Home » Newcomers » Newcomers » Problem with Installation(Eclipse and Java)
Problem with Installation [message #1046919] Mon, 22 April 2013 10:43 Go to next message
Hello Forum,
I just dowloaded the recent Eclipse, also Java 7 Update 21 and installed both on Win7.
In the Eclipse.ini I added the following lines as written in the Newbie posting:
-vm
C:\Program Files (x86)\Java\jre7\bin\javaw.exe
But I still get the following error message. What is wrong with my installation? I'm new to both Java and Eclipse, so every hint will help.
Markus
Java was started but returned exit code=13
-Xms40m
-Xmx512m
-XX:MaxPermSize=256m
-jar C:\eclipse\\plugins/org.eclipse.equinox.launcher_1.3.0.v20120522-1813.jar
-os win32
-ws win32
-arch x86_64
-showsplash C:\eclipse\\plugins\org.eclipse.platform_4.2.2.v201302041200\splash.bmp
-launcher C:\eclipse\eclipse.exe
-name Eclipse
--launcher.library C:\eclipse\\plugins/org.eclipse.equinox.launcher.win32.win32.x86_64_1.1.200.v20120913-144807\eclipse_1503.dll
-startup C:\eclipse\\plugins/org.eclipse.equinox.launcher_1.3.0.v20120522-1813.jar
--launcher.overrideVmargs
-exitdata 1038_58
-vm C:\Program Files (x86)\Java\jre7\bin\javaw.exe
-vmargs
-Xms40m
-Xmx512m
Re: Problem with Installation [message #1047084 is a reply to message #1046919] Mon, 22 April 2013 15:20 Go to previous messageGo to next message
You appear to be trying to run a 64 bit Eclipse on a 32 bit JVM. You need to either download a 64 bit JRE/JDK from Oracle or download a 32 bit Eclipse from eclipse.org
Re: Problem with Installation [message #1047096 is a reply to message #1047084] Mon, 22 April 2013 15:38 Go to previous message
Vielen Dank.
Previous Topic:Eclipse not creating JPA entities from table
Next Topic:Need help with a project
Current Time: Wed Jul 23 11:46:59 EDT 2025
Powered by FUDForum. Page generated in 0.07597 seconds
