Warnings plugin hanging [message #1041538] |
Mon, 15 April 2013 04:19  |
The Warnings plugin (4.23-h-1) makes a job sit there for hours and days on this line, when "Java Compiler (Eclipse)" is selected as parser:
[WARNINGS] Parsing warnings in console log with parser Java Compiler (Eclipse)
Very annoying is that it is not possible to forcefully terminate the build. The only way to solve this is to restart Hudson. My guess is that the plugin does not check whether the thread running the job has been interrupted.
Here's an excerpt from a thread dump. It looks like the plugin is in an endless loop.
"Executor #0 for master : executing jFunk-gerrit-continuous #12" daemon prio=10 tid=0x00007f6a642b8000 nid=0xaff1 runnable [0x00007f6a8c2b8000]
java.lang.Thread.State: RUNNABLE
at java.util.regex.Pattern$BmpCharProperty.match(Pattern.java:3366)
at java.util.regex.Pattern$Ques.match(Pattern.java:3691)
at java.util.regex.Pattern$GroupHead.match(Pattern.java:4168)
at java.util.regex.Pattern$Loop.match(Pattern.java:4295)
at java.util.regex.Pattern$GroupTail.match(Pattern.java:4227)
at java.util.regex.Pattern$Curly.match0(Pattern.java:3782)
at java.util.regex.Pattern$Curly.match(Pattern.java:3744)
at java.util.regex.Pattern$Loop.matchInit(Pattern.java:4311)
at java.util.regex.Pattern$Prolog.match(Pattern.java:4251)
at java.util.regex.Pattern$BranchConn.match(Pattern.java:4078)
at java.util.regex.Pattern$Slice.match(Pattern.java:3482)
at java.util.regex.Pattern$Branch.match(Pattern.java:4114)
at java.util.regex.Pattern$Curly.match0(Pattern.java:3789)
at java.util.regex.Pattern$Branch.match(Pattern.java:4112)
at java.util.regex.Pattern$Start.match(Pattern.java:3055)
at java.util.regex.Matcher.search(Matcher.java:1105)
at java.util.regex.Matcher.find(Matcher.java:535)
at hudson.plugins.warnings.parser.RegexpParser.findAnnotations(RegexpParser.java:86)
at hudson.plugins.warnings.parser.RegexpDocumentParser.parse(RegexpDocumentParser.java:61)
at hudson.plugins.warnings.parser.ParserRegistry.parse(ParserRegistry.java:313)
at hudson.plugins.warnings.parser.ParserRegistry.parse(ParserRegistry.java:292)
at hudson.plugins.warnings.WarningsPublisher.parseConsoleLog(WarningsPublisher.java:352)
at hudson.plugins.warnings.WarningsPublisher.perform(WarningsPublisher.java:278)
at hudson.plugins.analysis.core.HealthAwareRecorder.perform(HealthAwareRecorder.java:331)
at hudson.tasks.BuildStepMonitor$1.perform(BuildStepMonitor.java:34)
at hudson.model.AbstractBuild$AbstractRunner.perform(AbstractBuild.java:646)
at hudson.model.AbstractBuild$AbstractRunner.performAllBuildSteps(AbstractBuild.java:624)
at hudson.model.AbstractBuild$AbstractRunner.performAllBuildSteps(AbstractBuild.java:600)
at hudson.model.Build$RunnerImpl.post2(Build.java:163)
at hudson.model.AbstractBuild$AbstractRunner.post(AbstractBuild.java:566)
at hudson.model.Run.run(Run.java:1414)
at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:40)
at hudson.model.ResourceController.execute(ResourceController.java:82)
at hudson.model.Executor.run(Executor.java:137)
[Updated on: Mon, 15 April 2013 04:21] by Moderator
FUDForum. Page generated in 0.05692 seconds
