JUnit version used by testing support? [message #1042214] |
Tue, 16 April 2013 02:01  |
I am facing problems writing tests using @BeforeClass and @AfterClass.
I get following stacktrace:
java.lang.NoClassDefFoundError: org/junit/internal/runners/model/MultipleFailureException
at org.eclipse.scout.testing.client.runner.ScoutClientTestRunner.withAfterClasses(ScoutClientTestRunner.java:153)
at org.junit.runners.ParentRunner.classBlock(ParentRunner.java:145)
at org.junit.runners.ParentRunner.run(ParentRunner.java:235)
at org.apache.maven.surefire.junit4.JUnit4TestSet.execute(JUnit4TestSet.java:53)
at org.apache.maven.surefire.junit4.JUnit4Provider.executeTestSet(JUnit4Provider.java:123)
at org.apache.maven.surefire.junit4.JUnit4Provider.invoke(JUnit4Provider.java:104)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.apache.maven.surefire.util.ReflectionUtils.invokeMethodWithArray(ReflectionUtils.java:164)
at org.apache.maven.surefire.booter.ProviderFactory$ProviderProxy.invoke(ProviderFactory.java:110)
at org.apache.maven.surefire.booter.SurefireStarter.invokeProvider(SurefireStarter.java:175)
at org.apache.maven.surefire.booter.SurefireStarter.runSuitesInProcess(SurefireStarter.java:123)
at org.eclipse.tycho.surefire.osgibooter.OsgiSurefireBooter.run(OsgiSurefireBooter.java:85)
at org.eclipse.tycho.surefire.osgibooter.HeadlessTestApplication.run(HeadlessTestApplication.java:21)
at org.eclipse.equinox.internal.app.EclipseAppContainer.callMethodWithException(EclipseAppContainer.java:587)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:198)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:620)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:575)
at org.eclipse.equinox.launcher.Main.run(Main.java:1408)
at org.eclipse.equinox.launcher.Main.main(Main.java:1384)
Caused by: java.lang.ClassNotFoundException: org.junit.internal.runners.model.MultipleFailureException
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:506)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:422)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:410)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
at java.lang.ClassLoader.loadClass(ClassLoader.java:247)
... 34 more
In my workspace I have this class in the junit.jar (located in the org.junit.source_4.8.2.v4_8_2_v20110321-1705 plugin).
I tried to add the package to the MANIFEST.MF
org.junit.internal.runners.model;version="4.8.2"
But this is not understood by the maven build. I get the error: "No solution found because the problem is unsatisfiable.".
Quick search in Google:
http://mavenhub.com/c/org/junit/runners/model/multiplefailureexception
In a plain maven project, I should have a dependency declared in the POM:
<dependency>
<groupId>junit</groupId>
<artifactId>junit</artifactId>
<version>4.9</version>
</dependency>
I tried to update my Manifest:
org.junit.internal.runners.model;version="[4.9.0,5.0.0)"
But I still get the "no solution problem" (is this because of Tycho ?):
[ERROR] Internal error: java.lang.RuntimeException: "No solution found because the problem is unsatisfiable.": ["Unable to satisfy dependency from org.eclipse.scout.rt.testing.client.test 3.9.0.qualifier to package org.junit [4.9.0,5.0.0).", "Unable to satisfy dependency from org.eclipse.scout.rt.testing.client.test 3.9.0.qualifier to package org.junit.runner [4.9.0,5.0.0).", "Unable to satisfy de
pendency from org.eclipse.scout.rt.testing.client.test 3.9.0.qualifier to package org.junit.runners.model [4.9.0,5.0.0).", "No solution found because the problem is unsatisfiable."] -> [Help 1]
org.apache.maven.InternalErrorException: Internal error: java.lang.RuntimeException: "No solution found because the problem is unsatisfiable.": ["Unable to satisfy dependency from org.eclipse.scout.rt.testing.client.test 3.9.0.qualifier to package org.junit [4.9.0,5.0.0).", "Unable to satisfy dependency from org.eclipse.scout.rt.testing.client.test 3.9.0.qualifier to package org.junit.runner [4.9.
0,5.0.0).", "Unable to satisfy dependency from org.eclipse.scout.rt.testing.client.test 3.9.0.qualifier to package org.junit.runners.model [4.9.0,5.0.0).", "No solution found because the problem is unsatisfiable."]
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:168)
at org.apache.maven.cli.MavenCli.execute(MavenCli.java:537)
at org.apache.maven.cli.MavenCli.doMain(MavenCli.java:196)
at org.apache.maven.cli.MavenCli.main(MavenCli.java:141)
at org.codehaus.plexus.classworlds.launcher.Launcher.launchEnhanced(Launcher.java:290)
at org.codehaus.plexus.classworlds.launcher.Launcher.launch(Launcher.java:230)
at org.codehaus.plexus.classworlds.launcher.Launcher.mainWithExitCode(Launcher.java:409)
at org.codehaus.plexus.classworlds.launcher.Launcher.main(Launcher.java:352)
Caused by: java.lang.RuntimeException: "No solution found because the problem is unsatisfiable.": ["Unable to satisfy dependency from org.eclipse.scout.rt.testing.client.test 3.9.0.qualifier to package org.junit [4.9.0,5.0.0).", "Unable to satisfy dependency from org.eclipse.scout.rt.testing.client.test 3.9.0.qualifier to package org.junit.runner [4.9.0,5.0.0).", "Unable to satisfy dependency from
at org.eclipse.tycho.p2.resolver.AbstractResolutionStrategy.newResolutionException(AbstractResolutionStrategy.java:81)
at org.eclipse.tycho.p2.resolver.ProjectorResolutionStrategy.resolve(ProjectorResolutionStrategy.java:88)
at org.eclipse.tycho.p2.resolver.AbstractResolutionStrategy.resolve(AbstractResolutionStrategy.java:58)
at org.eclipse.tycho.p2.impl.resolver.P2ResolverImpl.resolveDependencies(P2ResolverImpl.java:122)
at org.eclipse.tycho.p2.impl.resolver.P2ResolverImpl.resolveDependencies(P2ResolverImpl.java:78)
at org.eclipse.tycho.p2.resolver.P2TargetPlatformResolver.doResolvePlatform(P2TargetPlatformResolver.java:373)
at org.eclipse.tycho.p2.resolver.P2TargetPlatformResolver.resolveDependencies(P2TargetPlatformResolver.java:350)
at org.eclipse.tycho.core.resolver.DefaultTychoDependencyResolver.resolveProject(DefaultTychoDependencyResolver.java:109)
at org.eclipse.tycho.core.maven.TychoMavenLifecycleParticipant.afterProjectsRead(TychoMavenLifecycleParticipant.java:82)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:274)
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:156)
... 11 more
Sidenote:
It seems that with version 4.9, org.junit.internal.runners.model.MultipleFailureException has been depreciated and move to org.junit.runners.model.MultipleFailureException (see Javadoc: MultipleFailureException)
Re: JUnit version used by testing support? [message #1044572 is a reply to message #1043008] |
Fri, 19 April 2013 00:33   |
[ERROR] Internal error: java.lang.RuntimeException: "No solution found because the problem is unsatisfiable.": ["Unable to satisfy dependency from org.eclipse.scout.rt.testing.client.test 3.9.0.qualifier to package org.junit [4.9.0,5.0.0).", "Unable to satisfy dependency from org.eclipse.scout.rt.testing.client.test 3.9.0.qualifier to package org.junit.runner [4.9.0,5.0.0).", "Unable to satisfy de pendency from org.eclipse.scout.rt.testing.client.test 3.9.0.qualifier to package org.junit.runners.model [4.9.0,5.0.0).", "No solution found because the problem is unsatisfiable."] -> [Help 1]
Here some additional inputs (follow also the discussion on the bug):
Quote:> * If you are in a maven/tycho build, how do you control the JUnit version? It
> should be a maven/tycho configuration not? (I had the feeling that tycho was
> deducing the JUnit version using the version indicated in the Manifest).
It does deduce the junit version from your manifest files and uses the one available from the target-platform-configuration configuration.
If you want to get a newer version of JUnit in your target platform, you can get it from Orbit, by adding this code to your target file:
<location includeAllPlatforms="false" includeConfigurePhase="true" includeMode="planner" includeSource="true" type="InstallableUnit">
<unit id="org.junit" version="4.10.0.v4_10_0_v20120426-0900"/>
<repository location="http://download.eclipse.org/tools/orbit/downloads/drops/R20130118183705/repository/"/>
</location>
But it does not solve everything... org.eclipse.scout.rt.testing.shared.runner.AbstractRunAftersInSeparateScoutSession needs to be changed
[Updated on: Fri, 19 April 2013 02:12] by Moderator
FUDForum. Page generated in 0.04149 seconds
