Update a CLOB field in a table [message #1042457] |
Tue, 16 April 2013 09:11  |
Hi all,
sometimes I have problems in updating a CLOB field on table in my database, becasue the SQL command is too long. This depends on the fact that the value that I have to save can be very long.
private String createSQLUpdateOrder(String idComm, String commission, String xmlOrder) {
return "UPDATE MyTable "
+ "SET CLOBField='" + xmlOrder + "' "
+ "WHERE OrderId='" + idComm + "' And Order='" + commission + "')";
public boolean saveOrderInformation(String xmlOrder, String commission, String idComm) {
int retval = 0;
try {
retval = SERVICES.getService(EDICCSqlService.class).update(createSQLUpdateOrder(idComm, commission, xmlOrder));
catch (ProcessingException e) {
e.printStackTrace();
System.out.println(e.getMessage());
retval = -1;
Probably I manage this kind of information in incorrectly way. Anyone has any suggestions?
Thanks in advance for your help
Re: Update a CLOB field in a table [message #1042506 is a reply to message #1042484] |
Tue, 16 April 2013 10:08   |
Hi Jeremie,
I try your code but I have the following error:
ProcessingException[ProcessingStatus[ERROR code=0 SQL with binds:
UPDATE MyTable
SET CLOBField = :xmlOrderBind
WHERE OrderId = :idCommBind
*** UNPARSED ***
) / Cannot find input for 'ValueInputToken[parsed 'CLOBField = :xmlOrderBind', replaced 'CLOBField = :xmlOrderBind']' in bind bases.]]
at org.eclipse.scout.rt.server.services.common.jdbc.internal.exec.StatementProcessor.createInput(StatementProcessor.java:862)
at org.eclipse.scout.rt.server.services.common.jdbc.internal.exec.StatementProcessor.<init>(StatementProcessor.java:131)
at org.eclipse.scout.rt.server.services.common.jdbc.AbstractSqlService.createStatementProcessor(AbstractSqlService.java:815)
at org.eclipse.scout.rt.server.services.common.jdbc.AbstractSqlService.update(AbstractSqlService.java:762)
at org.zeiss.mo.scout.CZVEDIController.server.services.process.OrderDetailsProcessService.saveOrderInformation(OrderDetailsProcessService.java:201)
at org.eclipse.scout.service.ServiceUtility.invoke(ServiceUtility.java:172)
at org.eclipse.scout.rt.server.DefaultTransactionDelegate.invokeImpl(DefaultTransactionDelegate.java:218)
at org.eclipse.scout.rt.server.DefaultTransactionDelegate.invoke(DefaultTransactionDelegate.java:92)
at org.eclipse.scout.rt.server.ServiceTunnelServlet.runServerJobTransactionWithDelegate(ServiceTunnelServlet.java:392)
at org.eclipse.scout.rt.server.ServiceTunnelServlet.runServerJobTransaction(ServiceTunnelServlet.java:388)
at org.eclipse.scout.rt.server.ServiceTunnelServlet$RemoteServiceJob.runTransaction(ServiceTunnelServlet.java:416)
at org.eclipse.scout.rt.server.ServerJob.runTransactionWrapper(ServerJob.java:202)
at org.eclipse.scout.rt.server.ServerJob.access$0(ServerJob.java:190)
at org.eclipse.scout.rt.server.ServerJob$1.run(ServerJob.java:161)
at org.eclipse.scout.rt.server.ServerJob$1.run(ServerJob.java:1)
at javax.security.auth.Subject.doAs(Unknown Source)
at org.eclipse.scout.rt.server.ServerJob.run(ServerJob.java:156)
at org.eclipse.scout.commons.job.JobEx.runNow(JobEx.java:50)
at org.eclipse.scout.rt.server.ServerJob.runNow(ServerJob.java:148)
at org.eclipse.scout.rt.server.ServiceTunnelServlet.doPost(ServiceTunnelServlet.java:297)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:755)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:848)
at org.eclipse.scout.http.servletfilter.HttpServletEx.access$0(HttpServletEx.java:1)
at org.eclipse.scout.http.servletfilter.HttpServletEx$1.service(HttpServletEx.java:38)
at org.eclipse.scout.http.servletfilter.internal.FilterChainImpl.doFilter(FilterChainImpl.java:44)
at org.eclipse.scout.http.servletfilter.helper.HttpAuthJaasFilter.doFilter(HttpAuthJaasFilter.java:62)
at org.eclipse.scout.http.servletfilter.internal.FilterChainImpl.doFilter(FilterChainImpl.java:41)
at org.eclipse.scout.http.servletfilter.helper.DevelopmentAuthFilter.doFilter(DevelopmentAuthFilter.java:61)
at org.eclipse.scout.http.servletfilter.security.AbstractChainableSecurityFilter.doFilter(AbstractChainableSecurityFilter.java:103)
at org.eclipse.scout.http.servletfilter.security.AbstractChainableSecurityFilter.doFilterInternal(AbstractChainableSecurityFilter.java:220)
at org.eclipse.scout.http.servletfilter.security.AbstractChainableSecurityFilter.access$0(AbstractChainableSecurityFilter.java:219)
at org.eclipse.scout.http.servletfilter.security.AbstractChainableSecurityFilter$1.run(AbstractChainableSecurityFilter.java:157)
at org.eclipse.scout.http.servletfilter.security.AbstractChainableSecurityFilter.doFilter(AbstractChainableSecurityFilter.java:149)
at org.eclipse.scout.http.servletfilter.ServletFilterDelegate.delegateServiceMethod(ServletFilterDelegate.java:57)
at org.eclipse.scout.http.servletfilter.HttpServletEx.service(HttpServletEx.java:35)
at org.eclipse.equinox.http.registry.internal.ServletManager$ServletWrapper.service(ServletManager.java:180)
at org.eclipse.equinox.http.servlet.internal.ServletRegistration.service(ServletRegistration.java:61)
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.processAlias(ProxyServlet.java:128)
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.service(ProxyServlet.java:60)
at org.eclipse.equinox.http.jetty.internal.HttpServerManager$InternalHttpServiceServlet.service(HttpServerManager.java:386)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:598)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:486)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:231)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1065)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:413)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:192)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:999)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:117)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:111)
at org.eclipse.jetty.server.Server.handle(Server.java:350)
at org.eclipse.jetty.server.AbstractHttpConnection.handleRequest(AbstractHttpConnection.java:454)
at org.eclipse.jetty.server.AbstractHttpConnection.content(AbstractHttpConnection.java:900)
at org.eclipse.jetty.server.AbstractHttpConnection$RequestHandler.content(AbstractHttpConnection.java:954)
at org.eclipse.jetty.http.HttpParser.parseNext(HttpParser.java:851)
at org.eclipse.jetty.http.HttpParser.parseAvailable(HttpParser.java:235)
at org.eclipse.jetty.server.AsyncHttpConnection.handle(AsyncHttpConnection.java:77)
at org.eclipse.jetty.io.nio.SelectChannelEndPoint.handle(SelectChannelEndPoint.java:606)
at org.eclipse.jetty.io.nio.SelectChannelEndPoint$1.run(SelectChannelEndPoint.java:46)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:603)
at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:538)
Used code is:
private String createSQLUpdateOrder() {
+ "SET CLOBField=:xmlOrderBind "
+ "WHERE OrderId=:idCommBind)";
public boolean saveOrderInformation(String xmlOrder1, String commission, String idComm) {
int retval = 0;
try {
createSQLUpdateOrder(),
new NVPair("xmlOrderBind", xmlOrder1),
new NVPair("idCommBind", idComm)
retval = -1;
catch (InvalidSyntaxException e) {
retval = -1;
[Updated on: Tue, 16 April 2013 10:11] by Moderator
FUDForum. Page generated in 0.03649 seconds
