#include indexer problem [message #104245] |
Wed, 02 June 2004 02:06  |
Originally posted by: SpamBeGoneYug3sh.yahoo.com
I enabled the indexer problem reporting on my project, however, It flags
certain things as errors which shouldn't be.
Example...
My project dir is:
foo
I have an include file:
foo/general/h/example.h
I have a C file that includes the above file relative to the project root:
#include "./general/h/example.h"
My makefile specifies foo as a root include directory. Building the project
work fines (using the makefile I defined), however the indexer complains
about the include. If I use a path relative to the C file e.g.
#include "../../general/h/example.h"
then it works fine.
I tried tweaking the project include directories, but no go.
Any ideas on getting the indexer to work with this?
Re: #include indexer problem [message #104426 is a reply to message #104369] |
Wed, 02 June 2004 13:18   |
Yes, I did have scanner discovery on. I tried disabling it and still no go.
I don't think its a path input problem.... theres only one path, i.e. the
root project folder. since includes are relative to the root, I shouldn't
have to include any other paths.
"johnc" <jcamelon@ca.ibm.com> wrote in message
news:c9kn4r$1ke$1@eclipse.org...
> Are you using the scanner discovery feature?
> If so, it is a defect on that.
> Otherwise, you haven't inputted the correct paths necessary.
> JohnC
> "Yug3sh" <SpamBeGoneYug3sh@yahoo.com> wrote in message
> news:c9jq74$qol$1@eclipse.org...
> > Example...
> > My project dir is:
> > foo
root:
> project
> > then it works fine.
Re: #include indexer problem [message #104547 is a reply to message #104426] |
Thu, 03 June 2004 10:09   |
Is the compilation unit that is including this in the directory 'foo'? If
so, please make a small sample project demonstrating the problem and raise a
bug on CDT-Parser @ bugs.eclipse.org.
news:c9l1ip$i3f$1@eclipse.org...
go.
> > JohnC
flags
> > > Example...
> > > My project dir is:
> > > foo
> root:
> > project
complains
> > > then it works fine.
Re: #include indexer problem [message #104567 is a reply to message #104547] |
Thu, 03 June 2004 13:13  |
Yes it is in directory foo.
I'll make a sample and file a bug.
Thanks.
news:c9napm$c45$1@eclipse.org...
a
> go.
the
shouldn't
> > > JohnC
> flags
> > > > Example...
> > > > My project dir is:
> > > > foo
> > root:
> > > project
> complains
> > > > then it works fine.
FUDForum. Page generated in 0.04864 seconds
