Home » Modeling » TMF (Xtext) » Creating functions with named arguments
Creating functions with named arguments [message #1044131] Thu, 18 April 2013 10:28 Go to next message
I'm trying to define functions which accept named parameters, like in Python. For example:
function f(x, y):
    // something
// you can call f like this
f(1, 2)
// or naming the arguments
f(x=1, y=2)
f(y=2, x=1)
f(1, y=2)
// but you can't supply a non named argument after a named one
f(x=1, 2) // wrong
I came up with these rules for the function:
Function:
    'function' name=ID '(' parameters+=Parameter (',' parameters+=Parameter)* ')' ':'
    statements += Statement+
    'end'
Parameter:
    name = ID
FunctionCall:
    function=[Function] '(' (paramNames+=[Parameter] '=' )? paramValues+=INT (',' (paramNames+=[Parameter] '=' )? paramValues+=INT )* ')'
I also added a ScopeProvider to to provide the parameter names.
Now, how can I enforce the condition that once you give a named parameter in a function call, all subsequent parameters must also be named?
Re: Creating functions with named arguments [message #1044232 is a reply to message #1044131] Thu, 18 April 2013 12:43 Go to previous messageGo to next message
Some rules/condition are best "enforced" by the validator, not the grammar.
Hallvard
> function f(x, y):
> // something
> f(1, 2)
> f(x=1, y=2)
> f(y=2, x=1)
> f(1, y=2)
> f(x=1, 2) // wrong
> Function:
> 'end'
> Parameter:
> name = ID
> FunctionCall:
Re: Creating functions with named arguments [message #1044247 is a reply to message #1044232] Thu, 18 April 2013 13:05 Go to previous messageGo to next message
I agree, but I don't know how to do it from the validator. I need to verify which paramValues had a paramName before them, but I don't see how.
Re: Creating functions with named arguments [message #1044303 is a reply to message #1044247] Thu, 18 April 2013 14:44 Go to previous messageGo to next message
I am not doing this myself, but I would take a look at NodeModelUtils getPreviousSibling and getNextSibling functions. Maybe start with the function node/eobject, And from there get the child parameter list. Iterate through them. When you find a named parameter, validate that all consecutive parameters are also named.
Re: Creating functions with named arguments [message #1044655 is a reply to message #1044303] Fri, 19 April 2013 03:11 Go to previous messageGo to next message
NodeModelUtils is relevant if you *need* to access the parse model. In this use case this is not necessary, you can do everything with the semantic one. You could write a validation for a function call, iterate over all parameters and check whether they all have the same type.
Alex
Re: Creating functions with named arguments [message #1044973 is a reply to message #1044655] Fri, 19 April 2013 11:24 Go to previous messageGo to next message
Well, I actually found an easier solution based on the grammar, defining rules for named and non-named (positional) arguments:
FunctionCall:
    function=[Function] '(' args=ArgList ')'
ArgList:
    positionalArgs+=PositionalArgument (',' positionalArgs+=PositionalArgument)* (',' namedArgs+=NamedArgument)* |
    namedArgs+=NamedArgument (',' namedArgs+=NamedArgument)*
NamedArgument:
    paramName=[Parameter] '=' argument=INT
PositionalArgument:
    argument=INT
Re: Creating functions with named arguments [message #1046117 is a reply to message #1044973] Sun, 21 April 2013 07:35 Go to previous message
@Erick - Good job, I like it!
@Alexander - nevermind. I figured it out. But good point.
[Updated on: Sun, 21 April 2013 08:00] by Moderator
Previous Topic:Error with own editor opener
Next Topic:content assist grammar with external lexer
Current Time: Sat Jul 26 11:11:28 EDT 2025
Powered by FUDForum. Page generated in 0.05644 seconds
