Home » Modeling » Papyrus » OCL constraints on stereotypes
OCL constraints on stereotypes [message #1046896] Mon, 22 April 2013 10:08 Go to next message
Hi everyone,
I'm using Papyrus on Eclipse Juno and I have definied an OCL constraint on a stereoptype. Unfortunately, Papyrus doesn't seem to check this kind of constraints. I also tried on Eclipse Kelpler.
What can I do in order to check the OCL constraints that I have defined in a profile ?
Any help would be much appreciate.
Thanks.
Re: OCL constraints on stereotypes [message #1046925 is a reply to message #1046896] Mon, 22 April 2013 10:53 Go to previous messageGo to next message
Hi Vincent,
It's currently work in progress in Kepler. Most of the features should work on the latest nightly builds (Define constraints in the profile, validate models on which the profile is applied). You need the latest Papyrus and OCL builds.
Camille
Re: OCL constraints on stereotypes [message #1046949 is a reply to message #1046925] Mon, 22 April 2013 11:33 Go to previous messageGo to next message
Thanks for your answer.
So I downloaded the latest nightybuild of Papyrus from :
http://download.eclipse.org/modeling/mdt/papyrus/updates/nightly/kepler
Then I have tried to validate a very simple test. I got this exception :
Error	An exception occurred while delegating evaluation of the 'Constraint1' invariant on 'Test 0 -> <<test>> <Class> Class1': null	Test 0 -> <<test>> <Class> Class1	null	EMF Problem
Did I do something wrong or is this due to the nightybuild ?
Re: OCL constraints on stereotypes [message #1046982 is a reply to message #1046949] Mon, 22 April 2013 12:30 Go to previous messageGo to next message
Do you have a more precise message? e.g. the message from the root exception? (An OCL exception, probably)
What did you write on your OCL constraint?
Camille
Re: OCL constraints on stereotypes [message #1047027 is a reply to message #1046949] Mon, 22 April 2013 13:37 Go to previous messageGo to next message
Camille wrote to use the latest OCL and Papyrus. Your message suggests
that you used only Papyrus nightly.
You should also use the latest Xtext ... all of which are available from
http://download.eclipse.org/releases/staging.
Ed Willink
Re: OCL constraints on stereotypes [message #1047437 is a reply to message #1046896] Tue, 23 April 2013 03:48 Go to previous messageGo to next message
The problem is resolved. You were right, I forgot to update OCL to the latest nightlybuild...
Thank you both of you.
Re: OCL constraints on stereotypes [message #1047725 is a reply to message #1046982] Tue, 23 April 2013 11:09 Go to previous messageGo to next message
I installed Papyrus latest nightly build (0.10.0.v201304222226) and OCL last nightly build (4.1.0.v20130423-0101) and Xtext SDK (2.4.1.v201304180855).
I added the following constraint attached to the stereotype "Provider" that extend "Actor" (it means that the context is Provider):
self.base_Actor.getAssociations()-> forAll (a | a.memberEnd->exists (r|r.type.oclIsKindOf (ServiceInteraction)) and
a.memberEnd ->exists (r|r.type.oclIsKindOf (ServicePublication)) and
a.memberEnd->exists (r|r.type.oclIsKindOf (ServiceSearch)))
Note that "ServiceInteraction","ServicePublication" and "ServiceSearch" are stereotypes that extend "Use Case"
It doesn't contain errors. I tried to verify the constraint, i made an assocaition between an Actor stereotyped "Provider" and a Use Case stereotyped "ServiceComposition".But when i validate the model that apply my profile (open *.uml-->right click on the model-->validate), the validation is successful!
I'm confused between 2 things:
- The constraint is badly described and so it doesn't work or
- Something wrong with the validation Task in Papyrus.
Could you help me please..Thank you
Re: OCL constraints on stereotypes [message #1047741 is a reply to message #1047725] Tue, 23 April 2013 11:34 Go to previous messageGo to next message
A lead:
- a.memberEnds is a UML feature. This means that it returns instances of UML Elements (Which might be stereotyped with ServiceInteraction). It *won't* return instances of ServiceInteraction (Or any other stereotype). a is an Association, memberEnd contains Properties, r is a Property, and r.type is a UML Type. So you should type something like: not r.type.getAppliedStereotype(yourProfile::ServiceInteraction).oclIsUndefined()
However, this constraint should fail during validation.
You should use Papyrus to validate profiled models defined in Papyrus. Or, at least, use the latest UML integration build.
Camille
Re: OCL constraints on stereotypes [message #1047823 is a reply to message #1047741] Tue, 23 April 2013 13:51 Go to previous messageGo to next message
Thank you a lot Camille...really!
It worked!
Best regards
Re: OCL constraints on stereotypes [message #1433994 is a reply to message #1047823] Mon, 29 September 2014 10:20 Go to previous messageGo to next message
I put an OCL constraint in my profile which is related to the stereotype"ObjectMultiviews" (that extends Lifeline Class).
I want that the Lifeline stereotyped "ObjectMultiviews" could send messages only for Lifelines stereotyped "ObjectBase" and "ObjectMultiviews".
Unfortunately, many errors in my constraint that I couldn't understand Sad
Here's the constraint:
self.getConnectorEnds()-> forAll (o | o.connectorEnd->Exists(r|not r.element.getAppliedStereotype('AWSProfile::ObjectBase').oclIsUndefined()) and o.connectorEnd->exists(r|not r.element.getAppliedStereotype('AWSProfile::ObjectMultiviews').oclIsUndefined()))
Please Help me...what's wrong in it?
Thank you
Re: OCL constraints on stereotypes [message #1434030 is a reply to message #1433994] Mon, 29 September 2014 11:12 Go to previous messageGo to next message
If the context of the constraint is the stereotype "ObjectMultiviews", then the constraint should start with:
self.base_Lifeline.getConnectorEnds() (Or probably, self.base_Lifeline.connectorEnds)
"self" refers to the stereotype application (ObjectMultiview); not the stereotyped element (Lifeline)
Camille
Re: OCL constraints on stereotypes [message #1434060 is a reply to message #1434030] Mon, 29 September 2014 11:55 Go to previous messageGo to next message
Thank you Camille..
But unfortunately, nothing changed..
I don't know if the operation getConnectorEnds() and the property connectorEnd work with Lifelines and messages (Sequence diagram).
self.base_Lifeline.getConnectorEnds()-> forAll (o | o.connectorEnd->exists (r|not r.element.getAppliedStereotype('AWSProfile::ObjectBase').oclIsUndefined() )and
o.connectorEnd ->exists (r|not r.element.getAppliedStereotype('AWSProfile::ObjectMultiviews').oclIsUndefined()))
I saw in a paper "self.send.sendMessageEnd", but I don't know if it's the correct syntax or not.
  • Attachment: 2.png
    (Size: 6.56KB, Downloaded 225 times)
  • Attachment: 1.png
    (Size: 19.92KB, Downloaded 184 times)
Re: OCL constraints on stereotypes [message #1434577 is a reply to message #1434060] Tue, 30 September 2014 05:25 Go to previous messageGo to next message
Hi Camille,
I moved to Eclipse Luna, Papyrus v1.0.0 20140611 and OCL 5.0.2
I put this constraint but the parser didn't accept it:
self.base_Lifeline.connectorEnds->forAll(o |
o.ConnectorEnd.Connector
->exists(type.extension_ObjectBase <> null)
and o.ConnectorEnd.Connector
->exists(type.extension_ObjectMultiviews <> null))
I Still don't know what is the right syntax Sad
Could you help me please...
  • Attachment: error1.png
    (Size: 71.68KB, Downloaded 220 times)
  • Attachment: error2.png
    (Size: 80.98KB, Downloaded 191 times)
Re: OCL constraints on stereotypes [message #1434804 is a reply to message #1434577] Tue, 30 September 2014 12:19 Go to previous messageGo to next message
Hi, Walid,
The Lifeline metaclass has no 'connectorEnds' property. It has a
'represents' property of type ConnectableElement that has an 'end'
property (note the singular).
The ConnectorEnd metaclass has no 'ConnectorEnd' property nor
'Connector'. Unfortunately, the UML metamodel completely forgot to
define an opposite of the Connector::end property, so you have to
navigate awkwardly through the end's owner.
How does the following work for you?
self.base_Lifeline.represents.end->forAll(end |
end.owner.oclAsType(Connector)->exists(type.extension_ObjectBase->notEmpty())
and
end.owner.oclAsType(Connector)->exists(type.extension_ObjectMultiviews->notEmpty()))
This says that, if the lifeline's represented connectable element is
associated with any connector ends, then the connector owning every
associated end must be typed by an association that has both the
<<ObjectBase>> and <<ObjectMultiviews>> stereotype applied. Is that
the constraint that you want to express?
HTH,
Christian
On 2014-09-30 09:25:06 +0000, Walid Ban said:
> Hi Camille,
> I Still don't know what is the right syntax :(
> Regards
> <image>
> <image>
Re: OCL constraints on stereotypes [message #1434818 is a reply to message #1434804] Tue, 30 September 2014 12:45 Go to previous messageGo to next message
Hi Christian,
Thank you for reply...
I have a profile that contains stereotypes which extend the meta-class "Lifeline". These stereotypes are "ObjectBase", "ObjectMultiviews", "ObjectProviderView" and "ObjectHumanConsumer".
The constraint (which must be created in my profile) tells that :an "ObjectMultiviews" Lifeline could only send messages to another "ObjectMultiviews" Lifeline or to an "ObjectBase" Lifeline.
So, if for example, an "ObjectMultiviews" Lifeline sends a message to an "ObjectProviderView" Lifeline, an errors must be occured when I validate a model (on which my profile is applied).
Any solution please?
Thank you for your collaboration...
Re: OCL constraints on stereotypes [message #1435583 is a reply to message #1434818] Wed, 01 October 2014 14:13 Go to previous messageGo to next message
Hi, Walid,
It looked like your constraint was trying to
On 2014-09-30 16:45:03 +0000, Walid Ban said:
> Hi Christian,
> Regards
Re: OCL constraints on stereotypes [message #1435614 is a reply to message #1435583] Wed, 01 October 2014 15:03 Go to previous messageGo to next message
All right, thank you Christian
Well, the parser didn't accept "extension_ObjectBase" and "extension_ObjectMultiviews" ! (Unresolved Property 'UML::Association::extension_ObjectBase')
I think because the stereotype "ObjectBase" extends Lifeline Meta-Class not Association Meta-Class. (I hope that you understand what I mean)
Any suggestion??
  • Attachment: error.png
    (Size: 99.30KB, Downloaded 176 times)
  • Attachment: workspace_Luna.rar
    (Size: 5.60MB, Downloaded 172 times)
    (Size: 78.34KB, Downloaded 173 times)
Re: OCL constraints on stereotypes [message #1436796 is a reply to message #1435583] Fri, 03 October 2014 08:21 Go to previous message
Hi again,
This constraint is always violated Confused
self.base_Lifeline.represents->exists(r| r.getAppliedStereotype('AWSProfile::ObjectMutiviews')<>null xor
r.getAppliedStereotype('AWSProfile::ObjectBase')<>null )
(I have a profile that contains stereotypes which extend the meta-class "Lifeline". These stereotypes are "ObjectBase", "ObjectMultiviews", "ObjectProviderView" and "ObjectHumanConsumer".
So, if for example, an "ObjectMultiviews" Lifeline sends a message to an "ObjectProviderView" Lifeline, the constraint must be violated when I validate the model .
Any suggestion please?
Previous Topic:Requirement table (and others), Rationale column appears truncated
Next Topic:Project explorer frame
Current Time: Wed Jul 23 12:36:07 EDT 2025
Powered by FUDForum. Page generated in 0.11857 seconds
