Home » Archived » Hudson » Duplicate checkout using SVN and multiconfiguration project
Duplicate checkout using SVN and multiconfiguration project [message #1039628] Fri, 12 April 2013 07:31 Go to next message
I have a multiconfiguration project and configured SVN as SCM provider.
My configuration contains a node setup as an axis, when running the job I get in the workspace two checkouts.
One is the checkout into the workspace itself and one is the checkout of the axis.
Log of the job on the master:
Started by user anonymous
Building on master
Checking out a fresh workspace because there's no workspace at /var/lib/hudson/jobs/K4_Init/workspace
Cleaning workspace /var/lib/hudson/jobs/K4_Init/workspace
Checking out http://codeserver/svn/code/trunk revision: Apr 12, 2013 2:22:52 PM depth:infinity ignoreExternals: true
A         tests
AU        tools/obcp/getParameterID.sh
At revision 3188
no change for http://codeserver/svn-dlr/code/trunk since the previous build
Triggering master
Log of the job on the master as slave:
Started by upstream job "K4_Init" build number 48
Building on master
Checking out a fresh workspace because there's no workspace at /var/lib/hudson/jobs/K4_Init/workspace/slave/master
Cleaning workspace /var/lib/hudson/jobs/K4_Init/workspace/slave/master
A         build
In my opinion it is wrong, but what do you think?
[Updated on: Thu, 24 October 2013 12:10] by Moderator
Re: Duplicate checkout using SVN and multiconfiguration project [message #1039639 is a reply to message #1039628] Fri, 12 April 2013 07:44 Go to previous messageGo to next message
Would it be possible to get a copy of your config.xml file? You can email it to me: schristou88@gmail.com
Re: Duplicate checkout using SVN and multiconfiguration project [message #1039654 is a reply to message #1039628] Fri, 12 April 2013 08:03 Go to previous messageGo to next message
Interesting is the behaviour of the executors.
When I start the job and the "slave" isn't running only the checkout the status is shown like 0/4+1.
When the slave itselfs runs it looks like 1/4+1.
I have sent you a mail.
Is there no possibility to upload any files here?
Re: Duplicate checkout using SVN and multiconfiguration project [message #1153447 is a reply to message #1039654] Thu, 24 October 2013 12:11 Go to previous messageGo to next message
Any news on this topic?
Re: Duplicate checkout using SVN and multiconfiguration project [message #1159810 is a reply to message #1153447] Mon, 28 October 2013 16:12 Go to previous messageGo to next message
Christian, curious, are you setting up master as slave node axis? If so what is the reason?
Also since you have setup master as a slave node axis, the second checkout happens under "K4_Init/workspace/slave/master", where as the first one was under "K4_Init/workspace". Though I don't know the reason why you setup the slave node axis as master, the ckeckout behavior seems to be correct to me.
Re: Duplicate checkout using SVN and multiconfiguration project [message #1159976 is a reply to message #1039628] Mon, 28 October 2013 18:41 Go to previous messageGo to next message
Yes I have selected it there. I thought I have to do it, otherwise the svn checkout isn't executed on the master as well.
I have created some additional steps to prepare the build environment. So the best solution is to move them into an own job and keep the checkout alone in one job?
Re: Duplicate checkout using SVN and multiconfiguration project [message #1160155 is a reply to message #1159976] Mon, 28 October 2013 21:35 Go to previous message
For that purpose you could use Matrix Tie Parent Plugin. This plugin ties the parent build of a multi-configuration job to a particular node (namely master).
Previous Topic:Plugin - Grinder patch
Next Topic:Independent push and poll configuration
Current Time: Sat Jul 26 23:14:59 EDT 2025
Powered by FUDForum. Page generated in 0.08180 seconds
