Home » Eclipse Projects » Eclipse Scout » SVG Field in Swing and in SWT(Same code but different result between Swing and SWT)
icon3.gif  SVG Field in Swing and in SWT [message #1041558] Mon, 15 April 2013 04:48 Go to next message
Hi all,
I'm here again to mark a strange thing happens to me using a field SVG.
I use a SVG field to represent a set of points that indicate my form; I pass the following XML string to the SVG field:
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<svg xmlns="http://www.w3.org/2000/svg" version="1.1"><circle cx="114.488188975" cy="76.692913385" r="1" stroke="red" stroke-width="1" /><circle cx="211.6352088927718" cy="59.563272678074185" r="1" stroke="black" stroke-width="1" /><circle cx="209.3157529735557" cy="42.17850270155239" r="1" stroke="black" stroke-width="1" /><circle cx="191.0802939762989" cy="32.472440944700004" r="1" stroke="black" stroke-width="1" /><circle cx="174.4206109176706" cy="26.403640237343986" r="1" stroke="black" stroke-width="1" /><circle cx="159.6756518033286" cy="22.840592219122065" r="1" stroke="black" stroke-width="1" /><circle cx="147.18110236035" cy="20.067126354125172" r="1" stroke="black" stroke-width="1" /><circle cx="135.68805171689291" cy="18.446769206111867" r="1" stroke="black" stroke-width="1" /><circle cx="124.98911814399666" cy="17.13918469977591" r="1" stroke="black" stroke-width="1" /><circle cx="114.488188975" cy="17.354330708700004" r="1" stroke="black" stroke-width="1" /><circle cx="103.98725980600334" cy="17.13918469977591" r="1" stroke="black" stroke-width="1" /><circle cx="93.02979132162059" cy="17.736450374662" r="1" stroke="black" stroke-width="1" /><circle cx="81.03937007785001" cy="18.757859601966217" r="1" stroke="black" stroke-width="1" /><circle cx="67.843066055435" cy="21.103420568609884" r="1" stroke="black" stroke-width="1" /><circle cx="52.23953816497982" cy="24.460093449028754" r="1" stroke="black" stroke-width="1" /><circle cx="34.95023378134344" cy="30.771653543150002" r="1" stroke="black" stroke-width="1" /><circle cx="20.015784392169238" cy="42.30777015729562" r="1" stroke="black" stroke-width="1" /><circle cx="17.71337986151086" cy="59.62890348538038" r="1" stroke="black" stroke-width="1" /><circle cx="18.48818897640001" cy="76.69291338499998" r="1" stroke="black" stroke-width="1" /><circle cx="21.063277100054705" cy="93.16624601886353" r="1" stroke="black" stroke-width="1" /><circle cx="25.34317562804314" cy="109.13904477655561" r="1" stroke="black" stroke-width="1" /><circle cx="36.58681722154216" cy="121.6692913371" r="1" stroke="black" stroke-width="1" /><circle cx="53.976709815492" cy="127.46807322973481" r="1" stroke="black" stroke-width="1" /><circle cx="68.8148394495926" cy="131.1242917677153" r="1" stroke="black" stroke-width="1" /><circle cx="81.79527558964998" cy="133.31870041587482" r="1" stroke="black" stroke-width="1" /><circle cx="93.28832623310704" cy="134.93905756388813" r="1" stroke="black" stroke-width="1" /><circle cx="104.05289061330957" cy="135.87443126594144" r="1" stroke="black" stroke-width="1" /><circle cx="114.48818897499999" cy="136.4094488172" r="1" stroke="black" stroke-width="1" /><circle cx="124.98911814399665" cy="136.24664207022408" r="1" stroke="black" stroke-width="1" /><circle cx="135.68805171689291" cy="134.93905756388813" r="1" stroke="black" stroke-width="1" /><circle cx="146.9921259824" cy="132.99138372783509" r="1" stroke="black" stroke-width="1" /><circle cx="159.18976510624978" cy="129.96617733404054" r="1" stroke="black" stroke-width="1" /><circle cx="172.6834392671584" cy="125.52452644141964" r="1" stroke="black" stroke-width="1" /><circle cx="184.20664352746437" cy="116.94488188835004" r="1" stroke="black" stroke-width="1" /><circle cx="192.97841985020898" cy="105.26102110425819" r="1" stroke="black" stroke-width="1" /><circle cx="200.09667396000964" cy="91.7879990654327" r="1" stroke="black" stroke-width="1" /><circle cx="205.9527559028" cy="76.69291338500003" r="1" stroke="black" stroke-width="1" /><circle cx="371.496062987" cy="76.692913385" r="1" stroke="red" stroke-width="1" /><circle cx="468.27087210048916" cy="59.62890348538042" r="1" stroke="black" stroke-width="1" /><circle cx="465.96846756983075" cy="42.30777015729563" r="1" stroke="black" stroke-width="1" /><circle cx="451.0340181806566" cy="30.771653543150002" r="1" stroke="black" stroke-width="1" /><circle cx="433.7447137970202" cy="24.46009344902877" r="1" stroke="black" stroke-width="1" /><circle cx="418.141185906565" cy="21.103420568609884" r="1" stroke="black" stroke-width="1" /><circle cx="404.94488188415005" cy="18.757859601966224" r="1" stroke="black" stroke-width="1" /><circle cx="392.95446064037947" cy="17.736450374662" r="1" stroke="black" stroke-width="1" /><circle cx="381.9969921559967" cy="17.13918469977591" r="1" stroke="black" stroke-width="1" /><circle cx="371.496062987" cy="17.354330708700004" r="1" stroke="black" stroke-width="1" /><circle cx="360.99513381800335" cy="17.13918469977591" r="1" stroke="black" stroke-width="1" /><circle cx="350.2962002451071" cy="18.44676920611186" r="1" stroke="black" stroke-width="1" /><circle cx="338.80314960165003" cy="20.067126354125165" r="1" stroke="black" stroke-width="1" /><circle cx="326.3086001586714" cy="22.840592219122065" r="1" stroke="black" stroke-width="1" /><circle cx="311.5636410443294" cy="26.403640237343964" r="1" stroke="black" stroke-width="1" /><circle cx="294.90395798570114" cy="32.472440944700004" r="1" stroke="black" stroke-width="1" /><circle cx="276.6684989884443" cy="42.178502701552375" r="1" stroke="black" stroke-width="1" /><circle cx="274.34904306922823" cy="59.56327267807415" r="1" stroke="black" stroke-width="1" /><circle cx="280.03149605920004" cy="76.69291338499998" r="1" stroke="black" stroke-width="1" /><circle cx="285.8875780019904" cy="91.78799906543271" r="1" stroke="black" stroke-width="1" /><circle cx="293.005832111791" cy="105.26102110425813" r="1" stroke="black" stroke-width="1" /><circle cx="301.77760843453564" cy="116.94488188835001" r="1" stroke="black" stroke-width="1" /><circle cx="313.3008126948416" cy="125.52452644141961" r="1" stroke="black" stroke-width="1" /><circle cx="326.7944868557502" cy="129.9661773340405" r="1" stroke="black" stroke-width="1" /><circle cx="338.9921259796" cy="132.99138372783506" r="1" stroke="black" stroke-width="1" /><circle cx="350.29620024510706" cy="134.93905756388813" r="1" stroke="black" stroke-width="1" /><circle cx="360.99513381800335" cy="136.24664207022408" r="1" stroke="black" stroke-width="1" /><circle cx="371.496062987" cy="136.4094488172" r="1" stroke="black" stroke-width="1" /><circle cx="381.9313613486904" cy="135.87443126594144" r="1" stroke="black" stroke-width="1" /><circle cx="392.6959257288929" cy="134.93905756388813" r="1" stroke="black" stroke-width="1" /><circle cx="404.18897637235" cy="133.31870041587482" r="1" stroke="black" stroke-width="1" /><circle cx="417.1694125124074" cy="131.12429176771533" r="1" stroke="black" stroke-width="1" /><circle cx="432.007542146508" cy="127.46807322973484" r="1" stroke="black" stroke-width="1" /><circle cx="449.3974347404578" cy="121.66929133710003" r="1" stroke="black" stroke-width="1" /><circle cx="460.64107633395685" cy="109.13904477655569" r="1" stroke="black" stroke-width="1" /><circle cx="464.9209748619453" cy="93.16624601886352" r="1" stroke="black" stroke-width="1" /><circle cx="467.4960629856" cy="76.69291338500003" r="1" stroke="black" stroke-width="1" /></svg>
the code that use is as follows:
        String xmlSVG = "<?xml version=\"1.0\" encoding=\"UTF-8\" standalone=\"no\"?>\n" +
            "<svg xmlns=\"http://www.w3.org/2000/svg\" version=\"1.1\">" + xmlSVGR.trim() + xmlSVGL.trim() + "</svg>";
        try {
          SVGDocument doc = SVGUtility.readSVGDocument(new ByteArrayInputStream(xmlSVG.getBytes()));
          getShapeRField().setSvgDocument(doc);
        catch (ProcessingException e) {
          e.printStackTrace();
the result that I obtain in Swing is:
index.php/fa/14372/0/
the result that I obtain in SWT is:
index.php/fa/14373/0/
Can anyone help me to understand where is the problem or my mistake?
Thanks in advance for your help
  • Attachment: img_Swing.png
    (Size: 4.66KB, Downloaded 833 times)
  • Attachment: img_SWT.png
    (Size: 1.81KB, Downloaded 878 times)
Re: SVG Field in Swing and in SWT [message #1052912 is a reply to message #1041558] Wed, 01 May 2013 05:59 Go to previous messageGo to next message
hi marco
i tried to look at your problem with the svg field. however, using the svg document provided in your post and displaying it as described in the svg field tutorial [1], i was unable to reproduce this issue.
two questions:
1) do you have the same issue when you follow the svg field tutorial [1] with your svg document
2) exactely when and where do you set the content of the svg field, ie. please provide more context around the code snipped in your post
thanks
matthias
[1] http://wiki.eclipse.org/Scout/Tutorial/SVG_Field
Re: SVG Field in Swing and in SWT [message #1053048 is a reply to message #1052912] Thu, 02 May 2013 04:09 Go to previous messageGo to next message
Hi Matthias,
I followed the guidelines in this tutorial to develop my code. I use it in a private method where I obtained the data from an xml file.
The problem that I would draw attention is, against the same code, the user interface Swing and SWT have different results as I reported in my first post.
Re: SVG Field in Swing and in SWT [message #1053065 is a reply to message #1053048] Thu, 02 May 2013 06:13 Go to previous messageGo to next message
It is difficult to reproduce the case...
From the current screenshot I cannot tell if your SVG Field is cut in SWT (Layout problem) or if the content is not displayed correctly.
Can you try to set a background color on the field?
getShapeRField().setBackgroundColor("FF0000");
... and make screenshots (from Swing and SWT).
[Updated on: Thu, 02 May 2013 06:13] by Moderator
Re: SVG Field in Swing and in SWT [message #1053075 is a reply to message #1053065] Thu, 02 May 2013 06:41 Go to previous messageGo to next message
Hi Jeremie,
I make a test with your suggestion and this is the result:
        try {
          [b]getShapeRField().setBackgroundColor("FF0000");[/b]
          getShapeRField().setVisible(true);
          getNoShapeField().setVisible(false);
          getShapeRField().setVisible(false);
          getNoShapeField().setVisible(true);
here I report to you the properties of this field:
index.php/fa/14615/0/
this is the result in Swing user interface:
index.php/fa/14613/0/
this is the result in SWT user interface:
index.php/fa/14614/0/
Re: SVG Field in Swing and in SWT [message #1053081 is a reply to message #1053075] Thu, 02 May 2013 07:14 Go to previous messageGo to next message
It seems to me that the SWT Field does not react as we are expecting...
1. Bug:
SVG Field in SWT do not take into account the background color.
2. Problem: SWT Field Layout
I have seen you use
- Grid Use Ui Height => true
- Grid Use Ui Width => true
I am not sure what the effect is/should be... because a SVG Field do not have a child fields...
I have tried to use instead:
- Height In Pixel
- Width In Pixel
but without any luck in SWT.
I think that using:
- Grid H == 10
- Grid W == <number of column in the parent group box>
produces the best results.
Re: SVG Field in Swing and in SWT [message #1053090 is a reply to message #1053081] Thu, 02 May 2013 07:45 Go to previous messageGo to next message
Hi Jeremie,
I try with
- Grid H == 10
but the result is always the same.
Re: SVG Field in Swing and in SWT [message #1053135 is a reply to message #1053090] Thu, 02 May 2013 11:35 Go to previous messageGo to next message
I have no trouble whatsoever getting identical results with SVG under both SWT and Swing.
Looking at marco's code I see that his definition for the <xml> element are rather minimalistic:
In my SVG drawings I use the following attributes for my <xml> element:
<svg width="400" height="400" viewBox="0 0 400 400" xmlns="http://www.w3.org/2000/svg" xmlns:xlink="http://www.w3.org/1999/xlink" contentScriptType="text/ecmascript" zoomAndPan="magnify" contentStyleType="text/css" version="1.1" xml:space="preserve" preserveAspectRatio="xMidYMid meet">
Marco, can you try to see if things look better if you use the longer version? You might need to adjust the width, height and viewBox parameters to fit your drawing.
Re: SVG Field in Swing and in SWT [message #1053238 is a reply to message #1053135] Fri, 03 May 2013 06:19 Go to previous messageGo to next message
Hi Urs,
I followed your suggestion and after changing the values ​​according to my needs, I got more or less the same result on Swing and SWT user interface.
However, the result is improved, at least the design is seen complete in both cases.
Thank you for your help
Re: SVG Field in Swing and in SWT [message #1053471 is a reply to message #1053238] Mon, 06 May 2013 03:44 Go to previous message
I'm glad you've got it working.
Previous Topic:howto add a new button to toolbar
Next Topic:SWT: Switching between SearchForm/TableForm-Pairs does not work
Current Time: Sat Jul 26 03:29:19 EDT 2025
Powered by FUDForum. Page generated in 0.30299 seconds
