Home » Eclipse Projects » EclipseLink » One to One Relationship With Shared PK not Working at Execution time(JPA, One To One, MySql)
One to One Relationship With Shared PK not Working at Execution time [message #1046723] Mon, 22 April 2013 05:23 Go to next message
Im using EclipseLink(JPA 2.0) with MySql and I'm having a problem with something in the model. I have 2 entities: Delincuente, PerfilFisico. They share the Delincuente's Pk.
The DB is working correctly but when i insert a Delincuente and then the Perfil Fisico, i tried to show the PerfilFisico of that Delincuente (Using Delincuente.PerfilFisico.), it was just empty. I checked the tables at the DB and everything was ok.
If i run the system again (I'm developing in Netbeans 7.2) and i consult the Delincuente that i just registered on the DB, it shows all the fields and everything is perfect!!
There is the code:
Delincuente.java
@OneToOne(cascade = CascadeType.ALL, mappedBy = "delincuente")
private PerfilFisico perfilFisico;
PerfilFisico.java
@JoinColumn(name = "PK_IdDelincuente", referencedColumnName = "PK_Identificacion", insertable = false, updatable = false)
@OneToOne(optional = false)
private Delincuente delincuente;
What is wrong, i've been reading for days and i can't figure out which the problem is. Any tips?
As i said it works, but when you are running it and you register a new Delincuente, you have to re-run the System to succesfully complete the consult and see the PerfilFisico
Re: One to One Relationship With Shared PK not Working at Execution time [message #1047051 is a reply to message #1046723] Mon, 22 April 2013 14:12 Go to previous messageGo to next message
This is asked on http://stackoverflow.com/questions/16143405/one-to-one-relationship-with-shared-not-working-at-execution-time as well.
The problem is likely due to not maintaining both sides of the bidirectional relationship. When setting the PerfilFisico.delincuente relationship, the application must also set the Delincuente.perfilFisico backpointer to keep the entities in synch with each other and the database. Not doing so runs the risk of having the cached entities out of synch with what is in the database - depending on which side is set, the database might not be updated at all.
Caching examples are provided here http://wiki.eclipse.org/EclipseLink/Examples/JPA/Caching but it is usually more performant to maintain relationships, or just not map the back pointer and query for it when needed rather than to force a refresh or invalidate the entity in the cache.
Best Regards,
Chris
Re: One to One Relationship With Shared PK not Working at Execution time [message #1047501 is a reply to message #1047051] Tue, 23 April 2013 05:44 Go to previous message
Thank you!!
I just fixed it and u were right!
I wasnt mapping or doing the bidirectional assign of the entities.
Previous Topic:EclipseLink composite persistence unit class declaration
Next Topic:Query Cache in 2.4.1 Help
Current Time: Sat Jul 26 23:33:28 EDT 2025
Powered by FUDForum. Page generated in 0.05419 seconds
