Home » Language IDEs » C / C++ IDE (CDT) » 100% Memory CDT2
100% Memory CDT2 [message #102934] Sat, 22 May 2004 12:22 Go to next message
Originally posted by: compuhelp.caramail.com
Hi all,
I have a little bug...
CDT use periodycally 100% of my memory,
according to this ecipse popup window:
http://compuhelp.free.fr/eclipse2.jpg
and when I'm using cdt, sometimes all is good
but sometimes it was very very slow to edit source code
(and the popup appear)
what happen?
under JDT (when I work in Java), all is good and quick.
Thanks in advance.
Compu
Re: 100% Memory CDT2 [message #103876 is a reply to message #102934] Wed, 26 May 2004 18:54 Go to previous messageGo to next message
I would recommend trying our M9 build once it is released; let us know if it
is any better. If you find the situation is still bleak, raise a defect @
bugs.eclipse.org.
JC
"Compuhelp" <compuhelp@caramail.com> wrote in message
news:c8nuaa$kp2$1@eclipse.org...
> Hi all,
> what happen?
> Thanks in advance.
> Compu
Re: 100% Memory CDT2 [message #103966 is a reply to message #102934] Thu, 27 May 2004 10:54 Go to previous messageGo to next message
Originally posted by: news.u-h-l.de
This is an OpenPGP/MIME signed message (RFC 2440 and 3156)
--------------enig4DB6F0A5FA7633A7468A3937
Content-Type: text/plain; charset=us-ascii; format=flowed
> what happen?
I also had this problem today when I wanted to use Eclipse M8 together
with CDT M8. I then tried the development snapshot of CDT together with
Eclipse M9 but - as you probably would expect - it was not usable for
"production use" either. So I decided to go a step back and installed
CDT M7 in Eclipse M8 (you have to remove CDT M8 before if it was already
installed). And it seems that it does not suffer from the above bug. (At
least it runs now for about an hour without any problems whereas the M8
release did not survive for more than five minutes!)
Klaus
God is real ...
\|/ ____ \|/ ... unless declared integer.
\_| \__/ |_/ Mail me : news@u-h-l.de
\__U_/ WWW : www.u-h-l.de
PGP : 0x128F9DEC
Content-Type: application/pgp-signature; name="signature.asc"
Content-Description: OpenPGP digital signature
Content-Disposition: attachment; filename="signature.asc"
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.4 (GNU/Linux)
Comment: Using GnuPG with Thunderbird - http://enigmail.mozdev.org
iD8DBQFAtgEqyaizchKPnewRAjsKAJ4polvTYnYHrZElIA0T32qhvmmHeACg os9C
sHmmAM8OGE7sWJLokRzICTA=
=TiYO
-----END PGP SIGNATURE-----
--------------enig4DB6F0A5FA7633A7468A3937--
Re: 100% Memory CDT2 [message #103981 is a reply to message #103876] Thu, 27 May 2004 10:54 Go to previous messageGo to next message
--------------enigED13F9B2EE237B2F1A3EF548
> bugs.eclipse.org.
Do you already have an estimate of when the M9 build will probably be
released?
Klaus
God is real ...
PGP : 0x128F9DEC
iD8DBQFAtgEtyaizchKPnewRAtHRAJ4tzT2yMgcUe4H5HdoyHyfdbGBPAgCe KvJ1
sWZbRJNlIXLOa+J50GcPz+o=
=aTF9
--------------enigED13F9B2EE237B2F1A3EF548--
Re: 100% Memory CDT2 [message #104011 is a reply to message #102934] Thu, 27 May 2004 14:34 Go to previous messageGo to next message
--------------enig983DCF8551C8373FECB36F06
> what happen?
It seems to be a problem with the version of the Java runtime you use.
When I run Eclipse+CDT (both release M8) with a JRE 1.4.2 (_03 and _04!)
then I encounter the same problem. But when I run them with a JRE 1.4.1
then everything is fine. Eclipse+CDT still need very much CPU time while
I'm working with them but CDT does not use up all memory so that I have
to kill Eclipse.
Klaus
God is real ...
PGP : 0x128F9DEC
iD8DBQFAtjTRyaizchKPnewRAp4fAJ9LAKaZUR5Mw4leycWAlhETWZXF4gCf ZIjJ
Gpfs/qMXnX4Gg3rnYxmB7cY=
=O6wM
--------------enig983DCF8551C8373FECB36F06--
Re: 100% Memory CDT2 [message #104061 is a reply to message #104011] Sat, 29 May 2004 07:56 Go to previous message
>> what happen?
> to kill Eclipse.
ok, but I installed the same JRE (1.4.2) and Eclipse (M8) in my portable
pc, and all is perfect: the problem don't appear :/
Alex
Previous Topic:Wiki updates
Next Topic:Importing my c++ classes HELP
Current Time: Wed Sep 17 11:58:59 EDT 2025
Powered by FUDForum. Page generated in 0.04260 seconds
