BIRT Line Chart [message #1042529] |
Tue, 16 April 2013 10:39  |
I have a problem with the BIRT Line Chart. It seems that not all data is displayed in the Chart. I have y data for every 0,1 x value.
e.g. I have x=-2 y=5 , x=-1,9 y=5 , x=-1,8 y=4 ,...
I have a sum of about 90 values. In the Chart there are only about 10 displayed...
Attached is the PDF Export of the Chart. Between the points there are missing some, I think.
And I have another question, is it possible to move the y-axes a bit to the left?
So that it starts at x=-2.
Thanks for any help.
Regards Steffi
Attachment: preview.pdf
(Size: 39.90KB, Downloaded 335 times)
Re: BIRT Line Chart [message #1043591 is a reply to message #1042529] |
Wed, 17 April 2013 18:43  |
You can set the origin for the y-axis to be at the min instead of 0, in the format chart tab of the chart editor. For the missing values, you may have some sort of grouping set up on your x-axis. You might look at this in the select data tab by clicking on the grouping and sorting button next to the x-axis field expression. Hope this helps.
FUDForum. Page generated in 0.22712 seconds
