Home » Modeling » TMF (Xtext) » unique name validation in project, not the whole workspace(How to get only Resources of project with IResourceDescriptions?)
unique name validation in project, not the whole workspace [message #766678] Fri, 16 December 2011 03:47 Go to next message
Hello!
I have to check for unique names in my Xtext-project and I do this with a validator and collect all EObjects (in my case EEntities) like this:
		List<EEntity> allEntities = new ArrayList<EEntity>();
		for (IResourceDescription resourceDescription : resourceDescriptions.getAllResourceDescriptions()) {
			for (IEObjectDescription eobjectDescription : resourceDescription.getExportedObjects()) {
				EObject eObjectOrProxy = eobjectDescription.getEObjectOrProxy();
				if (eObjectOrProxy instanceof EEntity) {
					allEntities.add( (EEntity) eobjectDescription.getEObjectOrProxy() );
This is working fine for me. But when we were testing the DSL in a real-life-project we discovered that getAllResourceDescriptions of IResourceDescriptions delievers all ResourceDescriptions of the whole workspace. I will have to narrow this to project-level but do not know how I can do this.
Any help concerning this issue is highly appreciated. Thanks!
Annette
Re: unique name validation in project, not the whole workspace [message #766681 is a reply to message #766678] Fri, 16 December 2011 03:58 Go to previous messageGo to next message
Hello Annette,
have a look at this http://www.eclipse.org/forums/index.php/mv/msg/261440/754503/#msg_754503
~Christian
Re: unique name validation in project, not the whole workspace [message #766705 is a reply to message #766681] Fri, 16 December 2011 04:35 Go to previous messageGo to next message
Hi Christian!
Thanks for your reply Smile
I tried the suggestion in the post above and I did not get things right, yet.
If I use
IResourceDescription resourceDescription = resourceDescriptions.getResourceDescription( eEntity.eResource().getURI() );
to get the ResourceDescription only the file of my entity is validated. But I want the validation to consider all entities in all files of one project. So I guess I will have to use getAllResourceDescriptions but somehow filter the list of ResourceDescriptions to get rid of the entities of my workspace which do not belong to my project.
I have one more question:
I inject IResourceDescriptions in my Validator and in your solution ResourceDescriptionsProvider is injected and the ResourceDescriptions is fetched by the eObject of the validation. Should I change this or does not it matter?
[Updated on: Fri, 16 December 2011 04:36] by Moderator
Re: unique name validation in project, not the whole workspace [message #766724 is a reply to message #766705] Fri, 16 December 2011 05:10 Go to previous messageGo to next message
Hi this is why you use the Container Manager. IT takes care of the
project and its resources. Note: standalone The Container is the
resourceset
Re: unique name validation in project, not the whole workspace [message #766852 is a reply to message #766724] Fri, 16 December 2011 09:50 Go to previous messageGo to next message
I never used a Container Manager - I'm quite new to Xtext - but I will try on Monday.
Thanks, Christian!
Re: unique name validation in project, not the whole workspace [message #767941 is a reply to message #766852] Mon, 19 December 2011 03:45 Go to previous messageGo to next message
I just tried using the Container-Manager and it worked instantly and I am once more convinced that the Xtext-Framework is really great Smile
If someone is interested in the code:
	@Inject
	IContainer.Manager containermanager;
	@Inject
	ResourceDescriptionsProvider resourceDescriptionsProvider;
	public List<EEntity> getAllEntitiesFor( EObject eObject ) {
		IResourceDescriptions resourceDescriptions = resourceDescriptionsProvider.getResourceDescriptions( eObject.eResource() );
		IResourceDescription resourceDescription = resourceDescriptions.getResourceDescription( eObject.eResource().getURI() );
		List<IContainer> visiblecontainers = containermanager.getVisibleContainers( resourceDescription, resourceDescriptions );
		for (IContainer container : visiblecontainers) {
			for (IEObjectDescription eobjectDescription : container.getExportedObjects()) {
		return allEntities;
Thanks for the help, Christian.
Re: unique name validation in project, not the whole workspace [message #1046885 is a reply to message #767941] Mon, 22 April 2013 09:52 Go to previous messageGo to next message
I used described approach to collect all EObjects in project previously, but it does not seem to work anymore Sad ...
Problem is here:
resourceDescriptions object now contains only descriptions of few resources (the containing resource itself and all resources referenced from that resource) and I would need there descriptions of all resources, not only referenced ones.
I do not understand what happend, this approach worked well before.
Can anyone help me with this issue?
Thank you & Best regards
Michal
Re: unique name validation in project, not the whole workspace [message #1046900 is a reply to message #1046885] Mon, 22 April 2013 10:14 Go to previous messageGo to next message
HI,
this is the reason to use the container manager and ask it for (visible) containers
Re: unique name validation in project, not the whole workspace [message #1046916 is a reply to message #1046900] Mon, 22 April 2013 10:39 Go to previous messageGo to next message
Christian,
thank you for your answer.
I also ask for visible containers.
Problem is, that if I use getVisibleContainers(resourceDescription, resourceDescriptions) and resourceDescriptions object contains only descriptions of related resources, than also visible containers contain only limited amount of containers (not all of them...).
Here is my function:
def collectAllDescriptions(EClass clazz){
	val resourceDescriptions = rdp.getResourceDescriptions(resource)
	val resourceDescription = resourceDescriptions.getResourceDescription(resource.URI)
	val containers = containerManager.getVisibleContainers(resourceDescription,resourceDescriptions)
	var out = new ArrayList<IEObjectDescription>()
	for(container:containers){
		out.addAll(container.getExportedObjectsByType(clazz))
	out
rdp is injected ResourceDescriptionsProvider and resource is processed resource.
If I use Project->Clean, everything works well, as object resourceDescriptions contains all model files contained in project. Problem occurs only when I save single model file and generator is called (resourceDescriptions contain only limited amount of descriptions).
Thank you,
Michal
Re: unique name validation in project, not the whole workspace [message #1046924 is a reply to message #1046916] Mon, 22 April 2013 10:52 Go to previous messageGo to next message
And what is your expected behaviour?
what do you want to achieve?
the code gives you all visible stuff from your context
Re: unique name validation in project, not the whole workspace [message #1046928 is a reply to message #1046924] Mon, 22 April 2013 11:00 Go to previous messageGo to next message
I need to collect all EObjects of specific type across all model files in the project. (E.g. all Greeting objects .... as I need to generate file containing their names...)
Thank you & Regards,
Michal
Re: unique name validation in project, not the whole workspace [message #1046940 is a reply to message #1046928] Mon, 22 April 2013 11:20 Go to previous messageGo to next message
If you ask the container for exported objects of that type it should
work. (If you really export them)
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext at itemis dot de
Re: unique name validation in project, not the whole workspace [message #1047484 is a reply to message #1046940] Tue, 23 April 2013 05:13 Go to previous messageGo to next message
Hello Christian,
I set up new "Greeting" project and it works there out of the box...
Problem is somewhere in my code Sad
I tried to debug, what the difference is and I found out, that following code gives different results:
In case of greeting project, where everything works perfectly, the result is:
[[StateBasedContainer] container '=rrrrrrrrrrrrrrrrrrrrrrr/src' from org.eclipse.xtext.ui.containers.JavaProjectsState@ffde9e]
And If I watch elementData->0->descriptions, it contains:
org.eclipse.xtext.builder.clustering.CurrentDescriptions$ResourceSetAware@1c60440
In case of my real project, where it does not work, the result is:
[[StateBasedContainer] container 'all' from org.eclipse.xtext.resource.containers.FlatResourceSetBasedAllContainersState@b75459]
[ResourceSetBasedResourceDescriptions
  [DefaultResourceDescription uri=platform:/resource/LCEProject/src/file.tcf]
I don't understand, why it behaves differently. Do you have any idea, why could this situation occur?
Thank you & Best regards,
Michal
EDIT:
I found out, that containerManager in Greeting example uses as stateProvider
 org.eclipse.xtext.ui.containers.ContainerStateProvider
, on the other hand, in case of my real project
org.eclipse.xtext.resource.containers.ResourceSetBasedAllContainersStateProvider
Difference between Greeting example is, that I @Inject containerManager and resourceDescriptionsProvider in MyDslGenerator class as follows:
@Inject
ResourceDescriptionsProvider rdp
@Inject
IContainer$Manager containerManager
In case of my real project I use not Injected class and I inject the containerManager in that class in constructor as follows:
val injector = Guice::createInjector(new MyRealRuntimeModule)
this.containerManager = injector.getInstance(typeof(IContainer$Manager))
Could be this the reason of my problems?
[Updated on: Tue, 23 April 2013 07:13] by Moderator
Re: unique name validation in project, not the whole workspace [message #1047553 is a reply to message #1047484] Tue, 23 April 2013 07:24 Go to previous messageGo to next message
No Message Body
Re: unique name validation in project, not the whole workspace [message #1047554 is a reply to message #1047553] Tue, 23 April 2013 07:24 Go to previous messageGo to next message
Runtime Module != UI Module.
Re: unique name validation in project, not the whole workspace [message #1047591 is a reply to message #1047554] Tue, 23 April 2013 08:25 Go to previous messageGo to next message
Hello Christian,
If I understand you well, I should use
val injector = Guice::createInjector(new MyRealUIModule)
It sounds reasonable, as all "Project" related things are Eclipse UI based. On the other hand, I should not reference from generator to UI module, as the generator is also used out of Eclipse... So how this should be done?
Anyway, I changed the structure of generator to I can use standard @Inject annotation and it works well now, but I am still interested in the previous task...
Thank you for your help & Best regards
Michal
Re: unique name validation in project, not the whole workspace [message #1047595 is a reply to message #1047591] Tue, 23 April 2013 08:28 Go to previous messageGo to next message
in which kontext do you use this. why at all using an injector yourself??????
http://koehnlein.blogspot.de/2012/11/xtext-tip-how-do-i-get-guice-injector.html
Re: unique name validation in project, not the whole workspace [message #1047652 is a reply to message #1047595] Tue, 23 April 2013 09:34 Go to previous messageGo to next message
No Message Body
[Updated on: Tue, 23 April 2013 09:40] by Moderator
Re: unique name validation in project, not the whole workspace [message #1047655 is a reply to message #1047595] Tue, 23 April 2013 09:37 Go to previous messageGo to next message
Hello Christian,
to explain my problem:
I use in my DSL multiple generators (I generate various implementations from my models ... and I switch between them using preferencePage or arguments of runGenerator() in Main class).
I created own package for every generator. Default MyDslGenerator.xtend was used just to create objects of my specific generators. Previously, I have not injected them, but just created standardly using constructor. If I injected e.g. ResourceDescriptionsProvider or Container.Manager in this standardly created objects, it was always null injected. That is why I tried to use
val injector = Guice::createInjector(new MyDslRuntimeModule)
Now, after reading Jan's blog, I realize, this was bad approach.
Just before you answered, I changed the structure of my generator that way, that I @Inject all specific generators in MyDslGenerator.xtend ... and consequently I can @Inject ResourceDescriptionsProvider or Container.Manager without any problem in my specific generators, so it works very well now.
Michal
Re: unique name validation in project, not the whole workspace [message #1047672 is a reply to message #1047655] Tue, 23 April 2013 10:03 Go to previous messageGo to next message
still the question: why dont you generate the classes via guice directly?
Re: unique name validation in project, not the whole workspace [message #1047690 is a reply to message #1047672] Tue, 23 April 2013 10:25 Go to previous messageGo to next message
What you mean be "generate the classes via guice directly"?
As I mentioned in the last sentence of my previous message I already inject my generator classes using @Inject keyword. Is this not "directly"?
Michal
Re: unique name validation in project, not the whole workspace [message #1047716 is a reply to message #1047690] Tue, 23 April 2013 11:00 Go to previous messageGo to next message
Yes but then you wont get null for container manager etc
Re: unique name validation in project, not the whole workspace [message #1047733 is a reply to message #1047716] Tue, 23 April 2013 11:16 Go to previous message
Yes, and as I wrote, it works now perfectly... There are no nulls anymore.
The result is, that my workaround with "createInjector" was wrong.
Thank you for all your help.
Michal
Previous Topic:cross-file references does not work after update (missing .classpath file)
Next Topic:How to manufacture model elements
Current Time: Thu Sep 25 12:37:22 EDT 2025
Powered by FUDForum. Page generated in 0.09579 seconds
