Home » Eclipse Projects » Eclipse Scout » scout sources checkout - problem with RWT.HYPERLINK
scout sources checkout - problem with RWT.HYPERLINK [message #1043842] Thu, 18 April 2013 03:23 Go to next message
I checked out the GIT sources of Scout RT.
Everything is ok except, that I have an error in
org.eclipse.scout.rt.ui.rap.mobile.form.fields.tablefield.RwtScoutList
and
org.eclipse.scout.rt.ui.rap.basic.table.RwtScoutTable
-> HYPERLINK cannot be resolved or is not a field
it refers to the line:
if (event.detail == RWT.HYPERLINK) {
Did I miss a dependency or what to do to solve this error?
-Rene
Re: scout sources checkout - problem with RWT.HYPERLINK [message #1043868 is a reply to message #1043842] Thu, 18 April 2013 04:05 Go to previous messageGo to next message
Have you set the correct target platform?
You can find them in
org.eclipse.scout.target
I think the current is eclipse-3.9.target
In my opinion we should describe all the necessary steps here:
http://wiki.eclipse.org/Scout/Contribution#Development_IDE_Configuration
Re: scout sources checkout - problem with RWT.HYPERLINK [message #1043894 is a reply to message #1043842] Thu, 18 April 2013 04:32 Go to previous messageGo to next message
Hi René,
This was a feature that was implemented in the RAP Bugzilla 347436 and was shipped RAP 2.1 M1.
As Jérémie already said, please have a look at the target file eclipse-3.9.target
The repository for RAP has been adjusted pointing to version 2.1
<repository id="rap_2.1" location="http://download.eclipse.org/rt/rap/2.1/"/>
If you set this target file, the compile errors should disappear.
Re: scout sources checkout - problem with RWT.HYPERLINK [message #1044070 is a reply to message #1043842] Thu, 18 April 2013 09:09 Go to previous messageGo to next message
Jérémy, Ken
Thanks - that was the problem.
+1 to add this to documentation Wink
Re: scout sources checkout - problem with RWT.HYPERLINK [message #1044180 is a reply to message #1044070] Thu, 18 April 2013 11:28 Go to previous messageGo to next message
René Eigenheer wrote on Thu, 18 April 2013 15:09
It is a wiki, you have write right... feel free to put your add your inputs.
Re: scout sources checkout - problem with RWT.HYPERLINK [message #1044195 is a reply to message #1044180] Thu, 18 April 2013 11:48 Go to previous message
Hi René
I'm writing the new documentation right now. But as I'm short in spare time so it's going to take some until I can release it. So if you could write this small addition I would appreciate it.
Thanks and greetings
Stephan
Previous Topic:Scalability concerns
Next Topic:JUnit version used by testing support?
Current Time: Sat Jul 26 11:46:20 EDT 2025
Powered by FUDForum. Page generated in 0.37502 seconds
