Home » Language IDEs » Java Development Tools (JDT) » Simple Remote Debugging
Simple Remote Debugging [message #104390] Tue, 14 October 2003 11:17 Go to next message
Originally posted by: rami.abramson.terayon.com
Hello all,
We are trying to remote debug a program "TasksServer", jdk1.3.1 .
Our launch command from the command line is:
java -Xdebug -Xnoagent -Djava.compiler=NONE
-Xrunjdwp:transport=dt_socket,address=RAMIA1-2k:4444 TasksServer
and we get:
Error [2] in connect() call!
err:: No such file or directory
Socket transport failed to init.
Transport dt_socket failed to initialize, rc = -1.
FATAL ERROR in native method: No transports initialized
We have tried our ports too and the result is the same.
Ofcourse when we try to connect from Eclipse we get:
-ERROR:Launching TasksServer: failed to connect to remote VM.
|-Establishing connection...
How can one remote debug?
thank you,
Gabby and Rami
Re: Simple Remote Debugging [message #104473 is a reply to message #104390] Tue, 14 October 2003 12:07 Go to previous messageGo to next message
Originally posted by: tma.zurich.ibm.com
try using the "server=y" flag when starting the program, as in:
-Xrunjdwp:transport=dt_socket,server=y,address=4444
Eclipse tries to connect to the VM, your command line asks the VM to
connecto to eclipse.
Thomas
Rami A. wrote:
> Hello all,
> and we get:
> thank you,
> Gabby and Rami
Re: Simple Remote Debugging [message #104910 is a reply to message #104473] Wed, 15 October 2003 03:30 Go to previous messageGo to next message
> Thomas
> Rami A. wrote:
> > Hello all,
> > and we get:
> > thank you,
> > Gabby and Rami
Thank you, it worked.
Re: Simple Remote Debugging [message #105739 is a reply to message #104910] Wed, 15 October 2003 15:33 Go to previous messageGo to next message
Originally posted by: joy.himmelfarb.trumbull-services.com
I am having a similar problem. I start WebLogic 7.0, adding the following
to the command line:
-Xdebug -Xrunjdwp:transport=dt_socket server=y suspend=n
The server starts without error, but when I try to launch a remote debug
session from Eclipse 2.1, I get a "Failed to connect to remote VM.
Connection refused" dialog.
Any help would be greatly appreciated.
Joy
"Rami A." <rami.abramson@terayon.com> wrote in message
news:bmit2g$e57$1@eclipse.org...
> Thomas M
Re: Simple Remote Debugging [message #105947 is a reply to message #105739] Thu, 16 October 2003 05:08 Go to previous message
It's -Xrunjdwp:transport=dt_socket,server=y,suspend=n (with commas
instead of spaces). The server VM seems to ignore extra arguments.
Previous Topic:Disabling stop on Error in jdt debugger
Next Topic:Problems with templates in M4
Current Time: Sun Nov 02 20:59:13 EST 2025
Powered by FUDForum. Page generated in 0.04693 seconds
