Home » Eclipse Projects » EclipseLink » Problem mongodb query/find by id
Problem mongodb query/find by id [message #1031352] Mon, 01 April 2013 12:07 Go to next message
Using Eclipselink version 2.4.2-RC1 because of Bug 392174. Mongodb version is 2.4.0.
I am having a problem searching for a document by the mongo generated OID.
I have a simple mongo entity, Exercise, mapped to a collection called 'exercises. The id is mapped to _id as @GeneratedValue.
The document already exists in the collection.
 db.exercises.findOne()
        "_id" : ObjectId("5155ccb4f4b5a31e95000334"),
        "name" : "Unicycling",
        "description" : "unicycling"
Searching by id using:
    String exerciseId = "5155ccb4f4b5a31e95000334";
    Exercise testExercise = em.find(Exercise.class,exerciseId);
returns no results:
[EL Fine]: sql: 2013-04-01 10:25:20.203--ServerSession(529858968)--Connection(102824579)--Thread(Thread[main,5,main])--Executing MappedInteraction()
	spec => null
	properties => {mongo.collection=exercises, mongo.operation=FIND}
	input => [5155ccb4f4b5a31e95000334]
[EL Finest]: query: 2013-04-01 10:25:20.394--ServerSession(529858968)--Thread(Thread[main,5,main])--Adapter result: null
[EL Finest]: query: 2013-04-01 10:25:20.394--ServerSession(529858968)--Thread(Thread[main,5,main])--Data access result: null
I have also tried JPQL:
[code]
String id = "5155ccb4f4b5a31e95000334";
Query query = getEntityManager().createQuery("SELECT e FROM Exercise e WHERE e.id = :id");
query.setParameter("id", id);
List<Exercise> exercises = query.getResultList();
[\code]
Also with no results.
I am however able to query by one of the other fields:
    String description = "unicycling";
    Query query = getEntityManager().createQuery("SELECT e FROM Exercise e WHERE e.description = :description");
    query.setParameter("description", description);
[EL Fine]: sql: 2013-04-01 10:52:20.868--ServerSession(305297482)--Connection(70630159)--Thread(Thread[main,5,main])--Executing MappedInteraction()
	spec => null
	input => [DatabaseRecord(
	exercises.description => unicycling)]
[EL Finest]: query: 2013-04-01 10:52:21.772--ServerSession(305297482)--Thread(Thread[main,5,main])--Adapter result: [{_id=5155ccb4f4b5a31e95000334, description=unicycling, name=Unicycling}]
Once the record has been found by another search (or by a findAll()), the JPQL method of finding by id will return a record (I am assuming from the EntityManager cache). The EntityManager.find() method however still does not return results.
Has anyone else seen this behavior or have a workaround?
Jason
Re: Problem mongodb query/find by id [message #1032061 is a reply to message #1031352] Tue, 02 April 2013 10:20 Go to previous messageGo to next message
That is odd. We have similar tests that work.
Did EclipseLink insert the data, or did you manually insert it?
How did you map the Id?
Try using a byte[] or and ObjectId as the parameter instead of the hex string.
Re: Problem mongodb query/find by id [message #1032888 is a reply to message #1032061] Wed, 03 April 2013 11:14 Go to previous messageGo to next message
The data was inserted manually.
The id is mapped as:
    @Id
    @GeneratedValue
    @Field(name="_id")
    public String getId() {
        return this.id;
Changing the id from String to byte[] produces the same null result.
When I try to use ObjectId as the id type I get a conversion exception.
Exception [EclipseLink-3001] (Eclipse Persistence Services - 2.4.2.v20130315-93567e3): org.eclipse.persistence.exceptions.ConversionException
Exception Description: The object [5155ccb4f4b5a31e95000334], of class [class org.bson.types.ObjectId], could not be converted to [class [B].
	at org.eclipse.persistence.exceptions.ConversionException.couldNotBeConverted(ConversionException.java:71)
	at org.eclipse.persistence.internal.helper.ConversionManager.convertObjectToByteArray(ConversionManager.java:344)
	at org.eclipse.persistence.internal.helper.ConversionManager.convertObject(ConversionManager.java:134)
	at org.eclipse.persistence.internal.oxm.XMLConversionManager.convertObject(XMLConversionManager.java:186)
	at org.eclipse.persistence.internal.databaseaccess.DatasourcePlatform.convertObject(DatasourcePlatform.java:162)
	at org.eclipse.persistence.internal.descriptors.ObjectBuilder.extractPrimaryKeyFromRow(ObjectBuilder.java:2545)
	at org.eclipse.persistence.internal.descriptors.ObjectBuilder.extractPrimaryKeyFromExpression(ObjectBuilder.java:2392)
	at org.eclipse.persistence.internal.queries.ExpressionQueryMechanism.checkCacheForObject(ExpressionQueryMechanism.java:866)
	at org.eclipse.persistence.queries.ReadObjectQuery.checkEarlyReturnLocal(ReadObjectQuery.java:243)
	at org.eclipse.persistence.queries.ObjectLevelReadQuery.checkEarlyReturn(ObjectLevelReadQuery.java:838)
	at org.eclipse.persistence.queries.DatabaseQuery.execute(DatabaseQuery.java:789)
	at org.eclipse.persistence.queries.ObjectLevelReadQuery.execute(ObjectLevelReadQuery.java:1109)
	at org.eclipse.persistence.queries.ReadObjectQuery.execute(ReadObjectQuery.java:421)
	at org.eclipse.persistence.queries.ObjectLevelReadQuery.executeInUnitOfWork(ObjectLevelReadQuery.java:1197)
	at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.internalExecuteQuery(UnitOfWorkImpl.java:2879)
	at org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1607)
	at org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1589)
	at org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1554)
	at org.eclipse.persistence.internal.jpa.QueryImpl.executeReadQuery(QueryImpl.java:231)
	at org.eclipse.persistence.internal.jpa.QueryImpl.getResultList(QueryImpl.java:403)
I can retrieve by the object Id using a native query, but I can't get native queries to work with Auth turned on.
Thanks for your help.
Re: Problem mongodb query/find by id [message #1037404 is a reply to message #1032888] Tue, 09 April 2013 10:12 Go to previous messageGo to next message
Can you try having EclipseLink insert the data.
Re: Problem mongodb query/find by id [message #1039139 is a reply to message #1037404] Thu, 11 April 2013 16:10 Go to previous messageGo to next message
When I try to use the EntityManager.persist method, it appears to work from the Java side. I can query the created object by id. However, it only appears to be written to the entity manager cache. It never gets persisted to mongo.
EDIT
I had the persist method wrapped in a Facade class. I had not yet added the transaction or flush. I added that and now get an exception that my class is not a known entity type.
It is included in the persistence.xml but I still see the exception.
[Updated on: Thu, 11 April 2013 16:20] by Moderator
Re: Problem mongodb query/find by id [message #1039172 is a reply to message #1039139] Thu, 11 April 2013 17:24 Go to previous messageGo to next message
The exception turned out to be Glassfish related. A restart of the app server and a redeploy of the application fixed it. The object still was not written to the collection however.
I had the entity declared as:
@Entity
@NoSql(dataType="exercises",dataFormat=DataFormatType.MAPPED)
public class Exercise extends BaseEntity {
When I remove the dataType and let JPA insert to the default collection name EXERCISE, everything works as expected.
Is overriding the default collection name supported?
Re: Problem mongodb query/find by id [message #1042464 is a reply to message #1039172] Tue, 16 April 2013 09:17 Go to previous messageGo to next message
What error do you get? Enable logging on finest and include the log.
Re: Problem mongodb query/find by id [message #1052646 is a reply to message #1042464] Tue, 30 April 2013 06:49 Go to previous messageGo to next message
I've got the same problem. My eclipselink version : 2.4.1.
My class :
@Entity
@NoSql(dataFormat=DataFormatType.MAPPED, dataType="collecte")
public class Collecte {
@Id
@GeneratedValue
//@Field(name="_id")
private String id;
I've tried with or without @Field annotation, same results.
The test :
EntityManagerFactory emf = Persistence
.createEntityManagerFactory("mongoPU");
EntityManager em = emf.createEntityManager();
Collecte c = em.find(Collecte.class, "517f9d50559a541e63011fe0");
//Query q = em.createQuery("select c from Collecte c where c.id =:id");
// Query q = em.createNativeQuery("db.collecte.findOne({\"_id\": ObjectId(" +"517f9d50559a541e63011fe0"+ ") \"})", Collecte.class);
//q.setParameter("id", "517f9d50559a541e63011fe0");
// Collecte c = (Collecte) q.getSingleResult();
assertThat(c.getEan()).isEqualTo("3251248033108");
None of the methods find(), createQuery, createNativeQuery() works.
The logs :
[EL Finest]: jpa: End deploying Persistence Unit mongoPU; session file:/home/david/git/servicescrowdsourcing/target/scala-2.10/classes/_mongoPU; state Deployed; factoryCount 1
[EL Finer]: connection: client acquired: 148643588
[EL Finer]: transaction: acquire unit of work: 1188706162
[EL Finest]: query: Execute query ReadObjectQuery(name="readObject" referenceClass=Collecte )
[EL Finest]: connection: Connection(1634151355)--Connection acquired from connection pool [default].
[EL Fine]: sql: Connection(1634151355)--Executing MappedInteraction()
spec => null
properties => {mongo.collection=collecte, mongo.operation=FIND}
input => [517f9d50559a541e63011fe0]
[EL Finest]: query: Adapter result: null
[EL Finest]: query: Data access result: null
[EL Finest]: connection: Connection(1634151355)--Connection released to connection pool [default].
The data have been inserted in MongoDB also with EclipseLink.
Any advice ?
David
Re: Problem mongodb query/find by id [message #1052720 is a reply to message #1052646] Tue, 30 April 2013 08:56 Go to previous messageGo to next message
Is your insert now working, or not? Please include the log from your insert if it is not working.
So, both the insert and the find work when you do not set the dataType, but neither work when you do?
Re: Problem mongodb query/find by id [message #1052803 is a reply to message #1052720] Tue, 30 April 2013 10:50 Go to previous messageGo to next message
Yes insertion in database work find but I think find the cause :
1/ if you add the annotation @Field(name="_id"), the id java field is record as a capitalise string in the _id database field, not as an ObjectId.
2/ if you suppress this annotation, you hava two UUID record in the database, first in ID column and the UUID string is capitalise, and second UUID in _id column, not capitalized and it's type is ObjectId !
In first case, you can find the produit with the ID, but tools like MonjaDb and Genghis can't be used to maintain database.
In second case, you can find the product with the capitalize id, but record twice an UUID is strange...
Re: Problem mongodb query/find by id [message #1053070 is a reply to message #1052803] Thu, 02 May 2013 06:32 Go to previous messageGo to next message
To finally have somethings that work as I except, I've used the Converter annotation like this :
@Entity
@NoSql(dataFormat=DataFormatType.MAPPED, dataType="personne")
public class Person {
	@Id
	@GeneratedValue
	@Field(name="_id")
	@Converter(name="convertisseurObjectId", converterClass=model.utils.ObjectIdConverter.class)
	@Convert("convertisseurObjectId")
	private String personId;
	@Column(name = "PERSON_NAME")
	private String personName;
and here is the converter class :
package model.utils;
import org.bson.types.ObjectId;
import org.eclipse.persistence.mappings.DatabaseMapping;
import org.eclipse.persistence.mappings.converters.Converter;
import org.eclipse.persistence.sessions.Session;
 * Converter of the ObjectId type, used by MongoDB
 * @author david
public class ObjectIdConverter implements Converter {
	public Object convertObjectValueToDataValue(Object objectValue,
			Session session) {
		ObjectId objId;
		if (objectValue instanceof ObjectId)
			objId = (ObjectId)objectValue;
		else
			objId = new ObjectId((String)objectValue);
		return objId;
	public Object convertDataValueToObjectValue(Object dataValue,
			Session session) {
		ObjectId objId;
		if (dataValue instanceof ObjectId)
			objId = (ObjectId)dataValue;
		else
			objId = new ObjectId((byte[])dataValue);
		return objId.toString();
	public boolean isMutable() {
		// Yes
		return false;
	public void initialize(DatabaseMapping mapping, Session session) {
		// Nothing to DO
Usefull are not ?
David
Re: Problem mongodb query/find by id [message #1053771 is a reply to message #1053070] Tue, 07 May 2013 10:28 Go to previous message
MongoDB requires an "_id" key field. If your data does not contain one, Mongo will generate one as an ObjectId.
The application is free to use whatever value it wants for "_id", it is odd your tools are requiring this to be an ObjectId.
In EclipseLink, you can use whatever type you want for the "_id", but this will be the value passed to Mongo. So if you map it as String, then it will be a String.
@GeneratedValue will initialize this field with a new ObjectId converted to your field's type (in your case String).
Your converter is probably the best way to ensure the type is an ObjectId in the database.
You might also be able to declare the type as ObjectId to avoid the String conversion. If this does not work, please log a bug to have ObjectId support corrected.
Previous Topic:When will Eclipselink 2.4.2 be released?
Next Topic:Convert .NET DateTimeOffset <--> Jodatime DateTime (utc)
Current Time: Sun Oct 26 12:32:58 EDT 2025
Powered by FUDForum. Page generated in 0.41146 seconds
