Home » Newcomers » Newcomers » Error, Need Help
Error, Need Help [message #1044061] Thu, 18 April 2013 08:57 Go to next message
Hi guys, i'm currently working on Eclipse and i'm facing many errores like this one
java.lang.NoClassDefFoundError: gnu/io/SerialPortEventListener
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(Unknown Source)
at java.security.SecureClassLoader.defineClass(Unknown Source)
at java.net.URLClassLoader.defineClass(Unknown Source)
at java.net.URLClassLoader.access$100(Unknown Source)
at java.net.URLClassLoader$1.run(Unknown Source)
at java.net.URLClassLoader.findClass(Unknown Source)
at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source)
at java.lang.Class.getDeclaredMethods0(Native Method)
at java.lang.Class.privateGetDeclaredMethods(Unknown Source)
at java.lang.Class.getDeclaredMethod(Unknown Source)
at java.awt.Component.isCoalesceEventsOverriden(Unknown Source)
at java.awt.Component.access$500(Unknown Source)
at java.awt.Component$3.run(Unknown Source)
at java.awt.Component.checkCoalescing(Unknown Source)
at java.awt.Component.<init>(Unknown Source)
at java.awt.Container.<init>(Unknown Source)
at java.awt.Panel.<init>(Unknown Source)
at java.applet.Applet.<init>(Unknown Source)
at processing.core.PApplet.<init>(PApplet.java:156)
at Chauffe.<init>(Chauffe.java:9)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
at java.lang.Class.newInstance0(Unknown Source)
at java.lang.Class.newInstance(Unknown Source)
at sun.applet.AppletPanel.createApplet(Unknown Source)
at sun.applet.AppletPanel.runLoader(Unknown Source)
at sun.applet.AppletPanel.run(Unknown Source)
Caused by: java.lang.ClassNotFoundException: gnu.io.SerialPortEventListener
... 38 more
I've searched for a while but can't find anything to help me, found some answers but just can't do it so i came here to ask for your help Smile
Re: Error, Need Help [message #1044166 is a reply to message #1044061] Thu, 18 April 2013 11:06 Go to previous messageGo to next message
> like this one
> [snip]
> [snip]
(You're using Eclipse, right?)
This only means that you've not added the JAR that furnishes Java class
gnu.io.SerialPortEventListener to your project via Java Build Path.
You must find this JAR, copy it into your project (many ways to do
this), right-click your project root in the Package or Project Explorer
view, choose Build Path and then click on Add JARs... in the dialog, etc.
Come back here and ask a more specific question if you get stuck.
Hope this helps.
Re: Error, Need Help [message #1044167 is a reply to message #1044166] Thu, 18 April 2013 11:09 Go to previous messageGo to next message
>> like this one
>> [snip]
>> [snip]
> Hope this helps.
By the way, I typed "gnu.io.SerialPortEventListener" into Google and
found this link:
http://forum.processing.org/topic/classnotfoundexception-gnu-io-serialporteventlistener
Re: Error, Need Help [message #1044168 is a reply to message #1044061] Thu, 18 April 2013 11:10 Go to previous messageGo to next message
Your question really belongs in a general Java programming forum and not in the Eclipse forums.
Your program is trying to load a class called SerialPortEventListener from the gnu.io package. This class can't be found on the programs classpath. You need to add the class to the classpath. Normally this would be accomplished by adding a jar file to the classpath. I'm not familiar with the gni.io package, so can't provide much more information other then to suggest you study about how the Java classpath works and how to specify the classpath.
Re: Error, Need Help [message #1044749 is a reply to message #1044167] Fri, 19 April 2013 05:35 Go to previous messageGo to next message
Russell Bateman wrote on Thu, 18 April 2013 11:09
found this link
Yeah I found it too, but it didn't work so i thought i would come here
Russell Bateman wrote on Thu, 18 April 2013 11:06
Hope this helps.
It helped a lot indeed, thanks to you guys, it did solve this problem but now i have a new one, and yeah i'm using Eclipse Smile
java.lang.UnsatisfiedLinkError: C:\Program Files (x86)\Java\jre6\bin\rxtxSerial.dll: Can't load IA 32-bit .dll on a AMD 64-bit platform thrown while loading gnu.io.RXTXCommDriver
at java.lang.ClassLoader$NativeLibrary.load(Native Method)
at java.lang.ClassLoader.loadLibrary1(Unknown Source)
at java.lang.ClassLoader.loadLibrary0(Unknown Source)
at java.lang.ClassLoader.loadLibrary(Unknown Source)
at java.lang.Runtime.loadLibrary0(Unknown Source)
at java.lang.System.loadLibrary(Unknown Source)
at gnu.io.CommPortIdentifier.<clinit>(CommPortIdentifier.java:83)
at processing.serial.Serial.list(Serial.java:632)
at Chauffe.setup(Chauffe.java:44)
at processing.core.PApplet.handleDraw(PApplet.java:2241)
at processing.core.PGraphicsJava2D.requestDraw(PGraphicsJava2D.java:243)
at processing.core.PApplet.run(PApplet.java:2140)
Exception in thread "Animation Thread" java.lang.RuntimeException: Error inside Serial.ports()
at processing.serial.Serial.errorMessage(Serial.java:666)
at processing.serial.Serial.list(Serial.java:647)
I really think that it's a bout the version of Eclipse and my windows but the eclipse 64 bit doesn't works so i'm kind of stuck.
David Wegener wrote on Thu, 18 April 2013 11:10
Anyway thanks for replying, and i've studied thos yesterday during 4 hours nothing really helped Smile
Re: Error, Need Help [message #1044889 is a reply to message #1044749] Fri, 19 April 2013 09:12 Go to previous messageGo to next message
On 4/19/2013 3:35 AM, Rawz . wrote:
> [snip]
> but now i have a new one, and yeah i'm using Eclipse :)
> 64-bit platform
> [snip]
You're mixing 32-bit and 64-bit, aren't you? This is a no-no. All one or
all the other, but no mixing.
Re: Error, Need Help [message #1059932 is a reply to message #1044889] Wed, 22 May 2013 04:34 Go to previous message
Ok, I think I get it, thanks all for your help
Previous Topic:Cannot resolve an eclipse JDI error
Next Topic:Documentation print topic and all subtopics problem
Current Time: Tue Jul 22 22:20:28 EDT 2025
Powered by FUDForum. Page generated in 0.11794 seconds
