Home » Archived » Test and Performance Tools Platform (TPTP) » AGR - Defining the name of the generated .execution file
AGR - Defining the name of the generated .execution file [message #103417] Fri, 06 July 2007 18:01 Go to next message
Originally posted by: chalmers.wang.oracle.com
Hi Everyone,
I was wondering if there is a way for the programmer to define the name of
the .execution file that is generated. Currently, my .execution files are
being named <test-suite>_<milliseconds since 19??>.execution. I'd prefer
to change it to <test-suite>_<year>_<month>_<date>.execution. Thanks in
advance.
Chalmers
Re: AGR - Defining the name of the generated .execution file [message #103590 is a reply to message #103417] Mon, 09 July 2007 07:05 Go to previous messageGo to next message
Hi Chalmers,
Yes. When you create a launch configuration for a test, select the
'Test Logs' tab, de-select 'Use defaults' and type in the name of the test
log in the 'Name' field. The millisecond timestamp is appended to test logs
only when a test log with the same name currently exists on the local file
system.
Paul
"Chalmers Wang" <chalmers.wang@oracle.com> wrote in message
news:4d7b6d50665b752ff2af276d956e8a01$1@www.eclipse.org...
> Hi Everyone,
> advance.
> Chalmers
Re: AGR - Defining the name of the generated .execution file [message #103951 is a reply to message #103590] Mon, 09 July 2007 18:09 Go to previous messageGo to next message
Hi Paul,
Is there any way to define the name programatically? I know that in order
to invoke AGR within a Java program, you need to set a number of
properties before telling the automation client adapter to execute a
command. Is there a property that I can set to give the name of the file?
Basically, I am not manually invoking the AGR so I most likely will not be
able to use the method you have suggested.
Chalmers
Paul Slauenwhite wrote:
> Hi Chalmers,
> system.
> Paul
>> Hi Everyone,
>> advance.
>> Chalmers
Re: AGR - Defining the name of the generated .execution file [message #104020 is a reply to message #103951] Tue, 10 July 2007 09:16 Go to previous message
Hi Chalmers,
The property is called "results", and is described in the help for the
Automatable Services Framework. For example, from ant you could use:
<tptp:execution
project="org.eclipse.tptp.test.testservices.tests"
resultsrefid="tptp.test.results1"
results="junit_results/Windows_IA32/Test.Sun142_TestServicesResult "
suite="junit/Test.Sun142_TestServices.testsuite"
If you're invoking from java or commandline, the property name is the same.
Hope this helps,
--Joe
Chalmers Wang wrote:
> Hi Paul,
> order to invoke AGR within a Java program, you need to set a number of
> file? Basically, I am not manually invoking the AGR so I most likely
> will not be able to use the method you have suggested.
> Chalmers
>> Hi Chalmers,
>> the 'Test Logs' tab, de-select 'Use defaults' and type in the name of
>> the test log in the 'Name' field. The millisecond timestamp is
>> appended to test logs only when a test log with the same name
>> currently exists on the local file system.
>> Paul
>>> Hi Everyone,
>>> name of the .execution file that is generated. Currently, my
>>> .execution files are being named <test-suite>_<milliseconds since
>>> 19??>.execution. I'd prefer to change it to
>>> <test-suite>_<year>_<month>_<date>.execution. Thanks in advance.
>>> Chalmers
Previous Topic:the test execution service launches additional JVM and Eclipse instance
Next Topic:Book dealing with TPTP?
Current Time: Sat Nov 01 15:19:22 EDT 2025
Powered by FUDForum. Page generated in 0.11450 seconds
