Home » Archived » Hudson » Warnings plugin hanging
Warnings plugin hanging [message #1041538] Mon, 15 April 2013 04:19 Go to next message
The Warnings plugin (4.23-h-1) makes a job sit there for hours and days on this line, when "Java Compiler (Eclipse)" is selected as parser:
[WARNINGS] Parsing warnings in console log with parser Java Compiler (Eclipse)
Very annoying is that it is not possible to forcefully terminate the build. The only way to solve this is to restart Hudson. My guess is that the plugin does not check whether the thread running the job has been interrupted.
Here's an excerpt from a thread dump. It looks like the plugin is in an endless loop.
"Executor #0 for master : executing jFunk-gerrit-continuous #12" daemon prio=10 tid=0x00007f6a642b8000 nid=0xaff1 runnable [0x00007f6a8c2b8000]
   java.lang.Thread.State: RUNNABLE
	at java.util.regex.Pattern$BmpCharProperty.match(Pattern.java:3366)
	at java.util.regex.Pattern$Ques.match(Pattern.java:3691)
	at java.util.regex.Pattern$GroupHead.match(Pattern.java:4168)
	at java.util.regex.Pattern$Loop.match(Pattern.java:4295)
	at java.util.regex.Pattern$GroupTail.match(Pattern.java:4227)
	at java.util.regex.Pattern$Curly.match0(Pattern.java:3782)
	at java.util.regex.Pattern$Curly.match(Pattern.java:3744)
	at java.util.regex.Pattern$Loop.matchInit(Pattern.java:4311)
	at java.util.regex.Pattern$Prolog.match(Pattern.java:4251)
	at java.util.regex.Pattern$BranchConn.match(Pattern.java:4078)
	at java.util.regex.Pattern$Slice.match(Pattern.java:3482)
	at java.util.regex.Pattern$Branch.match(Pattern.java:4114)
	at java.util.regex.Pattern$Curly.match0(Pattern.java:3789)
	at java.util.regex.Pattern$Branch.match(Pattern.java:4112)
	at java.util.regex.Pattern$Start.match(Pattern.java:3055)
	at java.util.regex.Matcher.search(Matcher.java:1105)
	at java.util.regex.Matcher.find(Matcher.java:535)
	at hudson.plugins.warnings.parser.RegexpParser.findAnnotations(RegexpParser.java:86)
	at hudson.plugins.warnings.parser.RegexpDocumentParser.parse(RegexpDocumentParser.java:61)
	at hudson.plugins.warnings.parser.ParserRegistry.parse(ParserRegistry.java:313)
	at hudson.plugins.warnings.parser.ParserRegistry.parse(ParserRegistry.java:292)
	at hudson.plugins.warnings.WarningsPublisher.parseConsoleLog(WarningsPublisher.java:352)
	at hudson.plugins.warnings.WarningsPublisher.perform(WarningsPublisher.java:278)
	at hudson.plugins.analysis.core.HealthAwareRecorder.perform(HealthAwareRecorder.java:331)
	at hudson.tasks.BuildStepMonitor$1.perform(BuildStepMonitor.java:34)
	at hudson.model.AbstractBuild$AbstractRunner.perform(AbstractBuild.java:646)
	at hudson.model.AbstractBuild$AbstractRunner.performAllBuildSteps(AbstractBuild.java:624)
	at hudson.model.AbstractBuild$AbstractRunner.performAllBuildSteps(AbstractBuild.java:600)
	at hudson.model.Build$RunnerImpl.post2(Build.java:163)
	at hudson.model.AbstractBuild$AbstractRunner.post(AbstractBuild.java:566)
	at hudson.model.Run.run(Run.java:1414)
	at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:40)
	at hudson.model.ResourceController.execute(ResourceController.java:82)
	at hudson.model.Executor.run(Executor.java:137)
[Updated on: Mon, 15 April 2013 04:21] by Moderator
Re: Warnings plugin hanging [message #1041790 is a reply to message #1041538] Mon, 15 April 2013 11:29 Go to previous messageGo to next message
I'll take a look at this. Does it work with javac?
Re: Warnings plugin hanging [message #1041807 is a reply to message #1041790] Mon, 15 April 2013 11:54 Go to previous messageGo to next message
Reinhard, Could you file a bug for tracking
Re: Warnings plugin hanging [message #1042258 is a reply to message #1041807] Tue, 16 April 2013 03:30 Go to previous message
It does work for Javac.
Here's the ticket: https://bugs.eclipse.org/bugs/show_bug.cgi?id=405767
Previous Topic:hudson reloading configuration
Next Topic:Hudson Error while deploying in jboss as 7 container.
Current Time: Sun Jul 27 10:12:26 EDT 2025
Powered by FUDForum. Page generated in 0.08178 seconds
