Home » Archived » Visual Editor (VE) » problem to debug VE into eclipse 3.1.0 ?
problem to debug VE into eclipse 3.1.0 ? [message #104027] |
Sun, 28 August 2005 19:50  |
Originally posted by: stephane.mascaron.net
i want to understand how the VE is working inside, so i decide to
install the source code, but....
I've installed ve-dev-base from cvs repository, but when i try
to execute the debug mode, i have this error below ?
I haven't found help to set the parameters in the debug mode dialog
box.... someone can help me ?
thank's !
Adichatz ;o) (french old language to said good bye)
S.M.
!SESSION 2005-08-29 01:37:25.203
eclipse.buildId=unknown
java.version=1.5.0_01
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=fr_FR
Framework arguments: -product org.eclipse.sdk.ide -pdelaunch
Command-line arguments: -product org.eclipse.sdk.ide -data
C:\Eclipse3.1-Foundation\eclipse\runtime-EclipseApplication -dev
file:C:/Eclipse3.1-Foundation/eclipse/workspace/.metadata/.p lugins/org.eclipse.pde.core/Eclipse
Application/dev.properties -pdelaunch -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.osgi 2005-08-29 01:37:26.46
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: Application "org.eclipse.ui.ide.workbench"
could not be found in the registry. The applications available are:
org.eclipse.help.base.infocenterApplication,
org.eclipse.help.base.helpApplication, org.eclipse.help.base.indexTool,
org.eclipse.ant.core.antRunner.
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:216)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
Re: problem to debug VE into eclipse 3.1.0 ? [message #104045 is a reply to message #104027] |
Mon, 29 August 2005 02:00   |
download ve-sdk and call runtime workbench in debug mode
stephane mascaron wrote:
> thank's !
> S.M.
> !STACK 1
> at
> at
> at
Re: problem to debug VE into eclipse 3.1.0 ? [message #104054 is a reply to message #104045] |
Mon, 29 August 2005 04:57   |
My Eclipse config :
Eclipse 3.1.0
EMF 2.1.0
JEM 1.1.0
VE SDK 1.1.0
I have downloaded VE-SDK, my debug mode config is :
Workspace data
- clear workspace data before launching is checked
Program to run
- run an application : org.eclipse.ide.workbench (checked)
or
- run a product : org.eclipse.sdk.ide (disabled)
for the both choice i have an error.
when i define in the second tab of the dialog box :
- Choose plug-ins and frangments to launch from the list is checked,
with the button "Add Required Plug-ins" and the test button
named "Validate Plug in Set" i check all the plug-ins wich is
necessary to debug the ve-dev-base project (in the list
of my wrokspace project is called "org.eclipse.jem (1.1.0.1)"
But an other error below said to me NO ! i can't ... Grrrr ;o)
please help, or give me an url where the VE dev base installation is
describe... thank's
for more information : VE plug-in is OK and work fine on my eclipse, but
i can't develop into ve source code. Where is the source code, because
in the ve-de-base i don't found Palette class, widget class....?
ve-de-base is linked automatically with ve-sdk in the
plug-ins directory ?
Adichatz ;o)
S.M.
!SESSION 2005-08-29 10:43:08.46
java.version=1.4.2_07
Framework arguments: -application org.eclipse.ui.ide.workbench -pdelaunch
Command-line arguments: -application org.eclipse.ui.ide.workbench -data
!ENTRY org.eclipse.osgi 2005-08-29 10:43:08.843
!MESSAGE An error occurred while automatically activating bundle
org.eclipse.ui.workbench (474).
!STACK 0
org.osgi.framework.BundleException: The activator
org.eclipse.ui.internal.WorkbenchPlugin for bundle
org.eclipse.ui.workbench is invalid
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:151)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:965)
at
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:321)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:266)
at
org.eclipse.core.runtime.adaptor.EclipseClassLoader.findLoca lClass(EclipseClassLoader.java:116)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:337)
at
org.eclipse.osgi.framework.internal.core.SingleSourcePackage .loadClass(SingleSourcePackage.java:37)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:386)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:350)
at
org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. loadClass(AbstractClassLoader.java:78)
at java.lang.ClassLoader.loadClass(ClassLoader.java:235)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:302 )
at java.lang.ClassLoader.defineClass0(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:539)
at
org.eclipse.osgi.framework.adaptor.core.DefaultClassLoader.d efineClass(DefaultClassLoader.java:370)
at
org.eclipse.core.runtime.adaptor.EclipseClassLoader.defineCl ass(EclipseClassLoader.java:227)
at
org.eclipse.osgi.framework.adaptor.core.DefaultClassLoader.f indClassImpl(DefaultClassLoader.java:343)
at
org.eclipse.osgi.framework.adaptor.core.DefaultClassLoader.f indClass(DefaultClassLoader.java:235)
at
org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. findLocalClass(AbstractClassLoader.java:183)
at
org.eclipse.core.runtime.adaptor.EclipseClassLoader.basicFin dLocalClass(EclipseClassLoader.java:141)
at
org.eclipse.core.runtime.adaptor.EclipseClassLoader.findLoca lClass(EclipseClassLoader.java:82)
at
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:389)
at
at
at
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:275)
at
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:144)
at
at
at
at
at
at
at
at
at
at
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1259)
at
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:152)
at
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:142)
at
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:129)
at
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 48)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:222)
at
at
at
at
at java.lang.reflect.Method.invoke(Method.java:324)
Caused by: java.lang.NoClassDefFoundError: org/eclipse/swt/SWTError
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Class.java:16 18)
at java.lang.Class.getConstructor0(Class.java:1930)
at java.lang.Class.newInstance0(Class.java:278)
at java.lang.Class.newInstance(Class.java:261)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:146)
... 55 more
Root exception:
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.osgi 2005-08-29 10:43:08.937
org.eclipse.ui.ide (817).
!STACK 0
org.eclipse.ui.internal.ide.IDEWorkbenchPlugin for bundle
org.eclipse.ui.ide is invalid
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
org/eclipse/ui/plugin/AbstractUIPlugin
at
at
at
at
at
at
at
at
at
at
at
at
at
at
... 27 more
Root exception:
java.lang.NoClassDefFoundError: org/eclipse/ui/plugin/AbstractUIPlugin
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!STACK 1
org.eclipse.core.runtime.CoreException[1]:
java.lang.ClassNotFoundException: org.eclipse.ui.internal.ide.IDEApplication
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:403)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
>>Hi,
>>thank's !
>>S.M.
>>!STACK 1
>>at
>>at
>>at
>>at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
Re: problem to debug VE into eclipse 3.1.0 ? [message #104069 is a reply to message #104054] |
Mon, 29 August 2005 05:26   |
i decide to re-install ve-dev-base from CVS, i think
the checkout is not correctly execute the last time.
So before, i disable the plug-ins in my Eclipse with
Window --> Preference --> Plug-ins Development --> Target Platefom
And now when i check out from CVS, i have 12 projects for ve-dev-base
and not just one....
Thank's
I try
Adichatz ;o)
Stephane.
stephane mascaron a écrit :
> My Eclipse config :
> Eclipse 3.1.0
> EMF 2.1.0
> JEM 1.1.0
> VE SDK 1.1.0
> Workspace data
> Program to run
> or
> describe... thank's
> Adichatz ;o)
> S.M.
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 55 more
> Root exception:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 27 more
> Root exception:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 1
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
>>> Hi,
>>> thank's !
>>> S.M.
>>> !STACK 1
>>> at
>>> at
>>> at
Re: problem to debug VE into eclipse 3.1.0 ? [message #104125 is a reply to message #104027] |
Mon, 29 August 2005 10:47  |
Yes !! it is working the debug mode with the VE..
now i think it's an other game to understand how the Ve
is write... ;op specially the EMF framework...
When i drag a button on the shell, Eclipse suspend
the thread and i can see the source code is executing
.... cool ...
thank's
Adichatz ;o)
S.M.
> thank's !
> S.M.
> !STACK 1
> at
> at
> at
Re: problem to debug VE into eclipse 3.1.0 ? [message #610421 is a reply to message #104027] |
> thank's !
> S.M.
> !STACK 1
> at
> at
> at
Re: problem to debug VE into eclipse 3.1.0 ? [message #610422 is a reply to message #104045] |
My Eclipse config :
Eclipse 3.1.0
EMF 2.1.0
JEM 1.1.0
VE SDK 1.1.0
Workspace data
Program to run
or
describe... thank's
Adichatz ;o)
S.M.
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
... 55 more
Root exception:
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
... 27 more
Root exception:
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!STACK 1
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
>>Hi,
>>thank's !
>>S.M.
>>!STACK 1
>>at
>>at
>>at
Re: problem to debug VE into eclipse 3.1.0 ? [message #610423 is a reply to message #104054] |
Thank's
I try
Adichatz ;o)
Stephane.
> My Eclipse config :
> Eclipse 3.1.0
> EMF 2.1.0
> JEM 1.1.0
> VE SDK 1.1.0
> Workspace data
> Program to run
> or
> describe... thank's
> Adichatz ;o)
> S.M.
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 55 more
> Root exception:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 27 more
> Root exception:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 1
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
>>> Hi,
>>> thank's !
>>> S.M.
>>> !STACK 1
>>> at
>>> at
>>> at
Re: problem to debug VE into eclipse 3.1.0 ? [message #610427 is a reply to message #104027] |
.... cool ...
thank's
Adichatz ;o)
S.M.
> thank's !
> S.M.
> !STACK 1
> at
> at
> at
Current Time: Fri Jul 18 09:02:44 EDT 2025
Powered by FUDForum. Page generated in 0.26298 seconds
