Home » Modeling » Graphiti » Shared editing domains and dispose
Shared editing domains and dispose [message #1039144] Thu, 11 April 2013 16:17 Go to next message
I've implemented a multi page graphiti editor, where each page is a
special subclass of DiagramEditor that takes care to share the editing
domain with the other DiagramEditors within the same multi page editor.
However, this gives problems when closing the editor, since the first
DiagramEditor's DefaultUpdateBehavior will dispose the editing domain
and when the following ones try, they throw a NPE. The problem is the
second line, where getOperationHistory() returns null.
In DefaultUpdateBehavior:
public void dispose() {
editingDomain.getResourceSet().eAdapters().remove(resourceSetUpdateAdapter);
resourceSetUpdateAdapter = null;
getOperationHistory().removeOperationHistoryListener(this);
for (Resource r : editingDomain.getResourceSet().getResources()) {
r.eAdapters().remove(updateAdapter);
EObject object = (EObject) diagramBehavior.getAdapter(Diagram.class);
if (object != null) {
object.eAdapters().remove(elementDeleteListener);
workspaceSynchronizer.dispose();
// Remove reference
disposeEditingDomain();
editingDomain = null;
Perhaps a test could be done first, to avoid calling
removeOperationHistoryListener when it's null?
Hallvard
Re: Shared editing domains and dispose [message #1039606 is a reply to message #1039144] Fri, 12 April 2013 06:50 Go to previous messageGo to next message
Hallvard,
good point. I added the check to the master branch (Gerrit change
https://git.eclipse.org/r/#/c/11848/).
Just in case you're interested: feel free to propose such changes in Gerrit.
Thanks for pointing out,
Michael
Re: Shared editing domains and dispose [message #1039973 is a reply to message #1039606] Fri, 12 April 2013 18:04 Go to previous messageGo to next message
It looked good to me :-) If it's enough is another question.
> Gerrit.
Hm, I'll have to take a closer look at that.
As I explained, my use case is a multi page editor. Perhaps the generic
parts of it could be integrated into Graphiti itself?
Hallvard
Re: Shared editing domains and dispose [message #1042512 is a reply to message #1039973] Tue, 16 April 2013 10:20 Go to previous message
"Hallvard Trætteberg" schrieb im Newsbeitrag
news:kka0d1$71p$1@xxxxxxxxe.org...
Hallvard,
I'm rather reluctant with adding more infrastructure around editors to the
framework at least for now, since you easily get GEF dependencies here. I'm
not sure yet where Graphiti will evolve to, currently there are options like
moving to GEF4 (as soon as it is out) or JavaFX as rendering engines. Fo
rboth options we will pile up more effort when we add stuff around the
editor.
But there is a small example on multi page editors in the Graphiti examples.
Have you seen that?
Michael
Previous Topic:Zooming in and out
Next Topic:Problems using our own Meta-Model
Current Time: Wed Jul 23 11:49:51 EDT 2025
Powered by FUDForum. Page generated in 0.03633 seconds
