Home » Language IDEs » C / C++ IDE (CDT) » CDT2.0M9: Cannot launch CDI debugger
CDT2.0M9: Cannot launch CDI debugger [message #104304] Wed, 02 June 2004 07:20 Go to next message
Originally posted by: holger.casties.siemens.com
I am using CDT2.0M9 with Eclipse3.0M9 under Windows 2000 (with Cygwin).
The following trace appears when starting the debugger:
Failed Launching CDI Debugger
org.eclipse.cdt.debug.core.cdi.CDIException: Unable to set working
directory: mi_cmd_env_cd: Usage DIRECTORY
org.eclipse.cdt.debug.mi.core.cdi.RuntimeOptions.setWorkingD irectory(RuntimeOptions.java:101)
org.eclipse.cdt.launch.internal.LocalCLaunchConfigurationDel egate.launch(LocalCLaunchConfigurationDelegate.java:94)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:569)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:150)
org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(D ebugUIPlugin.java:796)
org.eclipse.debug.internal.ui.DebugUIPlugin$6.run(DebugUIPlu gin.java:959)
org.eclipse.core.internal.jobs.Worker.run(Worker.java:66)
Unable to set working directory: mi_cmd_env_cd: Usage DIRECTORY
What am I doing wrong?
Is there a special configuration necessary for the used GDB?
(-> Unable to set working directory: mi_cmd_env_cd: Usage DIRECTORY)
Best regards
Holger
Re: CDT2.0M9: Cannot launch CDI debugger [message #104342 is a reply to message #104304] Wed, 02 June 2004 07:55 Go to previous messageGo to next message
Originally posted by: mikhailkhod.rogers.com
Check if the path or file name of your executable contains space characters.
This is a bug in CDT.
"Holger Casties" <holger.casties@siemens.com> wrote in message
news:c9kd62$iqs$1@eclipse.org...
Options.java:101)
on.java:569)
on.java:150)
a:796)
Options.java:101)
on.java:569)
on.java:150)
a:796)
> Best regards
> Holger
Re: CDT2.0M9: Cannot launch CDI debugger [message #104496 is a reply to message #104342] Thu, 03 June 2004 04:15 Go to previous messageGo to next message
> > Hi,
> Options.java:101)
> on.java:569)
> on.java:150)
> a:796)
Hi Mikhail,
thanks a lot, CDT2.0M9 is now running with CDI debugger.
(The problem was a space in the path 'D:\Program Files\Eclipse\...'!)
Does CDT2.0M9 run with Eclipse3.0RC1?
Holger
Re: CDT2.0M9: Cannot launch CDI debugger [message #104557 is a reply to message #104496] Thu, 03 June 2004 10:09 Go to previous messageGo to next message
We haven't tested it, but I am using RC1 with CDT and it seems to work fine.
news:c9mmm9$g8m$1@eclipse.org...
characters.
> > > Hi,
Cygwin).
> > Options.java:101)
> > on.java:569)
> > on.java:150)
> > a:796)
> Hi Mikhail,
> Holger
Re: CDT2.0M9: Cannot launch CDI debugger [message #768984 is a reply to message #104342] Wed, 21 December 2011 02:41 Go to previous message
Thank you very much for this posting - I was pulling my hair out, but this saved me from going completely bald! Very Happy
Previous Topic:build project outside Eclipse
Next Topic:Static Library
Current Time: Fri Sep 05 04:14:06 EDT 2025
Powered by FUDForum. Page generated in 0.04439 seconds
