Home » Modeling » GMF (Graphical Modeling Framework) » How to handle derived types using GMF?
How to handle derived types using GMF? [message #215218] Wed, 14 January 2009 10:54 Go to next message
I am getting the error "Can't find genClass for class 'A' in package
foo" when trying to create the generator model for a given set of .ecore
and .gmf* fiels. I believe the reason being, that I have a type B that
extends ("generalizes") from that type A.
Originally (and designwise correct) would be if type B simply extends
type A. Since type A then didn't show up at all in selection lists when
trying to generate the GMF mappings, I guessed, that GMF maybe only
includes leaf types (i.e. types not further derived from) as valid
selections. To correct that I defined a type "AbstractA" and now have
two types A and B deriving from it, where A only extends but doesn't add
anything to it (i.e. functionality wise it's the same as before, only
the class hierarchy has slightly changed). That way ALL types that I
want to later see and manipulate in the diagram are leaf types. But,
alas, that didn't help much since I now get the error message "Can't
find genClass for class 'AbstractA' in package foo".
Is GMF not able to cope with such class hierarchies? I would be very
amazed, if it wouldn't.
But if it does, then why am I getting this error and what do I have to
do to get this working?
This is using the latest GMF 2.1.2 (Sept. 17, 2008) version.
Michael
Re: How to handle derived types using GMF? [message #215443 is a reply to message #215218] Thu, 15 January 2009 15:28 Go to previous messageGo to next message
Michael,
I am also using GMF 2.1.2 to generate an editor. In my experience it
has no difficulty with hierarchies like you describe.
I can't tell exactly what's wrong with your models, but if I were were I
would check the following:
- was 'A' abstract?
- did I pick a containment feature whose type is restricted to 'B' when
it should have been generalized to 'A'?
- did I reload the .gmfmap file after making changes in my .ecore model?
Sounds like you forgot to reload the .genmodel after you modified the
..ecore model.
> Michael
Hope that helps,
Linda
Re: How to handle derived types using GMF? [message #215530 is a reply to message #215443] Fri, 16 January 2009 10:39 Go to previous messageGo to next message
Hello Linda, Michael,
> .ecore model.
Exactly. This is a usual reason of such problems.
Alex Shatalin
Re: How to handle derived types using GMF? [message #1044093 is a reply to message #215530] Thu, 18 April 2013 09:31 Go to previous message
Hello! I have the same problem! I do not try! Help please!
Previous Topic:Can't find genClass for class 'ATAGPlan' in package atagmetamodel' in package atagmetamodel
Next Topic:Best practice
Current Time: Mon Jul 21 04:11:27 EDT 2025
Powered by FUDForum. Page generated in 0.28482 seconds
