] |
Sat, 15 December 2012 13:36  |
i am new to windows builder
i am using juno 4.2
i have made new jframe but when i click on design view
i am having this
Internal Error
WindowBuilder encountered unexpected internal error.
This could be caused by a WindowBuilder bug or by a misconfiguration issue, conflict, partial update, etc.
org.eclipse.wb.internal.core.utils.check.AssertionFailedException: Can not find description for toolkit: org.eclipse.wb.swing
Stack trace:
at org.eclipse.wb.internal.core.utils.check.Assert.fail(Assert.java:225)
at org.eclipse.wb.internal.core.utils.check.Assert.isNotNull(Assert.java:174)
at org.eclipse.wb.internal.core.model.description.helpers.DescriptionHelper.getToolkit(DescriptionHelper.java:515)
at org.eclipse.wb.internal.core.model.description.helpers.DescriptionHelper.getResourceInfo(DescriptionHelper.java:402)
at org.eclipse.wb.internal.core.model.description.helpers.DescriptionHelper.getResourceInfo(DescriptionHelper.java:338)
at org.eclipse.wb.internal.core.model.description.helpers.DescriptionHelper.getResourceInfo(DescriptionHelper.java:425)
at org.eclipse.wb.internal.core.model.description.helpers.DescriptionHelper.getResourceInfo00(DescriptionHelper.java:301)
at org.eclipse.wb.internal.core.model.description.helpers.DescriptionHelper.getResourceInfo0(DescriptionHelper.java:278)
at org.eclipse.wb.internal.core.model.description.helpers.DescriptionHelper.getResourceInfo(DescriptionHelper.java:232)
at org.eclipse.wb.internal.core.model.description.helpers.DescriptionHelper.getComponentDescriptionResource(DescriptionHelper.java:207)
at org.eclipse.wb.internal.core.model.description.helpers.DescriptionHelper.addDescriptionResources(DescriptionHelper.java:68)
at org.eclipse.wb.internal.core.model.description.helpers.ComponentDescriptionHelper.getDescription0(ComponentDescriptionHelper.java:364)
at org.eclipse.wb.internal.core.model.description.helpers.ComponentDescriptionHelper.getDescription0(ComponentDescriptionHelper.java:289)
at org.eclipse.wb.internal.core.model.description.helpers.ComponentDescriptionHelper.getDescription(ComponentDescriptionHelper.java:258)
at org.eclipse.wb.internal.core.model.JavaInfoUtils.createJavaInfo(JavaInfoUtils.java:386)
at org.eclipse.wb.internal.swing.parser.ParseFactory.getRootContext(ParseFactory.java:128)
at org.eclipse.wb.internal.core.parser.JavaInfoParser.prepareParseContext(JavaInfoParser.java:1182)
at org.eclipse.wb.internal.core.parser.JavaInfoParser.parse(JavaInfoParser.java:242)
at org.eclipse.wb.internal.core.parser.JavaInfoParser.access$9(JavaInfoParser.java:238)
at org.eclipse.wb.internal.core.parser.JavaInfoParser$1.runObject(JavaInfoParser.java:153)
at org.eclipse.wb.internal.core.parser.JavaInfoParser$1.runObject(JavaInfoParser.java:1)
at org.eclipse.wb.internal.core.utils.execution.ExecutionUtils.runDesignTime(ExecutionUtils.java:159)
at org.eclipse.wb.internal.core.parser.JavaInfoParser.parse(JavaInfoParser.java:151)
at org.eclipse.wb.internal.core.editor.DesignPage.internal_refreshGEF(DesignPage.java:534)
at org.eclipse.wb.internal.core.editor.DesignPage.access$9(DesignPage.java:522)
at org.eclipse.wb.internal.core.editor.DesignPage$8$1.run(DesignPage.java:449)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:180)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:150)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4687)
at org.eclipse.wb.internal.core.editor.DesignPage$8.run(DesignPage.java:446)
at org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:464)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:372)
at org.eclipse.jface.dialogs.ProgressMonitorDialog.run(ProgressMonitorDialog.java:507)
at org.eclipse.wb.internal.core.editor.DesignPage.internal_refreshGEF_withProgress(DesignPage.java:465)
at org.eclipse.wb.internal.core.editor.DesignPage.internal_refreshGEF(DesignPage.java:415)
at org.eclipse.wb.internal.core.editor.UndoManager.refreshDesignerEditor(UndoManager.java:381)
at org.eclipse.wb.internal.core.editor.DesignPage.refreshGEF(DesignPage.java:392)
at org.eclipse.wb.internal.core.editor.actions.RefreshAction.run(RefreshAction.java:46)
at org.eclipse.wb.internal.core.editor.actions.DesignPageAction.run(DesignPageAction.java:34)
at org.eclipse.wb.internal.core.editor.errors.JavaExceptionComposite.doRefresh(JavaExceptionComposite.java:87)
at org.eclipse.wb.internal.core.editor.errors.ExceptionComposite$3.widgetSelected(ExceptionComposite.java:129)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:248)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4169)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3758)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1029)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:923)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:588)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:543)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
Full context stack trace:
FUDForum. Page generated in 0.07406 seconds
