Home » Archived » Visual Editor (VE) » "Error trying to set new file into editor" problem
"Error trying to set new file into editor" problem [message #104253] Tue, 30 August 2005 03:45 Go to next message
Hi all,
When I try to open a java class with VE or try to create a new visual
class I get the following error message:
Error trying to set new file into editor.
Reason: java.lang.NullPointerException
Has anyone face something similar?
I use Eclipse SDK 3.1 with the following features:
- JDT 3.1
- EMF 2.1
- GEF 3.1
- JST 0.7
- WST 0.7
- UML2 1.1
- JEM 1.1
- XSD 2.1
- VE 1.1
jfeid
Re: "Error trying to set new file into editor" problem [message #104329 is a reply to message #104253] Tue, 30 August 2005 09:48 Go to previous messageGo to next message
Could you please attach the .log file? That will give where the error
occurred.
Rich Kulp
Re: "Error trying to set new file into editor" problem [message #104507 is a reply to message #104329] Wed, 31 August 2005 05:25 Go to previous messageGo to next message
> occurred.
Ok, here is the log:
!ENTRY org.eclipse.ve.java.core 4 0 2005-08-31 12:23:09.187
!MESSAGE Exception thrown.
!STACK 0
at org.eclipse.emf.ecore.impl.EClassImpl.getFeatureID(EClassImp l.java:661)
at
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eDynamicFeatureI D(BasicEObjectImpl.java:215)
at
org.eclipse.jem.internal.instantiation.base.JavaObjectInstan ce.eDynamicFeatureID(JavaObjectInstance.java:282)
at
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eDynamicGet(Basi cEObjectImpl.java:493)
at
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjec tImpl.java:488)
at
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjec tImpl.java:483)
at
org.eclipse.ve.internal.jfc.core.JLayeredPaneProxyAdapter.ge tCurrentOrder(JLayeredPaneProxyAdapter.java:86)
at
org.eclipse.ve.internal.jfc.core.JLayeredPaneGraphicalEditPa rt.getModelChildren(JLayeredPaneGraphicalEditPart.java:58)
at
org.eclipse.gef.editparts.AbstractEditPart.refreshChildren(A bstractEditPart.java:716)
at
org.eclipse.gef.editparts.AbstractEditPart.refresh(AbstractE ditPart.java:684)
at
org.eclipse.gef.editparts.AbstractGraphicalEditPart.refresh( AbstractGraphicalEditPart.java:554)
at
org.eclipse.gef.editparts.AbstractEditPart.addNotify(Abstrac tEditPart.java:232)
at
org.eclipse.gef.editparts.AbstractGraphicalEditPart.addNotif y(AbstractGraphicalEditPart.java:212)
at
org.eclipse.gef.editparts.AbstractEditPart.addChild(Abstract EditPart.java:195)
at
org.eclipse.gef.editparts.AbstractEditPart.refreshChildren(A bstractEditPart.java:734)
at
at
at
at
at
at
at
at
at
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart.setRootModel(JavaVisualEditorPart.java:506)
at
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart.initializeViewers(JavaVisualEditorPart.java:987)
at
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$12.run(JavaVisualEditorPart.java:1977)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3057)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2716)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
!ENTRY org.eclipse.ui 4 4 2005-08-31 12:23:09.234
!MESSAGE Unhandled event loop exception
!ENTRY org.eclipse.ui 4 0 2005-08-31 12:23:09.234
!MESSAGE Failed to execute runnable (java.lang.NullPointerException)
!STACK 0
org.eclipse.swt.SWTException: Failed to execute runnable
at org.eclipse.swt.SWT.error(SWT.java:2942)
at org.eclipse.swt.SWT.error(SWT.java:2865)
at
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:126)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
... 18 more
Re: "Error trying to set new file into editor" problem [message #104538 is a reply to message #104507] Wed, 31 August 2005 10:03 Go to previous messageGo to next message
That shouldn't be happening. We've fixed a lot of bugs with 1.1.0.1. We
have a release candidate of it available. It is Maintenance build
M20050830.
Try:
1) installing that
2) start with -clean
3) Bring up a VE. If it still fails, then
4) Close the editor
5) Run Project->Clean...->Clean All
6) Wait for the build to finish
7) Try the VE again.
Rich Kulp
Re: "Error trying to set new file into editor" problem [message #104622 is a reply to message #104538] Thu, 01 September 2005 05:46 Go to previous messageGo to next message
> M20050830.
> Try:
> 1) installing that
> 4) Close the editor
Thanx for the response.
1) I've downloaded VE-runtime-M20050830.zip and extracted in eclipse's dir.
2) Launch eclipse with -clean.
3) VE fails again with the same error.
4) Closed the editor->Clean All projects->Wait for build to finish
5) VE fails again with same error.
Here is the new log:
!ENTRY org.eclipse.ve.java.core 4 0 2005-09-01 12:39:10.390
!STACK 0
at
org.eclipse.emf.ecore.impl.EStructuralFeatureImpl.getSetting Delegate(EStructuralFeatureImpl.java:790)
at
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eSettingDelegate (BasicEObjectImpl.java:822)
at
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eDynamicIsSet(Ba sicEObjectImpl.java:609)
at
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eIsSet(BasicEObj ectImpl.java:600)
at
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveFeatures(XMLS aveImpl.java:951)
at
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveElementID(XML SaveImpl.java:2272)
at
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveElement(XMLSa veImpl.java:889)
at
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveContainedMany (XMLSaveImpl.java:2001)
at
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveFeatures(XMLS aveImpl.java:1221)
at
at
org.eclipse.emf.ecore.xmi.impl.XMISaveImpl.writeTopObjects(X MISaveImpl.java:78)
at
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.traverse(XMLSaveI mpl.java:478)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.save(XMLSaveImpl. java:206)
at
org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doSave(XMLRes ourceImpl.java:193)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(Resour ceImpl.java:893)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(Resour ceImpl.java:813)
at
org.eclipse.ve.internal.java.codegen.util.VEModelCacheUtilit y.doSaveCache(VEModelCacheUtility.java:158)
at
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.doSave(JavaSourceTranslator.java:1357)
at
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or$2.doRun(JavaSourceTranslator.java:922)
at
org.eclipse.ve.internal.java.codegen.util.ReverseParserJob.r un(ReverseParserJob.java:56)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:76)
!ENTRY org.eclipse.ve.java.core 4 0 2005-09-01 12:39:10.859
!STACK 0
at
at
org.eclipse.jem.internal.instantiation.base.JavaInstance.eDy namicFeatureID(JavaInstance.java:281)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart.setRootModel(JavaVisualEditorPart.java:505)
at
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart.initializeViewers(JavaVisualEditorPart.java:986)
at
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$13.run(JavaVisualEditorPart.java:2001)
at
at
at
at
at
!ENTRY org.eclipse.ui 4 4 2005-09-01 12:39:10.906
!ENTRY org.eclipse.ui 4 0 2005-09-01 12:39:10.906
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
... 18 more
Re: "Error trying to set new file into editor" problem [message #104654 is a reply to message #104622] Thu, 01 September 2005 10:08 Go to previous messageGo to next message
I have no idea. That shouldn't be occuring. Can you try it with a new
configuration of just Eclipse, GEF, EMF, and VE, and on a new
workspace.? That way we can narrow it down to see if it is VE or
something colliding with it.
Rich Kulp
Re: "Error trying to set new file into editor" problem [message #105032 is a reply to message #104654] Fri, 02 September 2005 07:39 Go to previous messageGo to next message
Well, it seems to be a collide with the WST feature. I'm working a
Dynamic Web Project under WST in which a package is a standalone Swing
application developed with VE. The "Error trying to set new file into
editor" error message displays only when I try to access java files with
VE which exists under the Web Project. If I create another standard Java
Project (in the same workspace) VE works ok. Moreover, the problem is
reproducible. If I create a new workspace and CVS checkout the Web
Project or create a new one, behaves similarly.
jfeid
Re: "Error trying to set new file into editor" problem [message #105038 is a reply to message #105032] Fri, 02 September 2005 09:02 Go to previous messageGo to next message
Thanks, can you please open a defect so that we can track this down with
WST and see what the conflict is?
Also, add in the defect what steps you used to reproduce the problem.
When creating the web project, what options did you choose. when
creating the VE class what options did you choose.
> jfeid
Rich Kulp
Re: "Error trying to set new file into editor" problem [message #105042 is a reply to message #105038] Fri, 02 September 2005 09:58 Go to previous message
>> with VE which exists under the Web Project. If I create another
>> standard Java Project (in the same workspace) VE works ok. Moreover,
>> the problem is reproducible. If I create a new workspace and CVS
>> checkout the Web Project or create a new one, behaves similarly.
>> jfeid
Ok, bug submitted.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=108671
Re: "Error trying to set new file into editor" problem [message #610442 is a reply to message #104253] Tue, 30 August 2005 09:48 Go to previous message
occurred.
Rich Kulp
Re: "Error trying to set new file into editor" problem [message #610455 is a reply to message #104329] Wed, 31 August 2005 05:25 Go to previous message
> occurred.
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
... 18 more
Re: "Error trying to set new file into editor" problem [message #610457 is a reply to message #104507] Wed, 31 August 2005 10:03 Go to previous message
M20050830.
Try:
1) installing that
4) Close the editor
Rich Kulp
Re: "Error trying to set new file into editor" problem [message #610471 is a reply to message #104538] Thu, 01 September 2005 05:46 Go to previous message
> M20050830.
> Try:
> 1) installing that
> 4) Close the editor
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
... 18 more
Re: "Error trying to set new file into editor" problem [message #610476 is a reply to message #104622] Thu, 01 September 2005 10:08 Go to previous message
Rich Kulp
Re: "Error trying to set new file into editor" problem [message #610617 is a reply to message #104654] Fri, 02 September 2005 07:39 Go to previous message
jfeid
Re: "Error trying to set new file into editor" problem [message #610621 is a reply to message #105032] Fri, 02 September 2005 09:02 Go to previous message
> jfeid
Rich Kulp
Re: "Error trying to set new file into editor" problem [message #610624 is a reply to message #105038] Fri, 02 September 2005 09:58 Go to previous message
>> jfeid
Ok, bug submitted.
Previous Topic:Impossible dependency for installation?
Next Topic:Problem - Opening existing project - have lost design view
Current Time: Tue Jul 22 06:40:35 EDT 2025
Powered by FUDForum. Page generated in 0.05555 seconds
