Home » Modeling » TMF (Xtext) » checking type conformance in Xbase 2.4
checking type conformance in Xbase 2.4 [message #1040951] |
Sun, 14 April 2013 07:08  |
in 2.3.1 one could use
org.eclipse.xtext.common.types.util.TypeConformanceComputer to check
conformance between two JvmTypeReferences
this is deprecated in Xtext 2.4.0, in favor, I seem to understand, of
org.eclipse.xtext.xbase.typesystem.conformance.TypeConformanceComputer
where isConformat wants two LightweightTypeReference instances which are
not compliant with JvmTypeReferences...
by looking at XbaseValidator I seem to understand that to use it with
JvmTypeReferences one should something like
@Inject CommonTypeComputationServices services;
def isConformant(JvmTypeReference t1, JvmTypeReference t2) {
t1.toLightweightTypeReference.isAssignableFrom
(t2.toLightweightTypeReference)
def toLightweightTypeReference(JvmTypeReference typeRef) {
val converter =
new OwnedConverter
(new StandardTypeReferenceOwner
(services, typeRef))
converter.toLightweightReference(typeRef)
is that correct? or is there a better way?
thanks in advance
Lorenzo
HOME: http://www.lorenzobettini.it
Re: checking type conformance in Xbase 2.4 [message #1041571 is a reply to message #1040951] |
Mon, 15 April 2013 05:01   |
Hi Lorenzo,
LightweightTypeReference.isAssignableFrom is the way to go. Where do you
need that functionality specifically?
Sebastian
Looking for professional support for Xtext, Xtend or Eclipse Modeling?
Am 14.04.13 13:08, schrieb Lorenzo Bettini:
> Hi
> val converter =
> new OwnedConverter
> thanks in advance
> Lorenzo
Re: checking type conformance in Xbase 2.4 [message #1041575 is a reply to message #1041571] |
Mon, 15 April 2013 05:09   |
On 04/15/2013 11:01 AM, Sebastian Zarnekow wrote:
> Hi Lorenzo,
> Regards,
> Sebastian
Hi Sebastian
in my custom validator I need to check whether two types are conformant,
and I have JvmTypeReference instances, for instance, they are part of a
method method definition in my DSL, e.g.,
Method:
type=JvmTypeReference name=ValidID
'(' (params+=FullJvmFormalParameter (','
params+=FullJvmFormalParameter)*)? ')'
thus I don't have LightweightTypeReference available.
Thus, I was wondering whether this code to convert a JvmTypeReference to
a LightweightTypeReference is the way to go or whether there are better
solutions:
val converter =
new OwnedConverter
thanks in advance
Lorenzo
Re: checking type conformance in Xbase 2.4 [message #1041676 is a reply to message #1041575] |
Mon, 15 April 2013 08:04   |
Am 15.04.13 11:09, schrieb Lorenzo Bettini:
>> Hi Lorenzo,
>> Regards,
>> Sebastian
> Hi Sebastian
> Method:
> solutions:
> val converter =
> new OwnedConverter
> thanks in advance
> Lorenzo
In 2.4, type checks are (usually) done as part of the model inference.
Why do you need to do that in the validator manually? If you use an
infered JVM model, those things will work transparently. Anyway, it's
easy to convert between JvmTypeReference and LightweightTypeReference as
you already sketched in you initial question.
Sebastian
Re: checking type conformance in Xbase 2.4 [message #1041701 is a reply to message #1041676] |
Mon, 15 April 2013 08:39  |
>>> Hi Lorenzo,
>>> Regards,
>>> Sebastian
>> Hi Sebastian
>> Method:
>> solutions:
>> val converter =
>> new OwnedConverter
>> thanks in advance
>> Lorenzo
because I need to check for consistencies two elements of my DSL which
represent methods (defined using JvmTypeReference)... would it be
possible to do that in the JvmModelInferrer? Wouldn't it be too late?
OK :)
thanks
Lorenzo
Current Time: Tue Jul 22 04:13:02 EDT 2025
Powered by FUDForum. Page generated in 0.04679 seconds
