Home » Modeling » TMF (Xtext) » Error in extending xbase expressions
Error in extending xbase expressions [message #1043938] Thu, 18 April 2013 05:42 Go to next message
Hi ,
This is a part of my grammar :
grammar org.xtext.example.jade.Jade with  org.eclipse.xtext.xbase.Xbase
Message returns xbase::XExpression:
	SendMessage | Prova
SendMessage returns xbase::XExpression:
	{SendMessage}
	'send message' name = ValidID  '{'
	(('sender' '=' sender = STRING)? &
	('content'  '=' content = STRING)? &
	//('language'  '=' language = STRING)? &
	//('ontology'  '=' ontology = STRING)? &
	('performative' '=' performative = Performative) &
	('receivers' '{' (receivers += (MessageReceivers)+) '}' ) )
SimpleBehaviour :
	'behaviour' name=ValidID 'is' typeSB = TypeSB '{'
	 (body=XExpressionInsideBlock ';'?)
XExpressionInsideBlock returns xbase::XExpression:
	XVariableDeclaration | XExpression | Message;
Prova returns xbase::XExpression :
  {Prova} 'receive message do' '{' campo = XExpressionInsideBlock '}'
I extend xbase expressions adding my expression(Message) in XExpressionInsideBlock
My expression Message is SendMessage expression or Prova expression.I extend xbase expression for use all xbase expressions and in additional my expression Messagge in SimpleBehaviour.
Then I extend AbstractModelInferrer and XbaseCompiler for translate my DSL in java.
This è my XbaseCompiler :
class JadeCompiler extends XbaseCompiler {
	override protected doInternalToJavaStatement(XExpression expr,ITreeAppendable it, boolean isReferenced) {
		switch expr {
			SendMessage : {
				newLine
				append('''
      				ACLMessage «expr.name» = new                ACLMessage(ACLMessage.«expr.performative»);
      				«IF expr.sender != null»
      					«expr.name».setSender(new AID ("«expr.sender»",AID.ISLOCALNAME));
      				«ENDIF»
      			        «IF expr.content != null»
      				    «expr.name».setContent("«expr.content»");
      				«ENDIF»
      				«FOR r : expr.receivers»
      					«expr.name».addReceiver(new AID ("«r.receiver»",AID.ISLOCALNAME));
      				«ENDFOR»
      				send(«expr.name»);
		Prova : {
			doInternalToJavaStatement(expr.campo, it, isReferenced)
			append('''
			ACLMessage msg = receive();
			if (msg!=null){}
			default :
				super.doInternalToJavaStatement(expr, it, isReferenced)
	override protected internalToConvertedExpression(XExpression obj, ITreeAppendable it) {
		if (hasName(obj))
			append(getName(obj))
		else
			super.internalToConvertedExpression(obj, it)
If i use SendMessage expression the translate is work but if i use Prova expression the translate don't work
Error is :
ERROR org.eclipse.xtext.builder.BuilderParticipant - Error during compilation of '..'
Re: Error in extending xbase expressions [message #1044314 is a reply to message #1043938] Thu, 18 April 2013 15:05 Go to previous messageGo to next message
can you share a complete reproduceable example, stacktrace etc
Re: Error in extending xbase expressions [message #1044323 is a reply to message #1044314] Thu, 18 April 2013 15:20 Go to previous messageGo to next message
Btw i dont get a NPE with what i built myself from your stuff.
Re: Error in extending xbase expressions [message #1044375 is a reply to message #1044323] Thu, 18 April 2013 16:59 Go to previous messageGo to next message
thank you for you replies
my grammar :
generate jade "htp://www.xtext.org/example/jade/Jade"
import 'htp://www.eclipse.org/xtext/xbase/Xbase' as xbase
Model:
	'package' name = QualifiedName
	elements+=AbstractElement*;
AbstractElement :
	AbstractBehaviour | AgentJade
AgentJade:
	'agent' name=ValidID '{'
	 behaviours += AddBehaviour*
	 messages += Message*
AddBehaviour :
	'add behaviour' name=ValidID 'type' type = [AbstractBehaviour|ValidID]
	SendMessage | Prova
	{SendMessage}
MessageReceivers :
	'receiver =' receiver = STRING
enum Performative :
	REQUEST | INFORM | QUERY_IF | CFP | PROPOSE | ACCEPT_PROPOSAL | REJECT_PROPOSAL //da completare
AbstractBehaviour :
  SimpleBehaviour | Behaviour
Behaviour :
	'behaviour' name=ValidID 'is' typeB = 'Behaviour' '{'
	 (body=XExpressionInsideBlock';'?)
SimpleBehaviour :
enum TypeSB  :
	OneShotBehaviour | CiclicBehaviour
my compiler :
	override protected doInternalToJavaStatement(XExpression expr, ITreeAppendable it, boolean isReferenced) {
		switch expr {
			SendMessage : {
				newLine
				append('''
      				«ENDIF»
      				«ENDIF»
      				«ENDFOR»
      				send(«expr.name»);
		Prova : {
			append('''
			if (msg!=null){}
			default :
		if (hasName(obj))
		else
my AbstractModelInferrer :
class JadeJvmModelInferrer extends AbstractModelInferrer {
   @Inject extension JvmTypesBuilder
  @Inject extension IQualifiedNameProvider
  def dispatch void infer(Model element,
                IJvmDeclaredTypeAcceptor acceptor,
                boolean isPrelinkingPhase) {
    for (a : element.elements) {
    	switch a {
    		AbstractBehaviour : {
    			switch a {
    				SimpleBehaviour : {
    					acceptor.accept(a.toClass(a.fullyQualifiedName)).initializeLater [
    						superTypes += a.newTypeRef('jade.core.behaviours.'+ a.typeSB.toString)
    						members += a.toConstructor[
    							documentation = '''...'''
    							parameters += toParameter("agent", newTypeRef(a, 'jade.core.Agent'))
    							body = [
      									append('''
        								super(agent);
    						members += a.toMethod("action",a.newTypeRef(Void::TYPE))[
    						body = a.body
    		AgentJade : {
      				documentation = a.documentation
      				superTypes += a.newTypeRef('jade.core.Agent')
      				members += a.toMethod("setup",a.newTypeRef(Void::TYPE))[
      					body = [append('''
      						«FOR b : a.behaviours»
      							«b.type.name» «b.name» = new «b.type.name»(this);
      							addBehaviour(«b.name»);
      						«ENDFOR»
      						   for (m : a.messages) {
      						   	 switch m {
      						   	 	SendMessage : {
      						   	 		append('''
      						   	 		ACLMessage «m.name» = new ACLMessage(ACLMessage.«m.performative»);
      						   	 		«IF m.sender != null»
      						   	 			«m.name».setSender(new AID ("«m.sender»",AID.ISLOCALNAME));
      						   	 		«ENDIF»
      						   	 		«IF m.content != null»
      						   	 			«m.name».setContent("«m.content»");
      						   	 		«ENDIF»
      						   	 		«FOR r : m.receivers»
      						   	 			«m.name».addReceiver(new AID ("«r.receiver»",AID.ISLOCALNAME));
      						   	 		«ENDFOR»
      						   	 		send(«m.name»);
      						   	    }//sendMe
      						   	   }//switch
      						   	 }//for
      						 ]//body
    		}//agent jade
    }//switch
  }//for
  }//infer
}//class
my RuntimeModule :
public class JadeRuntimeModule extends org.xtext.example.jade.AbstractJadeRuntimeModule {
	public Class<? extends XbaseCompiler> bindXbaseCompiler() {
		return JadeCompiler.class;
	public Class<? extends ITypeComputer> bindITypeComputer() {
		return JadeTypeComputer.class;
my TypeComputer :
class JadeTypeComputer extends XbaseTypeComputer {
	override computeTypes(XExpression expression, ITypeComputationState state) {
		if(expression instanceof SendMessage) {
			_computeTypes(expression as SendMessage, state);
		} else if (expression instanceof Prova){
			 _computeTypes(expression as Prova,state)}
			 else {
			super.computeTypes(expression, state)
	protected def _computeTypes(SendMessage expression, ITypeComputationState state) {
		//super._computeTypes(expression as XExpression, state)
		state.acceptActualType(getTypeForName(typeof(Void), state))
	protected def _computeTypes(Prova expression, ITypeComputationState state) {
		//super.computeTypes(expression.campo, state)
Error :
at org.eclipse.xtext.xbase.compiler.TypeReferenceSerializer.serialize(TypeReferenceSerializer.java:90)
	at org.eclipse.xtext.xbase.compiler.AbstractXbaseCompiler.serialize(AbstractXbaseCompiler.java:342)
	at org.eclipse.xtext.xbase.compiler.AbstractXbaseCompiler.serialize(AbstractXbaseCompiler.java:338)
	at org.eclipse.xtext.xbase.compiler.AbstractXbaseCompiler.serialize(AbstractXbaseCompiler.java:334)
	at org.eclipse.xtext.xbase.compiler.XbaseCompiler.appendVariableTypeAndName(XbaseCompiler.java:663)
	at org.eclipse.xtext.xbase.compiler.XbaseCompiler._toJavaStatement(XbaseCompiler.java:643)
	at org.eclipse.xtext.xbase.compiler.XbaseCompiler.doInternalToJavaStatement(XbaseCompiler.java:441)
	at org.xtext.example.jade.jvmmodel.JadeCompiler.doInternalToJavaStatement(JadeCompiler.java:93)
	at org.xtext.example.jade.jvmmodel.JadeCompiler.doInternalToJavaStatement(JadeCompiler.java:83)
	at org.eclipse.xtext.xbase.compiler.AbstractXbaseCompiler.internalToJavaStatement(AbstractXbaseCompiler.java:297)
	at org.eclipse.xtext.xbase.compiler.AbstractXbaseCompiler.compile(AbstractXbaseCompiler.java:236)
	at org.eclipse.xtext.xbase.compiler.JvmModelGenerator.generateExecutableBody(JvmModelGenerator.java:1111)
	at org.eclipse.xtext.xbase.compiler.JvmModelGenerator._generateMember(JvmModelGenerator.java:809)
	at org.eclipse.xtext.xbase.compiler.JvmModelGenerator.generateMember(JvmModelGenerator.java:1777)
	at org.eclipse.xtext.xbase.compiler.JvmModelGenerator$2.apply(JvmModelGenerator.java:286)
	at org.eclipse.xtext.xbase.compiler.JvmModelGenerator$2.apply(JvmModelGenerator.java:1)
	at org.eclipse.xtext.xbase.lib.ObjectExtensions.operator_doubleArrow(ObjectExtensions.java:139)
	at org.eclipse.xtext.xbase.compiler.LoopExtensions$1.apply(LoopExtensions.java:39)
	at org.eclipse.xtext.xbase.lib.IterableExtensions.forEach(IterableExtensions.java:399)
	at org.eclipse.xtext.xbase.compiler.LoopExtensions.forEach(LoopExtensions.java:42)
	at org.eclipse.xtext.xbase.compiler.JvmModelGenerator._generateBody(JvmModelGenerator.java:290)
	at org.eclipse.xtext.xbase.compiler.JvmModelGenerator.generateBody(JvmModelGenerator.java:1751)
	at org.eclipse.xtext.xbase.compiler.JvmModelGenerator.generateType(JvmModelGenerator.java:209)
	at org.eclipse.xtext.xbase.compiler.JvmModelGenerator._internalDoGenerate(JvmModelGenerator.java:200)
	at org.eclipse.xtext.xbase.compiler.JvmModelGenerator.internalDoGenerate(JvmModelGenerator.java:1734)
	at org.eclipse.xtext.xbase.compiler.JvmModelGenerator.doGenerate(JvmModelGenerator.java:181)
	at org.eclipse.xtext.builder.BuilderParticipant.handleChangedContents(BuilderParticipant.java:291)
	at org.eclipse.xtext.builder.BuilderParticipant.build(BuilderParticipant.java:221)
	at org.eclipse.xtext.builder.impl.RegistryBuilderParticipant.build(RegistryBuilderParticipant.java:60)
	at org.eclipse.xtext.builder.impl.XtextBuilder.doBuild(XtextBuilder.java:170)
	at org.eclipse.xtext.builder.impl.XtextBuilder.incrementalBuild(XtextBuilder.java:146)
	at org.eclipse.xtext.builder.impl.XtextBuilder.build(XtextBuilder.java:95)
	at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:726)
	at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:199)
	at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:239)
	at org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:292)
	at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:295)
	at org.eclipse.core.internal.events.BuildManager.basicBuildLoop(BuildManager.java:351)
	at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:374)
	at org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBuildJob.java:143)
	at org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJob.java:241)
	at org.eclipse.core.internal.jobs.Worker.run(Worker.java:53)
Re: Error in extending xbase expressions [message #1044378 is a reply to message #1044323] Thu, 18 April 2013 17:01 Go to previous messageGo to next message
sorry for double post
[Updated on: Thu, 18 April 2013 17:03] by Moderator
Re: Error in extending xbase expressions [message #1044383 is a reply to message #1044378] Thu, 18 April 2013 17:15 Go to previous messageGo to next message
can you share your test model as well?
Re: Error in extending xbase expressions [message #1044667 is a reply to message #1044383] Fri, 19 April 2013 03:25 Go to previous messageGo to next message
I, for one, cannot reproduce that error with those settings. A concrete model would indeed be helpful.
Also, which version of Xtext are you using?
But may I give a somewhat unrelated hint towards improvement of your grammar? Keywords shouldn't have spaces. [1]
Also, when trying to format your ModelInferrer, I get a series of errors, org.eclipse.xtext.xbase.formatting.FormattableDocument - Conflicting TextEdits during formatting, for the areas around the comments on the closing brackets.
Is that only me? Because that does look like a bug to me.
[1] http://zarnekow.blogspot.de/2012/11/xtext-corner-9-about-keywords-again.html
[Updated on: Fri, 19 April 2013 03:51] by Moderator
Re: Error in extending xbase expressions [message #1044724 is a reply to message #1044667] Fri, 19 April 2013 04:47 Go to previous messageGo to next message
I use Xtext 2.4.1
I work on this example :
package agenti
behaviour HelloBehaviour is OneShotBehaviour {
	receive message do {
		val int i = 1
agent HelloAgent {
	add behaviour b1 type HelloBehaviour
	send message msg {
		performative = REQUEST
		receivers {
			receiver = "Pong"
Re: Error in extending xbase expressions [message #1044799 is a reply to message #1044724] Fri, 19 April 2013 07:05 Go to previous messageGo to next message
cant reproduce it with 2.4.0
can reproduce it with 2.4.1
looks like the type of the int literal cannot be determined.
~Christian
Re: Error in extending xbase expressions [message #1044808 is a reply to message #1044799] Fri, 19 April 2013 07:16 Go to previous messageGo to next message
Christian Dietrich wrote on Fri, 19 April 2013 13:05
~Christian
The problem also only seems to appear within a "Behaviour" block, with both SendMessage and Prova.
If I define either SendMessages and Provas in an "Agent" block, code is apprently generated as desired.
Re: Error in extending xbase expressions [message #1044812 is a reply to message #1044375] Fri, 19 April 2013 07:16 Go to previous messageGo to next message
Hi Andrea,
your type computer looks bogus to me. According to the JavaDoc of
ITypeComputer, you are responsible to trigger the type computation for
all child expressions of your specialized cases. This is important since
you usually want to specialize the expected type for your contained
expressions.
Currently you don't do that for 'Prova'. You have to use something like
state.withExpection(..).computeTypes(prova.campo).
Sebastian
Looking for professional support for Xtext, Xtend or Eclipse Modeling?
Am 18.04.13 22:59, schrieb andrea rossi:
> my grammar :
> Model:
> 'package' name = QualifiedName elements+=AbstractElement*;
> AbstractElement :
> AgentJade:
> 'agent' name=ValidID '{' behaviours += AddBehaviour*
> AddBehaviour : 'add behaviour' name=ValidID 'type' type =
> Message returns xbase::XExpression: SendMessage | Prova
> SendMessage returns xbase::XExpression: {SendMessage}
> MessageReceivers : 'receiver =' receiver = STRING ;
> enum Performative :
> AbstractBehaviour : SimpleBehaviour | Behaviour
> Behaviour : 'behaviour' name=ValidID 'is' typeB = 'Behaviour' '{'
> SimpleBehaviour : 'behaviour' name=ValidID 'is' typeSB = TypeSB '{'
> enum TypeSB : OneShotBehaviour | CiclicBehaviour ;
> Prova returns xbase::XExpression : {Prova} 'receive message do' '{'
> my compiler :
> switch expr {
> SendMessage : {
> newLine
> append('''
> «ENDIF»
> «ENDIF»
> «ENDFOR»
> send(«expr.name»);
> Prova : {
> append('''
> if (msg!=null){}
> default :
> if (hasName(obj))
> else super.internalToConvertedExpression(obj, it)
> IJvmDeclaredTypeAcceptor acceptor, boolean
> switch a {
> switch a {
> SimpleBehaviour : {
> superTypes +=
> body = [
> append('''
> super(agent);
> members +=
> body = a.body
> AgentJade : {
> members +=
> body = [append('''
> «ENDFOR»
> switch m {
> SendMessage : {
> append('''
> «ENDIF»
> «ENDIF»
> «ENDFOR»
> send(«m.name»);
> }//sendMe
> }//switch
> }//for
> ]//body
> }//agent jade
> }//switch
> }//for
> }//infer
> }//class
> my RuntimeModule :
> @Override
> my TypeComputer :
> state) {
> else {
> state) {
> Error :
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
> at
> at
> at
> at
> at
> at
> at
> at
Re: Error in extending xbase expressions [message #1045147 is a reply to message #1044812] Fri, 19 April 2013 17:11 Go to previous message
Thank you for help
Sebastian i did as you said and it seem work...
Previous Topic:Compile Xbase expression at arbitrary position using JvmModelInferrer and XbaseCompiler in Xtext 2.4
Next Topic:Two questions with regards to plantuml?
Current Time: Sun Jul 27 11:26:11 EDT 2025
Powered by FUDForum. Page generated in 0.05754 seconds
