Home » Archived » BIRT » Using BIRT with a J2EE application
Using BIRT with a J2EE application [message #104014] Wed, 04 January 2006 11:20 Go to next message
We are planning to use BIRT bundled along with our Application that runs on
a J2EE server.
The reports will be integrated along with the application. I need to know
how to pass the authorization
and authentication information (login info into birt so that I can restrict
the data based on the user login).
Dwarakanath
Re: Using BIRT with a J2EE application [message #104182 is a reply to message #104014] Wed, 04 January 2006 13:17 Go to previous messageGo to next message
Dwarakanath,
You have a couple of options.
You can set the username and password as parameters
and use this from the faq
Is it possible getting database's information from a DataSource? object with
the API?
Gary Xue
The best way to achieve this is to edit the beforeOpen script of the data
source object to set the runtime information of the data source. To do this,
right click on your JDBC data source and select "Edit Code". In the method
dropdown list, select "beforeOpen". In the code editor, write a script like
this:
extensionProperties.odaUser = "sesame";
extensionProperties.odaPassword = "open";
extensionProperties.odaURL = "jdbc:my_data_source:....";
extensionProperties.odaDriverClass = "com.mycompany.jdbc.Driver";
OR
add a Java object with the credentials and use JavaScript within BIRT to set
look at birtworld.blogspot.com
"Using Embedded Java Objects within BIRT"
You can also look at writting or extending your own ODA
"Using a supplied connection with BIRT "
and
BPS35
http://www.eclipse.org/birt/wiki/index.php?n=BPS.BPS35
Hope this helps
Jason Weathersby
BIRT PMC
"Dwarakanath" <dcheyyur@orangescape.com> wrote in message
news:dpgsko$a32$1@utils.eclipse.org...
> Hi
> on a J2EE server.
> restrict the data based on the user login).
> Regards
> Dwarakanath
Re: Using BIRT with a J2EE application [message #104806 is a reply to message #104182] Thu, 05 January 2006 07:58 Go to previous messageGo to next message
Hi Jason,
I think I didn't convey my requirement properly. At present we
Use the BIRT IDE to develop reports and deploy them as web applications.
It is necessary to obtain the current user (i.e, the user
who is executing the report at runtime - which is an instance of
javax.security.Principal) information so that I can restrict the data
being shown in the report. I assume, I need to add some kind of scripting
code during report design. where and how is what I don't know.
I hope I am clear now.
Dwarakanath
"Jason Weathersby" <jweathersby@actuate.com> wrote in message
news:dph3gs$mh3$1@utils.eclipse.org...
> Dwarakanath,
> with the API?
> Gary Xue
> this, right click on your JDBC data source and select "Edit Code". In the
> method dropdown list, select "beforeOpen". In the code editor, write a
> script like this:
> OR
> and
> BPS35
> Hope this helps
> Jason Weathersby
> BIRT PMC
>> Hi
>> on a J2EE server.
>> Regards
>> Dwarakanath
Re: Using BIRT with a J2EE application [message #104953 is a reply to message #104806] Thu, 05 January 2006 14:37 Go to previous message
Dwarakanath,
You can call out to Java from BIRT. From the FAQ
the API?
Gary Xue
this:
Another way that 2.0 RC gives you is by using the Property Binding selection
in the Edit Data Source Wizard. You could set the User Name to a
parameter.This would require no code.Jason"Dwarakanath"
news:dpj588$uit$1@utils.eclipse.org...
> Hi Jason,
> Regards
> Dwarakanath
>> Dwarakanath,
>> with the API?
>> Gary Xue
>> script like this:
>> OR
>> and
>> BPS35
>> Hope this helps
>> Jason Weathersby
>> BIRT PMC
>>> Hi
>>> on a J2EE server.
>>> know how to pass the authorization
>>> Regards
>>> Dwarakanath
Previous Topic:Exception found to load report and generate PDF
Next Topic:pagebreaks and report documents in BIRT 2.0RC
Current Time: Tue Jul 22 13:12:08 EDT 2025
Powered by FUDForum. Page generated in 0.03378 seconds
