Home » Eclipse Projects » EclipseLink » EclipseLink NoSQL support, limitations and future plans?(Summary of current Eclipselink support features, limitations and future plans)
EclipseLink NoSQL support, limitations and future plans? [message #1046151] Sun, 21 April 2013 08:54 Go to next message
Hello all, I am trying to understand better EclipseLink NoSQL, but I am having trouble understand it's limitations, what it currently supports and I simply can't find anything about the future plans the team has.
So, in short, I have quite a big list of questions that i would like to know, if you people don't mind:
Does EclipseLink support:
  1. Object Oriented queries
  2. CRUD of entities
  3. Polymorphic entities
  4. Embeddable objects (components)
  5. Basic types
  6. Unidirectional and Bidirectional relationships (if yes, which ones?)
  7. Collections (Set, List, Map, etc)
  8. Full JPA support (I assume it does, but just in case I am wrong)
  9. Denormalization
  10. Complex joins and aggregations
Apart from these questions, are there any other limitations or jewels of the crown that I should know of?
Also, what is the team currently working in? What are the future plans?
I would be super happy if someone here could provide me with links or documentation for the questions I provided above, since I couldn't find anything :S
Thanks in advance, Pedro.
[Updated on: Mon, 22 April 2013 12:03] by Moderator
Re: EclipseLink NoSQL support, limitations and future plans? [message #1046971 is a reply to message #1046151] Mon, 22 April 2013 12:06 Go to previous message
In an effort to complete the content of this discussion, I am now posting what I have found.
Currently (use discussion date as reference) EclipseLink Supports:
  • Complex hierarchical (including XML)
  • Indexed hierarchical data
  • Mapped hierarchical data (such as JSON)
  • CRUD operations
  • Embedded objects and collections
  • Inheritance
  • Relationships
  • Subset of JP-QL and Criteria API, dependant on NoSQL database's query support
Questions without answer:
- Current limitations
- Future plans
Sources:
[Updated on: Mon, 22 April 2013 12:07] by Moderator
Previous Topic:Value of Column is null while Deleting in ManyToMany-Relationship
Next Topic:Eclipselink not reconnecting to database, after database-server downtime
Current Time: Wed Jul 23 15:27:59 EDT 2025
Powered by FUDForum. Page generated in 0.03944 seconds
