[Xpand/Xtend] Extension problem [message #1005545] |
Sat, 26 January 2013 08:00  |
I have a problem with extensions in my Xpand project. I want to generate a textual file from my model conforming to the meta-model I made (using Ecore meta-meta-model). I have a following error when I try to run generator.mwe:
933 INFO CompositeComponent - Generator: generating 'template::template::module FOR model' => src-gen
976 ERROR AbstractExpressionsUsingWorkflowComponent - Error in Component of type org.eclipse.xpand2.Generator:
EvaluationException : Couldn't find operation 'getModel()' for metatransform::ModelPackage::Class.
template::template.xpt[901,10] on line 34 'this.inPattern.inClass.getModel()'
template::template.xpt[673,30] on line 26 'EXPAND rule FOREACH this.rules'
template::template.xpt[146,54] on line 8 'EXPAND transformation(this.name) FOREACH this.elements'
[23,43] on line 1 'EXPAND template::template::module FOR model'
977 ERROR WorkflowEngine - Workflow interrupted. Reason: Couldn't find operation 'getModel()' for metatransform::ModelPackage::Class.
977 ERROR WorkflowEngine - [ERROR]: Couldn't find operation 'getModel()' for metatransform::ModelPackage::Class.(Element: this.inPattern.inClass.getModel(); Reported by: Generator: generating 'template::template::module FOR model' => src-gen)
977 ERROR WorkflowEngine - [ERROR]: Couldn't find operation 'getModel()' for metatransform::ModelPackage::Class.(Element: this.inPattern.inClass.getModel().name; Reported by: Generator: generating 'template::template::module FOR model' => src-gen)
978 ERROR WorkflowEngine - [ERROR]: Couldn't find operation 'getModel()' for metatransform::ModelPackage::Class.(Element: EXPRESSION: this.inPattern.inClass.getModel().name; Reported by: Generator: generating 'template::template::module FOR model' => src-gen)
978 ERROR WorkflowEngine - [ERROR]: Couldn't find operation 'getModel()' for metatransform::ModelPackage::Class.(Element: org.eclipse.internal.xpand2.ast.LetStatement@15ee470d; Reported by: Generator: generating 'template::template::module FOR model' => src-gen)
978 ERROR WorkflowEngine - [ERROR]: Couldn't find operation 'getModel()' for metatransform::ModelPackage::Class.(Element: rule : TransformationPackage::Rule; Reported by: Generator: generating 'template::template::module FOR model' => src-gen)
978 ERROR WorkflowEngine - [ERROR]: Couldn't find operation 'getModel()' for metatransform::ModelPackage::Class.(Element: EXPAND rule FOREACH this.rules; Reported by: Generator: generating 'template::template::module FOR model' => src-gen)
978 ERROR WorkflowEngine - [ERROR]: Couldn't find operation 'getModel()' for metatransform::ModelPackage::Class.(Element: transformation(String moduleName) : MainConceptsPackage::Transformation; Reported by: Generator: generating 'template::template::module FOR model' => src-gen)
979 ERROR WorkflowEngine - [ERROR]: Couldn't find operation 'getModel()' for metatransform::ModelPackage::Class.(Element: EXPAND transformation(this.name) FOREACH this.elements; Reported by: Generator: generating 'template::template::module FOR model' => src-gen)
979 ERROR WorkflowEngine - [ERROR]: Couldn't find operation 'getModel()' for metatransform::ModelPackage::Class.(Element: org.eclipse.internal.xpand2.ast.FileStatement@25c3e05a; Reported by: Generator: generating 'template::template::module FOR model' => src-gen)
979 ERROR WorkflowEngine - [ERROR]: Couldn't find operation 'getModel()' for metatransform::ModelPackage::Class.(Element: module : MainConceptsPackage::Module; Reported by: Generator: generating 'template::template::module FOR model' => src-gen)
979 ERROR WorkflowEngine - [ERROR]: Couldn't find operation 'getModel()' for metatransform::ModelPackage::Class.(Element: EXPAND template::template::module FOR model; Reported by: Generator: generating 'template::template::module FOR model' => src-gen)
The unusual part is when i write a template file it gives me a contextual help and shows those operations on my modeling concepts (shows them as operations written in extension file). The extension file looks like this:
import metatransform;
MainConceptsPackage::Model getModel(ModelPackage::Class this) :
this.package.getRootPackage().model;
ModelPackage::Package getRootPackage(ModelPackage::Package this) :
this.superPackage == null ? this : this.getRootPackage();
I use getModel() extension in template file (inClass is of type ModelPackage::Class and MainConceptsPackage::Model has name attribute):
«LET this.inPattern.inClass.name.subString(0,1).toLowerCase() AS in-»
«in» «this.inPattern.inClass.getModel().name» «this.inPattern.inClass.name»
And the generator.mwe file:
<?xml version="1.0"?>
<workflow>
<property name="model" value="MetaTransformer.xpand/src/metamodel/Module.xmi" />
<property name="src-gen" value="src-gen" />
<!-- set up EMF for stand alone execution -->
<bean class="org.eclipse.emf.mwe.utils.StandaloneSetup" >
<platformUri value=".."/>
</bean>
<!-- instantiate meta model -->
<bean id="mm_emf" class="org.eclipse.xtend.typesystem.emf.EmfRegistryMetaModel"/>
<!-- load model and store it in slot 'model' -->
<component class="org.eclipse.emf.mwe.utils.Reader">
<uri value="platform:/resource/${model}" />
<modelSlot value="model" />
</component>
<!-- check model -->
<component class="org.eclipse.xtend.check.CheckComponent">
<metaModel idRef="mm_emf"/>
<checkFile value="metamodel::Checks" />
<emfAllChildrenSlot value="model" />
</component>
<!-- generate code -->
<component class="org.eclipse.xpand2.Generator">
<expand
value="template::template::module FOR model" />
<outlet path="${src-gen}" >
<postprocessor class="org.eclipse.xpand2.output.JavaBeautifier" />
</outlet>
</component>
</workflow>
When I don't use extension methods, generator works just fine and generates exactly what I wanted. The error only occurs when I insert those methods. So I'm wondering is there any additional setup I need to perform in generator.mwe or the error is consequence of something else?
Vladimir
FUDForum. Page generated in 0.29554 seconds
