Home » Eclipse Projects » Eclipse 4 » IEditorPart loses custom icon on detach/move(After moving an Eclipse 3.x style editor to another stack or detach it, its icon moves to the default)
icon5.gif  IEditorPart loses custom icon on detach/move [message #1045007] Fri, 19 April 2013 12:27 Go to next message
we recently moved our application to Eclipse 4.2.2 to make use of the "detachable editors" feature (mainly for that).
Now I am facing the problem, that old Eclipse 3.x style editors implementing "IEditorPart" (we don't have any that use Injection) are losing their title icon when moved (i.e. detached or even just to another tab group).
If the editors have a default icon set via the extension defintion in the plugin.xml, they switch to that, otherwise they do not show any icon anymore.
Problem is that we are using the same editor for different contributor plug-ins, but they can specify the icons to show. The icon is set using "setTitleImage" in the editor's init() call.
I checked whether the active icon is disposed or something, but its not and I also tried overriding "getDefaultImage" / "getTitleImage" and things like that, but these never even get called on moving the editor window.
Since the issue is so "visible" it really gives a bad impression to the users.
Any ideas? I also could not find a known bug for this issue.
Norman
Re: IEditorPart loses custom icon on detach/move [message #1045417 is a reply to message #1045007] Sat, 20 April 2013 03:49 Go to previous messageGo to next message
This sounds like a bug, when the editor is moved new CTabItem is created
for it and it sounds like the renderer is always using the default icon
(stored in the workbench.xmi).
Tom
On 19.04.13 18:53, Norman Schoene wrote:
> another tab group).
> anymore.
> window.
> users.
> Norman
Re: IEditorPart loses custom icon on detach/move [message #1050134 is a reply to message #1045007] Fri, 26 April 2013 15:05 Go to previous messageGo to next message
Thanks for the reply.
do you know if it is possible to change / set / enhance the renderer used to get around this?
Norman
Re: IEditorPart loses custom icon on detach/move [message #1064140 is a reply to message #1050134] Mon, 17 June 2013 14:51 Go to previous messageGo to next message
Norman, please open a Bugzilla for this (I haven't seen one yet and this *is* a defect).
Re: IEditorPart loses custom icon on detach/move [message #1064173 is a reply to message #1064140] Tue, 18 June 2013 01:37 Go to previous messageGo to next message
Created: Bug 410973
Re: IEditorPart loses custom icon on detach/move [message #1064882 is a reply to message #1064173] Fri, 21 June 2013 10:05 Go to previous message
Thanks, I've added a few comments on the defect...
Previous Topic:Invalid Thread Access on EclipseContext.dispose()
Next Topic:org.eclipse.ui.forms
Current Time: Fri Jul 25 20:42:06 EDT 2025
Powered by FUDForum. Page generated in 0.12664 seconds
