Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » Equality, hashcodes, EMF and Hibernate
Equality, hashcodes, EMF and Hibernate [message #1040657] |
Sat, 13 April 2013 20:09  |
I KNOW that this has been addressed before somewhere, but remain at an
impasse. EMF framework depends on user not overriding the
equal/hashCode methods of objects, and Hibernate encourages overriding
these methods. The main purpose from Hibernate standpoint is assuring
that Java equality not override SQL record equality.
In EMF model, I have an object (Patient) that contains clinical
decisions made about the patient (Decisions). I do not want duplicate
decisions in my database, and these are defined as decisions with the
same attribute A and attribute B.
In my eCore model I have added attributes A and B to the EKeys property
of the relation between Patient and Decisions. But I can add objects
all day long and there is no error or prevention.
I really appreciate your help. I am a newbie to this, but have tried
hard to find the answer.
- Mike
Re: Equality, hashcodes, EMF and Hibernate [message #1040780 is a reply to message #1040657] |
Sun, 14 April 2013 01:07   |
Mike,
You can use Diagnostician.INSTANCE to validate your instances. Of
course even if you could override equals, there would be nothing to
prevent logic that added a Decision and then changed the A and B
attribute values to cause a duplicate. I.e., this isn't a constraint
you can generally expect to be always fail fast enforceable so better to
assume you need to do a validity check at some point, i.e., before saving.
> property of the relation between Patient and Decisions. But I can add
> objects all day long and there is no error or prevention.
> - Mike
Re: Equality, hashcodes, EMF and Hibernate [message #1040784 is a reply to message #1040657] |
Mike,
> - Mike
Re: Equality, hashcodes, EMF and Hibernate [message #1040788 is a reply to message #1040657] |
Mike,
> - Mike
Re: Equality, hashcodes, EMF and Hibernate [message #1040792 is a reply to message #1040657] |
Mike,
> - Mike
Re: Equality, hashcodes, EMF and Hibernate [message #1040796 is a reply to message #1040657] |
Mike,
> - Mike
Re: Equality, hashcodes, EMF and Hibernate [message #1040800 is a reply to message #1040657] |
Mike,
> - Mike
Re: Equality, hashcodes, EMF and Hibernate [message #1040804 is a reply to message #1040657] |
Mike,
> - Mike
Re: Equality, hashcodes, EMF and Hibernate [message #1040809 is a reply to message #1040657] |
Mike,
> - Mike
Re: Equality, hashcodes, EMF and Hibernate [message #1041211 is a reply to message #1040657] |
Sun, 14 April 2013 16:21  |
Hi Michael,
EKeys are not transferred to the hibernate mapping. You can define/use the jpa unique constraint annotation for this, so
the unique constraints are enforced by the model then.
I would only override the equals/hashcode methods if you have a direct need for that.
gr. Martin
On 04/14/2013 02:09 AM, J. Michael Dean wrote:
> I KNOW that this has been addressed before somewhere, but remain at an impasse. EMF framework depends on user not
> overriding the equal/hashCode methods of objects, and Hibernate encourages overriding these methods. The main purpose
> from Hibernate standpoint is assuring that Java equality not override SQL record equality.
> In EMF model, I have an object (Patient) that contains clinical decisions made about the patient (Decisions). I do not
> want duplicate decisions in my database, and these are defined as decisions with the same attribute A and attribute B.
> In my eCore model I have added attributes A and B to the EKeys property of the relation between Patient and Decisions.
> But I can add objects all day long and there is no error or prevention.
> I really appreciate your help. I am a newbie to this, but have tried hard to find the answer.
> - Mike
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Current Time: Sat Jul 26 20:31:04 EDT 2025
Powered by FUDForum. Page generated in 0.06137 seconds
